Old 02-27-2002, 03:40 PM   #1
TurismoLou
Member#: 9480
2011 Wrangler Unlim.
Anti-hybrid
Default What modifications for 12 sec. 1/4 mile?
I just was interested in what modifications the big boys were running that are in the 12 sec club. I figure I might as well pattern my car after the guys with the experience.
TurismoLou is offline   Reply With Quote
Old 02-27-2002, 03:43 PM   #2
WRXThis
Member#: 3960
1. upgraded turbo- I have PE1820
2. fuel injectors- I have STI 565cm injectors
3. fuel pump- I have Toyota Supra pump flows 255lh
4. engine management- I have unichip with AL02 map
5. CAI- I use AEM's
6. turbo back exhaust- I have catless BPM MKIII
7. boost control- I use AVC-R with unichip
8. up-pipe- I use Brullen's
9. a good driver- Me, myself and I
WRXThis is offline   Reply With Quote
Old 02-27-2002, 03:57 PM   #3
geronimo
Member#: 6910
1988 Mustang
Purple
Vishnu stage 1....
geronimo is offline   Reply With Quote
Old 02-27-2002, 04:13 PM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Originally posted by geronimo
Vishnu stage 1....
Did I miss something? I didn't know it was out, and/or producing sub 12's with a stock turbo.
My bad.... and yes.. I'm too lazy to search right now
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 02-27-2002, 04:21 PM   #5
WRXThis
Member#: 3960
I highly doubt that it is RiftsWRX with a stock TD04. I have not seen this either.
Old 02-27-2002, 04:51 PM   #6
geronimo
Member#: 6910
1988 Mustang
Purple
it isn't yet but the numbers are... 239+HP and 250ftlbs.... the + is another 10 with the cat back. I've seen subies with less than that run 12's.
Old 02-27-2002, 04:53 PM   #7
TurismoLou
Member#: 9480
Anti-hybrid
What about Nathan and Al?
Old 02-27-2002, 05:33 PM   #8
jmott
Member#: 6713
2007 Prius
brown
thats in 2 wheel drive mode.
vishnus dyno numbers cant be compared with cobbs or turboXSs
jmott is offline   Reply With Quote
Old 02-27-2002, 06:01 PM   #9
geronimo
Member#: 6910
1988 Mustang
Purple
Shiv's stage 1 is supposed to make near, real near the 300fwhp. Maybe more, their are guys on here running mid to low 13's with a stage 0 and an EBC. So I could easily see the stage 1 running into the high 12's stock turbo, fuel sys, IC, i'd have to say that for the money that is a very nice way to go. Besides I don't know of many sompanies that are more concerned with their customers, and haveing a great product even if that means taking your time.
I will be vishnuing my WRX all the way.
Old 02-27-2002, 06:06 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
^ true dat (referring to jmott, I just lagged on typing)
From what I've seen, people have run very near 12s on a stock turbo with only intake, exhaust, some fueling, and tuning.
I would think it would be easily possible with the following (I'm armchair dragging here, bear with me.)
up-pipe + turbo back
Samco IC hoses
larger injectors
fuel pump
<Insert larger than stock turbo here>
Tuning (Unichip or otherwise)
I don't think it matters what turbo, from FP/vf24 low lag type to 1820 high power type. You could get DEEPER into 12s with larger turbos, FMIC or upgraded TMIC, etc... but I think the above is all that would be necessary to guarantee 12s given a decent driver.
People have gotten so close to 12s on the stock turbo that I imagine you could break into the 12s on the stock turbo if you really tried.
Concillian is offline   Reply With Quote
Old 02-27-2002, 06:21 PM   #11
jmott
Member#: 6713
2007 Prius
brown
that stage0 in the low 13s was also on 98 octane fuel....
Old 02-27-2002, 06:28 PM   #12
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
I really think that a Vishnu stage one will push some people into the high 12's, especially with a cat back. Even if you don't take the dyno numbers literally, you can still use them as a comparison. The stage zero increases horsepower by 30, and that took over a full second off of many peoples 1/4 times. Do you think adding another 30 horsepower could take off another half a second? I think so. VS1+good cat back = 12 sec. club. Now I just need to buy a rex. waiting--->
rex n effect is offline   Reply With Quote
Old 02-27-2002, 06:35 PM   #13
WRBLUEWAGON
Member#: 10745
2006 VW SUV
I beleve stage 1 cars with a very good driver will be bracking 12's very constently. I ran the old stage 0 map with only 15psi and did 13.6 and better all day long, with $hity 60 times. I have a very good Idea about what is going to be in stage 1 and I have a good feeling that the stock turbo will support [email protected] The Vishnu cars are perfectly tuned for 91oct so if anyone is running better than 91 they can put the boost up to 16 and with stage 1 do 12's all day long. And with there future intercooler I can see the stock turbo pushing 14psi to 14.5 at readline. At 16psi I push 13psi at redline right now because of my intercooler hoses. I was able to gain 1psi just because of the hoses. Plus the stage 1 are putting 50ftt and 20 more hp. And as far as how much power this would be a AWD, try [email protected]=282@ crank
Eric
WRBLUEWAGON is offline   Reply With Quote
Old 02-27-2002, 06:38 PM   #14
jmott
Member#: 6713
2007 Prius
brown
k
best of luck to you stage1 guys
but I predict few if any 12s
Old 02-27-2002, 07:16 PM   #15
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I'd tend to agree with jmott, I can't see Stage 1 doing consistent 12s regardless of gas.
IF you add an upgraded IC, fueling, catback and potentially standalone management you could probably hit 12s consistently with the stock turbo, but then you wouldn't be running Stage 1, would you?
Old 02-27-2002, 09:09 PM   #16
WRBLUEWAGON
Member#: 10745
2006 VW SUV
You know I'm very opptimistic (Spelling). But for me to lay out the money I need to be. But Dug-e-fresh ran a [email protected] with just stage 0. And every one I have run on street I have won by over a car lenth. I really think stage 1 will do 12's.
Eric
Old 02-27-2002, 10:18 PM   #17
TurismoLou
Member#: 9480
Anti-hybrid
Well I guess we just have to wait and see who's right until the stage 1 comes out. What is included in the stage 1 anyway?
Old 02-28-2002, 12:21 AM   #18
slowracing
Member#: 12799
2002 Impreza WRX
13.03 @ 101.9mph
well i ran 13.3 at 99.7 mph. I think going 12's on stock turbo will be easy. I didnt say cheap i said easy. im putting on the cusco header and iridium plugs this weekend. im crossing my fingers for 12's with bolt ons only and no boost controller or cpu yet. i just have a stronger wastegate that holds 13-14lbs of boost. i think with 16lbs mid to high 12's is attainable.
slowracing is offline   Reply With Quote
Old 02-28-2002, 02:00 AM   #19
nmyeti
Member#: 4980
what about us? Not to be a jerk here but we have posted our setups on this board SO many times... questions like this are better answered with a search...
Try page 2 of this thread for a look at what i had when i was running 12.3. I am not running that setup any longer... i expect i've gotten a bit faster. With any luck i'll have dyno numbers and track times from a totally new setup late march.
http://www.i-club.com/forums/showthr...ghlight=PE1820
nmyeti is offline   Reply With Quote
Old 02-28-2002, 03:15 AM   #20
WRX-ellent
Member#: 9071
2002 WRB Impreza WRX
FMIC/1820 inside & Link'd
Ok...here is my 2cents. I don't think the Stage 1 can hit 12's but I think the stock turbo coupled with the right mods can hit 12's...flame suit on!!!
~joe
WRX-ellent is offline   Reply With Quote
Old 02-28-2002, 09:33 AM   #21
fueledbymetal
Member#: 14425
2002 WRX Sedan
SOLD!
I checked this link and I didn't see any transmission modifictaions (you did mention stock clutch). So am I correct in assuming you did your low 12 second run with the stock Transmission?
fueledbymetal is offline   Reply With Quote
Old 02-28-2002, 09:38 AM   #22
WRBLUEWAGON
Member#: 10745
2006 VW SUV
You know what, Time will tell. I'll have stage 1 when it comes out and the very next day after it will be installed I'll be on the track.
Al and Nathen are making big power with monster turbos and fuel upgrades. Like 660in, stand alones, Supra Fuel pumps and pe1820 and now t03/04. In a perfect world Nathen would have pulled a 11 flat and Al would have gotten to is 11.9. These cars are hard to drive with that much twist. With the stocker I really think 12s are in it. EMS is the key to it all.
Eric
Old 02-28-2002, 10:51 AM   #23
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
I ran the 13.332 on Vishnu Stage 0...
and yes I ran it with 98 octane...
98 octane that had probably been sitting underground for the last 5 or 6 months. According to a couple tuners in the know, for what I have and the state at which my unichip is tuned for, 98 octane is not gonna make a difference... I will find out though, for the skeptics...
But, I mean how many people pay $4/gallon when the drag race season has not even really began yet. That 98 octane mikaust and I used was probably a real bad idea... it was old and probalby was less than pure....
I am thinking about running again tomorrow... I will have ony 93 octane.... if I run I will let you guys know what I got.
But in regards to Stage 1 running 12s... well, I think its possible. HP isn't everything when running the 1/4 mile.
I have heard through the grapevine that I should not be running the times I am running with the theoretical HP my engine produces... but guess what? I am.
At 13.332, and that being only my 2nd run of the season, I think I can improve those times by abit as they are. Nothing major.... but I think I can take a sneak peak into the 13.2s with no other mods! Hardly anything more to do than just drive better, eh?
Stage 1 will at the very least pull 2 tenths off my time!! I also think most people are caught up in the peak of this versus the peak of that.... and peaks are important....but, the area under that entire curve is a more telling story in regards to overall power and performance increases.....
In a 1/4 mile charge (even nmyeti) you use 1st, 2nd, 3rd and 4th gears only...
Shifting at 7000rpms (instantaneously) in 1st would drop you to about 3900rpms in 2nd
Shift at 7000rpms in 2nd and you will drop to about 4900rpms in third...
Shift at 7000rpms in 3rd and you will drop to about 4900rpms again in 4th.
So in a 1/4 mile run you need good power all through the RPM band because of the launch in 1st.
From there on out you need power from 4k and up...looking at Shivs dyno curves of the Stage 1 over Stage 0, theres huge chunks of area under the curve between the 2, especially in the 4k to 55k range.... right in the sweet spot where the tach falls when redline shifting!!
Doug
dug-e-fresh is offline   Reply With Quote
Old 02-28-2002, 10:56 AM   #24
WRBLUEWAGON
Member#: 10745
2006 VW SUV
if anyone can do 12s in a stage 1 it will be dug-e.
Old 02-28-2002, 11:04 AM   #25
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
thanks WRBLUEWAGON... I appreciate your input! I will try my best....
Doug
For those running 10 sec 1/4 miles tino Proven Power Bragging 46 07-03-2008 12:38 PM
4.8L 4000 HP 5.5 sec. 1/4 mile 4 banger Colonel Lingus Off-Topic 59 04-13-2006 08:15 PM
12 Sec 1/4 Mile Stock Turbo/Fuel Record Carlo Proven Power Bragging 72 06-15-2002 10:10 AM
12 sec 1/4 mile on OE fuel system?? Division By Zero Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 64 06-08-2002 09:29 PM
Whats mods to get a WRX to burn a 11 sec 1/4 miles time? JammaREXV1.0 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-01-2002 01:33 PM
