Old 06-03-2008, 10:38 PM   #1
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Default Combination switch acting up, just affecting one headlight?
I'm having an issue with my headlights that is somewhat different that the other combination switch issues I found when searching: sometimes the drivers side low beam goes out, but the passenger side is never affected. Typically it happens when I touch the stalk to use a turn signal, but not always. Sometimes it comes back on its own, other times I wiggle the stalk and the light returns. I have changed the bulb a number of times so I am confident that is not the issue. Usually I do hear the relays clicking away when the light goes out, similar to what other people have seen wth stalk issues.
So, my question: has anyone else had combination switch issues that only affected one low beam?
Thanks.
Snowphun is offline   Reply With Quote
Old 06-03-2008, 11:02 PM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
what year wrx do you have?
jdubya301 is offline   Reply With Quote
Old 06-04-2008, 06:09 PM   #3
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
It's a MY02.
Old 06-04-2008, 07:42 PM   #4
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
hmmm. i looked at the 02 wiring diagram, and the only separation i could find between the left and right headlights was the power supply.
it looks like each light uses it's own fuse under the hood. maybe thats where you are having a problem?
Old 06-10-2008, 03:24 PM   #5
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Thanks for the suggestion, I was surprised to see seperate fuses and relays for both headlights. I swapped both the fuse and relay side to side, unfortunately the problem continues on the left side. I'm thinking now that it is not the combo switch but something else, maybe a bad connection somewhere. The issue appears to be only with the low beam, I can switch to highs and it comes on immediately, turn the highs off and the low is still out. I'm going to reinstall my DRL module and see if the low beam goes out with just the DRL's on. I would expect it to.
Old 06-11-2008, 02:48 PM   #6
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
yeah this really stumped me.. maybe cougar4 can chime in... he is really good at the factory wiring thing.
maybe shoot him a pm
Old 06-11-2008, 10:55 PM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The cat is here and on the prowl for the next trouble. Thanks for the vote of confidence Jdubya301.
The info I am looking at shows that power to each side of the low and high beam lights share a common power source for each side. Since you state that the left side high beam has no problem this means the power at fuse 8 (left side) should be ok. There is a splice somewhere after the fuse that provides power to each of the left side lights. There may be a problem at the splice but the first suspect would have to be the connector to the low beam light. Inspect the light connector contacts for signs of damage or heating. If that is good check to see if the red/blue wire has 12 volts on it with reference to ground while the trouble is occurring. If the voltage is low then the slice needs to be checked. It may be at the fuse panel but I don't know for sure.
Old 06-12-2008, 01:51 AM   #8
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
np cougar.
Old 10-06-2008, 11:39 PM   #9
div
Member#: 131193
wrb
Did you ever find the cause of this? I am having the same problem.
div is offline   Reply With Quote
Old 10-07-2008, 07:17 AM   #10
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Yep. I had two problems: the stalk was acting up so I replaced that (about $65). The bigger issue with the left headlight was a mostly burnt out headlight harness. A replacement harness from Auto Zone fixed that. Pull the bulb and have a careful look at the plug, it may have some melted plastic and connections.
Old 10-07-2008, 06:28 PM   #11
div
Member#: 131193
wrb
I pulled my headlight out today so I could have some room to look at what was going on. The harness was fine, there was no corrosion or anything that looked melted. Checked the fuses, they were all fine as well as the relays. Went back scratching my head, put the meter back on the harness and wtf there is power? Tried the test light, worked.. Tried the bulb, it worked too, so I am dumb founded. It all works now. However in the process of diagnosing the troubles, I dropped my old bulb that I thought was bad, and is bad now, and I broke my pass side bulb. hahaha. Sooooooooo yeah, I dunno.
Headlight switch acting up hotshot172 Electrical & Lighting 9 12-19-2009 02:09 AM
WTB: Combination Switch for 04 headlights/signals whtlegacy Private 'Wanted' Classifieds 1 11-07-2008 07:31 PM
Verify bad combination switch aphexnexus Electrical & Lighting 1 09-10-2004 02:35 PM
Replacing Combination Switch/Roll Connector kmkbaritone Electrical & Lighting 2 08-20-2004 12:47 PM
Headlights acting up! cronic Electrical & Lighting 2 11-20-2003 03:47 PM
