Old 06-01-2008, 03:34 AM   #1
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Default Sti cluster swap
I know there is one on here already but i didnt see one for the STI to 02 wrx swap. Maybe i wasnt paying attention but i really need some info on this as im sure others do. I know it isnt a direct plug in but i dont know the specifics. Any legit info on this?
crpwrx is offline   Reply With Quote
Old 06-01-2008, 03:30 PM   #2
Feign
Member#: 68604
06 STi
Plenty of threads on this.
http://forums.nasioc.com/forums/show....php?t=1458180
Buy an 04 STi cluster. It will plug and play. The only thing that will be wonky is the Rear Diff warning light. I think you can ground it, otherwise...put some tape over it and call it a day.
If you buy an 05 or up there are more things involved. Look at post 5 in the link above as an example.
Feign is offline   Reply With Quote
Old 06-01-2008, 06:22 PM   #3
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
Thank you for the reply
Old 06-01-2008, 09:16 PM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
I just did an '05 into a '02 swap. its not terribly difficult the only thing that still hasn't been ironed out is the outside temp light. Look for my posts in the link above. the only difference between 04 and 05 cluster is the ABS light needs a little rewiring to make it work correctly.
mostly its cutting two wires and shaving a little lip on one of the plugs.
ProdriveDreams is offline   Reply With Quote
STi cluster swap to OEM wrx cluster JustAnotherSubie Newbies & FAQs 2 09-08-2008 04:17 PM
JDM STi Cluster Swapping PinoCchiOy Electrical & Lighting 7 09-24-2004 05:59 PM
Has anyone done STi cluster swap in WA? subimp6u08 North West Impreza Club Forum -- NWIC 2 04-13-2004 11:16 PM
STI Cluster Swap question WReXinEfX Interior & Exterior Modification 7 05-19-2003 03:59 PM
New STi cluster swap Leonardo Interior & Exterior Modification 60 12-07-2002 04:40 PM
