Old 06-01-2008, 11:41 PM   #1
03twrx
Member#: 73737
I've travled 500 mil
es to give you my seed
Default 04STi: BB's in a can sound, slow boost, no power
Was passing in 4th and then I heard a rattle can sound comming from the turbo area. Now under accel I hear it. No power. Sometimes makes boost, even then still no power. I think the turbo took a crap. Idles fine. Rattles a little durring reving, out of gear. A buddy told me a puff of white smoke came out of my exhaust when it happened, but I haven't seen any since. Any thoughts? Time for a green....
03twrx is offline   Reply With Quote
Old 06-02-2008, 09:23 AM   #2
03twrx
Member#: 73737
Also, the rattling doesn't get any louder or faster at higher rpms.
Old 06-02-2008, 10:05 AM   #3
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
BBS in a can is how people always describe detonation. Any chance you got some bad gas? How much boost do you run? Mods?
The fact that it doesnt get any louder and comes from the turbo area tells me it may not be det though.
Defiant Autospeed is offline   Reply With Quote
Old 06-02-2008, 10:44 AM   #4
RemlapaN
Member#: 58251
2004 Sti
GT35R 530whp @ 27psi
It's really difficult to get an ej257 to det when it's not under boost though - OP said he can recreate it in neutral free-revving.
Sounds like a fried turbo bearing if the car will not make boost.
RemlapaN is offline   Reply With Quote
Old 06-02-2008, 10:54 AM   #5
P&L Motorsports Inc.
Member#: 67199
07 [email protected] STI
97 RS [email protected]
....Or a rod bearing.
I wouldn't keep doing that until you find out for SURE.
-Jorge
P&L Motorsports Inc. is offline   Reply With Quote
Old 06-02-2008, 12:52 PM   #6
viaburn26
Member#: 167272
2004 STi
maybe the flex joint under the turbo blew out and making the up-pipe heat shield rattle even more .... of course if you wastegate arm comes off you won't have any boost
viaburn26 is offline   Reply With Quote
Old 06-02-2008, 09:44 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the early 04s pinged like a mother .. you on the stock engine managment?
Old 06-03-2008, 03:07 AM   #8
03twrx
Member#: 73737
It's offical, I'm the only NA STi in Florida! On my way to work the car would make a little boost, then, smoke real bad durring shifts. On the way home tonight, more of the same then no more noise and no more sound. I have a 255 pump, FMIC, short intake, halman mbc and a tune. Regular maint. including oil changes and all that stuff. Time for the 07 turbo and ewg.
Old 06-03-2008, 10:23 AM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
how many miles on the turbo when it let go?
Old 06-03-2008, 10:01 PM   #10
hwy61
Member#: 87950
2005 STI
Gone....Somewhere in MS
Be sure and flush out any turbo parts that might have found their way into the intercooler and especially before they find their way into the engine. A turbo is one thing, turbo parts in the cylinders is another.
You've determined that this is the turbo and not the rings or pistons from pre-detonation? While the turbo does have oil going to it I'm not sure what to make of the smoke during shifts except that you usually close the throttle on a shift and that creates more vacuum at the piston which could be sucking up oil if a damaged piston or rings. What ever, Hope you get it running better and faster than ever soon. Hwy61
hwy61 is offline   Reply With Quote
Old 06-04-2008, 02:42 AM   #11
03twrx
Member#: 73737
I'm not to sure on the turbo. It was off of an 05 STi. Maybe around 35k on it.
Old 06-04-2008, 02:45 AM   #12
03twrx
Member#: 73737
True true, I've parked teh car and will start pulling it apart within a few days. I'm more that confident it's the turbo. Rock solid idle. No miss or hesitation durring accel. I will start a new thread with pics when I tear it down. On a side note, 07 STi turbo on an 04?
Old 06-04-2008, 12:49 PM   #13
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Did you check everything make sure it's all hooked up?
k04sti is offline   Reply With Quote
Old 06-04-2008, 01:20 PM   #14
flycaster
Member#: 60142
2011 WRX
Grey
It's pretty unusual for a street turbo to lock up without any prior warning (i.e., oil smoke in the exhaust). You're getting zero boost? That's pretty odd, amigo. I'm not saying the turbo isn't dead, but have you checked all your pre-turbo (manifold, up-pipe) and post-turbo charge-pipe connections?
flycaster is offline   Reply With Quote
Old 06-04-2008, 09:18 PM   #15
03twrx
Member#: 73737
going to start pulling parts off on sat.
Old 06-04-2008, 09:37 PM   #16
dibblejr
Member#: 94070
05 LGT
You may want to pull the TI off the turbo and check the impeller shaft nut. My friend described the same noise and we was checking his car and found the nut was only on by one thread. I took it off by hand.
We tried replacing the nut, but the damage was already done and the turbo was changed.
Oh yeah, the dealer had serviced his turbo about a year before that. They told him they replaced the turbo,
Jay-R
dibblejr is offline   Reply With Quote
low boost no power 07UGM_TR Newbies & FAQs 8 02-18-2010 07:11 PM
hAlp! No power, no boost ein86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-15-2008 07:16 PM
I'm living in a refugee camp, no power, no hot water, and no love from the man. Mud Pig Off-Topic 16 04-17-2007 10:17 AM
uppipe install, now low and slow boost with cold engine - no audible leaks cartervt2k Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-14-2004 04:52 PM
marble in tin can sound? stink Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-15-2004 03:20 PM
