Old 06-03-2008, 05:16 PM   #1
Imprezd
Member#: 3357
News TurboXS 2008 WRX Stage 1 & Stage 2 Results!
Finally we have our 2008 WRX Hatch Cat-back System. This was our final piece to able to put a complete Turboback Exhaust on the car out of production parts and continue on our mod development path. In stock form the car lacked punch. It was almost useless to take it over 5500 rpm. Ok so Stage 1 there is still not much of a reason too but it is better than stock. :-) We put the car on our in house dyno and our baseline results were as follows:
Baseline Peak Numbers 213.8 ft. lbs. and 193.7 whp
Modifications:
Completely Stock 2008 WRX
Now that we have a starting point it was time to install and Tune our Delta ECU. The Delta Installation was pretty simple especially since we went to a smaller modular harness and ECU combination. As usual its a plug and play!
We ran 16.5 psi peak, the car responded well despite the itty bitty baseboard heater Subaru decided to call an Intercooler. The combination of leaning out the AFR and Turning up the boost net us a 47 ft. lbs gain and 25 whp gain peak. As you can see by the dyno plots the gains are solid throughout out the curve.
Modifications:
Engine Management Delta-003
The car drives well with the combination. Very smooth driving around town just more power everywhere. It is deceiving since in almost any gear the car can accelerate briskly. Still very quiet honestly it would be hard to tell that car was modified except for the new found giddy up.
Cat-back only pictured!
The Turboback features our 4 inch Bellmouth Downpipe design. Which has worked very well in the pass for our car we coupled it with a cat-less racepipe. Although you can purchase the Turboback with a high flow metal matrix converter. The 2008 WRX Hatch needed a cat-back solution as the exhaust exit is now on the right side of the car. So this required a complete redesign from the bottom up. We went with more of a refined look as the smooth lines of the hatch really want you to think it has grown up a little bit from previous models. The 4 inch slash cut tip fills the bumper nicely without being too aggressive.
Pics: Tip Right Side / Rear of Car
Here are a few pictures of the exhaust with the car on the lift. To get a complete idea of the exhaust system layout.
Pics: Installed Underneath
The installation of the Turboback was pretty straight forward. The car is back on the dyno this time with its new roar. It was not loud at all for a completely cat-less exhaust. We removed the Delta ECU from the vehicle to see what the car would do without any tuning. To my surprise the car made strong gains for exhaust only. The final horsepower output number are 243 ft. lbs and 223 whp. Not bad actually a little better than the Stage 1 results. A 29 ft. lbs. and 30 whp gain over a stock 2008. Not bad for a few pipes!
Modifications:
Turboback - W08H-TBE-RP Includes: 4 inch Bellmouth Downpipe, 3 inch Cat-less Race Pipe and a 3 inch Cat-back Exhaust with a 4 inch Slash-cut Tip
After reinstalling and Tuning the Delta running a peak of 17 psi. The gains were pretty serious, a pretty impressive peak torque of 307 ft. lbs and 246 whp a 93 ft. lbs. and 54 whp gain. This is the ticket!
Modificatons:
Engine Management - Delta-003
Turboback - W08H-TBE-RP Includes: 4 inch Bellmouth Downpipe, 3 inch Catless Race Pipe and a 3 inch Cat-back Exhaust with a 4 inch Slash-cut Tip
Delta ECU Downloads:
Right Click Save As:
2008 WRX Delta ECU Stage 1 Map
2008 WRX Delta ECU Stage 2 Map
Parameter File
Video:
http://www.youtube.com/watch?v=WbtM45zkV-s
So there it is .... Stage 1 and Stage 2!
note: We had some dyno shake issues with the test car so we couldn't go full throttle at 2k rpm which is why it shows a loss of hp.
Also waiting on video content to finish being edited.
Special Thanks to Matt H for letting us use his 2008 WRX Wagon.
Imprezd is offline   Reply With Quote
Old 06-03-2008, 06:01 PM   #2
Matt_H
Member#: 107000
2015 BMW X1
Hot!!!
Thanks again to everyone at TurboXS and to you Jermaine!
Matt_H is offline   Reply With Quote
Old 06-03-2008, 06:22 PM   #3
akaGeneyus
Member#: 127247
2015 Impreza
nice! im definately going to you (jermaine) once i install my txs gt30r. matt how does the car feel???
akaGeneyus is offline   Reply With Quote
Old 06-03-2008, 07:03 PM   #4
Matt_H
Member#: 107000
2015 BMW X1
It feels like a whole new car. Pulls hard through every gear and can actually get out of it's own way now. I was really impressed with the whole process and won't be going anywhere else.
Old 06-03-2008, 10:55 PM   #5
InfamousDX
Member#: 25413
awesome gains.
Old 06-04-2008, 10:03 AM   #6
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Awesome gains... and an even better post. Love the content...
def
dug-e-fresh is offline   Reply With Quote
Old 06-04-2008, 10:20 AM   #7
starbux
Member#: 166874
2008 WRX
Red
Looks real nice. How long before you get that setup for sale on your website?
starbux is offline   Reply With Quote
Old 06-04-2008, 10:21 AM   #8
lateralus1082
Member#: 170764
2008 VF40'd WRX
OBP 4 door Corolla
any chances for a 4-door exhaust?
lateralus1082 is offline   Reply With Quote
Old 06-04-2008, 10:29 AM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
impressive numbers...but so much for not modding it too much matt
are those the sti springs under there too?
Old 06-04-2008, 10:30 AM   #10
08GRSTi
Member#: 179806
2008 Impreza STi
Lightning Red
+1 for the downpipe
08GRSTi is offline   Reply With Quote
Old 06-04-2008, 10:35 AM   #11
Matt_H
Member#: 107000
2015 BMW X1
Yeah I know.
Yep they are STI springs.
Old 06-04-2008, 10:47 AM   #12
Hi-Speed Solutions
Vendor
Member#: 143099
2008 AW STI
Rockin' the hatch!
nice!
Hi-Speed Solutions is offline   Reply With Quote
Old 06-04-2008, 11:22 AM   #13
Imprezd
Member#: 3357
Originally Posted by 08GRSTi View Post
+1 for the downpipe
Downpipes and Racepipes are available now! The racepipe photos are in the process of being uploaded to the site.
Just to give you guys a heads up. If you buy the Downpipe you will need to purchase the WS08-RP (2008 WRX Racepipe). It is required to connect to your factory cat-back or cat-back.
Old 06-04-2008, 12:02 PM   #14
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Nice Jermaine! Solid gains!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 06-04-2008, 03:58 PM   #15
DansSpace
Member#: 157029
'13 Mazdaspeed3
Wow. Impressive gains for just a TB and a tune.
DansSpace is offline   Reply With Quote
Old 06-04-2008, 04:07 PM   #16
Clark_Kent
Member#: 114299
Nice gains.
Clark_Kent is offline   Reply With Quote
Old 06-04-2008, 05:33 PM   #17
paikman
Member#: 43002
1990 BNR32 GTR &
2015 Evo X Final Edition
Wow, can't believe how close the stage 2 WRX's are to a stage 1 sti..not
bad at all. I dyno'd my turboXS setup over the weekend too, albeit its DP only and no real tune.
paikman is offline   Reply With Quote
Old 06-04-2008, 08:47 PM   #18
Fireball1
Member#: 151870
What city/state is your shop located in? Will these mods fit an '08 WRX sedan too? Thnx.
Fireball1 is offline   Reply With Quote
Old 06-05-2008, 08:38 AM   #19
Imprezd
Member#: 3357
TurboXS is located in Gaithersburg, MD. Unfortunately we do not have cat-back for the Sedan yet. Everything else we offer fits. But you can do what would essentially work out at as our stealthback. Which would include the Downpipe and Racepipe (WS-DP and WS08-RP) but you could keep your stock cat back. We have a few STI's and our shop Sedan running around with this setup locally as Paikman Jon states above.
08 Sedan/STI Available parts:
Downpipe - WS-DP
Racepipe - WS08-RP
ECU -Delta-003
Accessories:
Intake - WS08-CAI
Blow Off Valve - WS08-RFL
Hybrid Valve - WS08-HYB
Bypass Valve - WS08-RBV
Jermaine~
Old 06-05-2008, 10:31 AM   #20
yuekon
Member#: 181670
2008 Impreza WRX
Obsidian Black Pearl
Nicely Done! I am just beginning to think about modding my 08 WRX 5 door---any suggestions on best first steps?
yuekon is offline   Reply With Quote
Old 06-05-2008, 10:54 AM   #21
Imprezd
Member#: 3357
Honestly you can't go wrong with a Turboback or the Delta ECU Stage 1.
Old 06-05-2008, 11:40 AM   #22
mikaust
Member#: 7468
2008 Outback Limited
The car is only reving to 6500? I think you screwed up and posted one of my old dyno plots from the wagon. Those are quite impressive #'s for a stage 2, heaps of torque.
mikaust is offline   Reply With Quote
Old 06-05-2008, 12:52 PM   #23
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Trouble maker...
def
Old 06-05-2008, 01:05 PM   #24
Clark_Kent
Member#: 114299
What were the AFRs on the tuned Stage 2 map?
Old 06-05-2008, 01:31 PM   #25
Imprezd
Member#: 3357
Relatively rich in the midrange 10.8 or so and leaning out to about 11 - 11.3
Perrin Catted DP's - $369.00 / TurboXS 2008+ WRX Sedan CBE FredBeansParts Engine/Power/Exhaust 4 09-30-2009 01:37 PM
Ultimate Racing 2008 WRX CAI + Turboback Exhaust + FMIC DYNO Results Ultimate Racing Proven Power Bragging 80 07-16-2008 02:19 AM
2008 Subaru STi - AMR STAGE 1 (AMR-S1) - Track Results VIDEO!!! :) AMR Proven Power Bragging 63 06-25-2008 01:00 AM
2008 WRX Owners Likes & Dislikes ChoppedBlack54 News & Rumors 11 09-06-2007 04:33 PM
Difference Between Cobb Stage 1 & Stage 2 rudy_t2004 Engine Management & Tuning 14 02-17-2005 10:57 PM
