Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 06-04-2008, 03:09 AM   #1
jamal
Member#: 71875
98 2.5GT
my wheels fit
Default Notes on Brake Interchangeability
Is interchangeability a word? I guess so since there's no squiggly red line under it. Anyhoo, while I touched on this stuff in the compiled brake information thread, I thought maybe it couldn't hurt to have it all laid out a little more clearly.
Basically, most Subaru brakes will interchange onto other Subarus. That's very convenient when you want to put bigger brakes on your non-STi Subaru without spending a lot of money. To be extra clear, almost any front caliper will bolt onto any other Subaru. The rear brakes are where things get complicated.
When talking about physically bolting the brakes up to another Subaru, there are a few things to be concerned about:
1. Wheel Clearance
2. Rotor bolt pattern
3. Caliper mounting
4. Rear parking brake diameter
#1 is pretty simple. If you're putting brembos on your 93 Impreza L, obviously the the tiny stock steelies aren't going to fit.
#2 is something you have to be concerned with when installing brembos. The 05+ STi has a 5x114.3 bolt pattern. So while you can bolt the calipers right up other cars, you'll need to use rotors drilled in 5x100, such as those on the 04 sti. The Tribeca and SVX also have a 5x114.3 bolt pattern, while all the other Subarus since 1990 or so are 5x100 (well, except the Justy).
#3 comes into play when installing STi brembos or the Subaru 2-pots in the REAR. Any FRONT caliper/bracket will bolt up to the front of any other modern Subaru (except the SVX), but in the rear there are different backing plates. The backing plate is attached to the rear spindles, and is what the calipers bolt to. There are a few different backing plates, and brakes will not interchange between them. The solution is to either switch backing plates or use an adapter bracket.
The way to divide up the backing plates is as follows:
-Drums
-Sliding 1-pot calipers
-Fixed 2-pot calipers
-new cars - 08+ impreza, 09+ forester, '10+ legacy, which do not have a backing plate.
drums
Obviously you can't bolt discs up to a drum backing plate since there's nowhere for the caliper to attach. To swap from drums you'll need to remove the brakes, press out the hub, remove the backing plates, and install disc backing plates, parking brakes (also the cables), the hubs (and likely new bearings), and then rotors and calipers. Generally it's easier to find some disc spindles and swap the whole things over.
1-pots
For the sliding calipers, almost everything used to be interchangeable. For example, a really popular and worthwhile upgrade for an older WRX is to take the caliper brackets and rotors from an 00-04 Legacy which gets you a 290mm rotor vs 266. This is called the "H6" upgrade. If you have a really old Legacy or Impreza it's also not a bad idea to upgrade to newer parts which gives you a better pad selection.
For the 08+ Impreza, the rear suspension changed significantly, and so did the rear upright and brakes. While the not-STi still uses a sliding 1-pot caliper, the spacing from where it mounts to where the rotor is changed. This means you can't really retrofit older brakes onto them. This isn't that terrible because the 08+ rotor is a fairly good size at 286mm, so you basically already have the "H6" upgrade.
2-pots
To bolt a 2-pot rear caliper to a 1-pot car, you'll need to install either the 2-pot backing plates which is the same process I mentioned for drums, or you can purchase some adapter brackets. WRXbrakes, Kartboy, and a few other places make conversion brackets to attach either the Subaru 2-pots or 04-07 Brembos to the rear of most any other Subaru. I should note that WRX 2-pot rear adapters do not work with Brembo 2-pot rear calipers even though the mounting is the same between them.
If you want to swap rear brembos for the 2-pots, or vice-versa, no bracket is required. Sti brembos will bolt right up to an 06-07 WRX, and the rear 2-pots will bolt right up to an 04-07 STi.
If, for some reason, you wanted some sliding calipers on your 2-pot car, you're out of luck. No bracket exists so you'll have to pull off the spindles and swap backing plates.
When it comes to STi Brembos, there's another little issue that arises when switching brakes and that is the rear parking brake. The STi, along with a few non-US models (and the 08+), has a larger 190mm parking brake drum (compared to 170mm on everything else). That means if you were to pick up some rear STi brembo calipers and rotors and put them on your non-sti, the parking brake wouldn't work because there's a 10mm gap between the drum and the shoes. It also means if, for rally purposes perhaps, you wanted some Subaru 2-pots on your STi, the rotors wouldn't fit over the parking brake.
Thankfully there's a solution for each situation. Subaru took care of the Brembo -> 2-pot swap because the 2-pots are (were) the group N rally-spec brakes. So they make rotors that work with the 2-pots but fit over STi parking brakes, in both 5x100 and 5x114.3. You can get them from rally shops such as Rallispec or Rocket Rally.
To make rear brembos work on a 170mm parking brake car, there are a couple of solutions. The best one is the DBA 2657 rotor. It's a brembo-sized rotor, drilled for 5x100, with a 170mm parking brake hat. This is a new thing that was produced specifically to go with the WRXBrakes Brembo adapter brackets, so be sure to thank Tom and DBASteve and Ken at WRXbrakes for getting together on that.
Before then, the solution was to either swap to a bigger parking brake, get some spacers made to fit in the rotor hat, or buy some taller parking brake shoes. Godspeed in the UK makes taller shoes, and adapter brackets. Brembo also makes adapter brackets and rotors, but I am unsure on pricing and availability on them. If you are in North America and want STi brembos, the best way to do it is with the WRXbrakes package.
Can I put front brakes on the rear?
No, as in not a chance. Don't try. Don't post a thread asking about it.
What happens to my brake bias?
If you have a 93 impreza and put on some front brembos, you might think that there would be a big increase in braking force. You would be right, and it would only be on the front wheels. That results in the front doing all the work, the rear doing nothing, and can actually increase your stopping distance. If you are swapping brakes around, take a look at this spreadsheet:
http://www.main.experiencetherave.co.../brakemath.xls
courtesy of Legacy777
Ideally you want to keep the bias where it was or go rearward a small amount (why the H6 upgrade is so popular).
a little more about new cars
For 2008, the Impreza has a whole different thing going on in the rear. While the front brakes are still the same, the rear suspension, spindles, and caliper mounting changed on regular Imprezas, the WRX, and the STi. Instead of a backing plate, the calipers mount to the spindle just like the front. Because of this, the calipers are different. The bolt spacing is actually the same as older 1-pot calipers, on both the WRX and STi.
Another thing to note is that the 08 WRX has the same larger 190mm parking brake hat as the STi.
So yes, it is possible to put 08 sti rear calipers on an 08+ wrx and it happens to be very easy. All you need is any set of front brembos, 08+ sti rear brembo calipers, and rotors drilled for 5x100. You can use 04 sti front rotors, but 04 sti rear rotors won't work and they have to be for an 08+ STi. Pretty much any machine shop will be able to re-drill the rotors for a nominal charge. What's even more convenient is that DBA dual drills their STi rotors in 5x100 and 5x114 and WRXbrakes does it in house to less expensive centric blank rotors.
This will only work with 08+ sti rear calipers and re-drilled 08+ STi rear rotors because the mounting on the calipers changed as did the rotor hat offset. If you were to attempt to use an 04 sti rotor, it would not line up with the caliper. The DBA rotor part numbers are 4654 front and 42656 rear. Anything dual drilled will have the part number end with -10. For example, DBA42656XS-10 is the dual drilled rear rotor that would be good to use for this swap.
The 09+ Forester, 2010+ Legacy, and BRZ/FT86/FRS also has the same rear upright and brake setup, so all this should apply to them as well.
If you wanted to put 08 sti rear calipers on an older 1-pot cars, they would bolt to the backing plate, but there is no rotor that will currently work. The DBA rotor would not line up with the caliper. The actual difference in offset is something I don't currently know, and I'm not sure if even an 08 sti rotor re-drilled would line up properly (parking brake issues aside). It could end up interfering with the backing plate.
Exceptions to the rules
-If you want to put smaller brakes on an 05+ STi, you can't just take a regular wrx front rotor, re-drill it, and bolt it on. The rotor hat will not fit over the hub. Subaru make special rotors to do this. On that note, out of other Subaru brakes, ONLY the 4-pots will fit with STi hubs. The caliper bracket for a 2-pot won't clear the hat on the special rotor.
-If you have an SVX, the front brakes are different and don't interchange. Rears are H-6 sized, but get that added rotor size at the upright and not from the bracket. You should be able to bolt on newer 1-pot rear brackets and calipers if you were looking for replacement parts but there isn't really an upgrade that works.
NEW: stuff about the BRZ
The BRZ uses the same rear suspension as the current Impreza/Legacy. The front brakes are standard 2-pot WRX, and the rears are from the 2010 LGT. So, putting Brembos on (something Greddy has already done), is the same as for the 08+ WRX- you take the STI caliper, redrill the rotor, and it bolts right up.
In the front, things are almost as simple. The calipers bolt to the uprights, so you would just need 04 sti rotors and any calipers. There is one extra thing you have to do though: because the calipers mount to the leading edge of the upright, the bleed screws have to be swapped to the other side of the caliper (not all that difficult). We can't just put the calipers on opposite sides because the piston sizes are staggered and you would end up with crazy uneven pad wear. And you obviously can't have the bleed screws facing down either.
jamal is offline   Reply With Quote
Old 06-04-2008, 10:17 AM   #2
DefyF8
Member#: 147175
2003 WRX
Midnight Blue
This is great information and helped me very much, thank you for taking the time for this!
DefyF8 is offline   Reply With Quote
Old 06-04-2008, 11:06 AM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Added to the supersticky.
Old 06-16-2008, 04:36 PM   #4
Zach310
Member#: 132718
2004 STI
Who do i contact to order a bracket to out the 2 pot brakes on the rear of my 2000 2.5 rs
Zach310 is offline   Reply With Quote
Old 06-24-2008, 11:49 AM   #5
Sid03SVT
Member#: 183032
2006 WRX Wagon
funny that you mentioned a 93 Impreza, cause thats what I'm driving right now; I want to put larger brakes on the front, I was hoping to source the parts used from a legacy/impreza from the heavier years so I can get a decent setup for a decent price; what am I going to need? I know I'll need calipers, brackets & rotors, but what else? thanks
currently - 242x16mm front disc, non abs; i was hoping to use the 276x24mm from the 2.5rs or 294x24mm wrx front setup; I have a set of 17" wheels so clearance won't be an issue until the winter (I run the 13" steelies with studs in the winter) but I can get my hands on 16" aluminum wheels fairly easily...
Sid03SVT is offline   Reply With Quote
Old 09-26-2008, 03:47 PM   #6
andrewt461
Member#: 70647
2004 WRX
Will '04 STi rotors have any fitment issues on an 04 wrx?
No problem w/ the hub size - both 5x100.
Problem w/ the caliper clip?
STi rotors are thicker - so this means that the regular WRX caliper+bracket wouldn't fit over it, right?
andrewt461 is offline   Reply With Quote
Old 09-26-2008, 03:56 PM   #7
MasterKwan
Member#: 98961
2003 WRX
Pretty sure STI rotors won't work with WRX brake caliper or brackets. As you point out there's an 8mm difference in width of the rotor and it's taller than the WRX rotor by a fairish amount.
STI rotors are closer to Legacy GT rotors at 30mm thick. I believe the STI rotors are about 1/2" taller than the LGT rotors even.
LGT rotors with LGT/Tribeca calipers and brackets are the hot ticket for front brakes. Just a little less capable than brembo's. It's a straight bolt on too. LGT brakes will kill the subaru 4 pots or standard 2 pot brakes. That's what I had on my car till...yesterday when I installed Brembo's.
Old 02-11-2009, 12:03 AM   #8
ianshoots
Member#: 197705
2000 OBS
Would the Legacy GT rear spindles/front set up be the best bet for my 2000 OBS (I have rear drums).
Sorry revive what might be an old thread.
ianshoots is offline   Reply With Quote
Old 03-19-2009, 11:05 PM   #9
ed10
Member#: 198026
2002 Impreza WRX
Nulla Tenaci Invia EstVia
does anybody know if the 06 wrx brakes will fit my 02??? of course the 06 comes with 4 pot at the front and 2 pot at the back....let me know PM me!!!
ed10 is offline   Reply With Quote
Old 03-19-2009, 11:15 PM   #10
Butt Dyno
Member#: 17301
is the "dark side"
Search. Seriously. You are not trying.
Old 03-20-2009, 11:35 AM   #11
ed10
Member#: 198026
2002 Impreza WRX
you're exactly right I'm not....so if you know it just tell me don't waste your time replying with a smart ass comment
Old 03-20-2009, 11:47 AM   #12
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
vvvvv
Basically, most Subaru brakes will interchange onto other Subarus. That's very convenient when you want to put bigger brakes on your non-STi Subaru without spending a lot of money. But, when talking about physically bolting the brakes up to another Subaru, there are a few things to be concerned about:
1. Wheel Clearance
3. Caliper mounting
#2 is something you have to be concerned with when installing brembos. The 05+ STi has a 5x114.3 bolt pattern. So while you can bolt the calipers right up other cars, you'll need to use rotors drilled in 5x100, such as those on the 04 sti. The Tribeca and SVX also have a 5x114.3 bolt pattern, while all the other Subarus since 1990 or so are 5x100 (well, except the Justy and Loyale).
-Drums
-08+ Imprezas (no backing plate)
Obviously you can't bolt discs up to a drum backing plate since there's nowhere for the caliper to attach. To swap from drums you'll need to remove the brakes, remove the backing plates, and install disc backing plates , parking brakes (also the cables) and then rotors and calipers. Generally it's easier to find some disc spindles and swap the whole things over.
For the sliding calipers, almost everything is interchangeable. That includes everything from a 1990 Legacy to Imprezas and Tribecas and even the SVX (although bolt patterns may vary).
To bolt a 2-pot rear caliper to a 1-pot car, you'll need to install either the 2-pot backing plates, which involves removing the parking brake, entire spindle, and using a press, or you can purchase some adapter brackets. WRXbrakes manufactures brackets to attach either the Subaru 2-pots or 04-07 Brembos to the rear of any other Subaru. Also if you need to buy other brake stuff you should totally check that place out.
For 2008, the Impreza has a whole different thing going on in the rear. While nothing changed with the front brakes, the rear suspension, spindles, and caliper mounting changed on regular Imprezas, the WRX, and the STi. Instead of a backing plate, the 08s have holes drilled in the spindle just like the front, and the bolt spacing is different. Whether or not that bolt spacing is the same as anything else is something I haven't figured out yet, but I wouldn't be surprised if some things are interchangeable.
When it comes to STi Brembos, there's another little issue that arises when switching brakes and that is the rear parking brake. The STi, along with a few non-US models, has a larger 190mm parking brake drum (compared to 170mm on everything else). That means if you were to pick up some rear STi brembo calipers and rotors and put them on your non-sti, the parking brake wouldn't work because there's a 10mm gap between the drum and the shoes. It also means if, for rally purposes perhaps, you wanted some Subaru 2-pots on your STi, the rotors wouldn't fit over the parking brake.
To make rear brembos work on a 170mm parking brake car, there are a couple of solutions. The best one is the DBA 2657 rotor. It's a brembo-sized rotor, drilled for 5x100, with a 170mm parking brake hat. This is a new thing that was produced specifically to go with the Kartboy Brembo adapter brackets, so be sure to thank Tom and DBASteve and Ken at WRXbrakes for getting together on that. As an update to that, WRXbrakes has taken over the brackets, so if you need some he's the guy to talk to.
Okay, well, I think that covers it.
UkNuck is offline   Reply With Quote
Old 03-20-2009, 04:26 PM   #13
Butt Dyno
Member#: 17301
is the "dark side"
You're too nice.
Old 03-25-2009, 02:36 PM   #14
bluebuick
Member#: 169465
04 wrx
if i buy all the calipers off a 06 sti, besides 5x100 rotors what else do i need as far as geting them to bolt up to my 04 wrx i know about the parking brake but how do they bolt up will the stock caliper "bracket" hold the new ones.
please PM me.
bluebuick is offline   Reply With Quote
Old 03-25-2009, 03:02 PM   #15
rougeben83
Member#: 115154
2005 Outback XT
White on grey
huuuuurrrr
1. Wheel Clearance
3. Caliper mounting
-Drums
rougeben83 is offline   Reply With Quote
Old 03-27-2009, 05:01 PM   #16
ki11switch
Member#: 176422
so just to make it clear. i have 04 brambos pads and rotors going on my 06 wrx. Everything is straight swap over since i am 06? including the ebrake?
ki11switch is offline   Reply With Quote
Old 03-27-2009, 07:06 PM   #17
jamal
Member#: 71875
98 2.5GT
my wheels fit
Oh, so I took a closer look at the rear of an 08 sti today and compared it to a 1-pot rear caliper bracket I have. The bolt holes have the same spacing so it's looking like it might be possible to just bolt an 08 sti brembo right up to the rear of an older 1-pot car. Not sure if the radial spacing and rotor hat offset are the same but I would expect them to be.
Old 04-30-2009, 07:41 AM   #18
STIJDM
Member#: 209711
Thanks for the effort you put into this thread, I read thru, there is no info about 2000 STI with original subaru calipers. I own a JDM STI V7 wagon, the brakes are not brembo, I dont know why. I want to get V8 brembo kit for it. Can I fit it into my ride? BTW, my front rotor size is 24 x 294mm, rear is 10 x 266mm. Thanks.
STIJDM is offline   Reply With Quote
Old 04-30-2009, 07:53 AM   #19
jamal
Member#: 71875
98 2.5GT
my wheels fit
The sti wagons didn't get brembos. But the rules listed above still apply. Sure your rear rotors are 266x10? I'd expect you to have the subaru 4/2-pots.
Old 04-30-2009, 10:38 PM   #20
STIJDM
Member#: 209711
You r right, I think I got it wrong, should be 4/2 pots calipers. My rear caliper is shown in pic below.
It should be 2 pots, right?
Old 05-04-2009, 12:54 PM   #21
subiecoupe
Member#: 208320
im trying to buy a wilwood brake kit for my 98rs, the kit is for an 03 wrx, and i was pretty sure that they are direct swap correct? just curious if i would need anything other than the rotors, calipers, pads, and brake lines. such as new mounting brackets or e-brake for rear? Also would I be able to fit these under the stock 2.5rs rims? I tried searching with no definitive results......any help greatly appreciated.( The kit is 4pot front and rears)
subiecoupe is offline   Reply With Quote
Old 05-05-2009, 02:28 AM   #22
obyone
Member#: 16523
this anymore???
Those are the brakes I was supposed to get.
I ordered the big brake kit from subaruparts.com for my 00 RS and specifically requested 4 fronts and 2 rears. Instead, I got the 4 fronts and sliders in the back. By the time I made it back in town, my shop had the car all put together and I needed a car.
/rant
obyone is offline   Reply With Quote
Old 07-15-2009, 07:18 PM   #23
dzrt_hrd
Member#: 180395
2008 Impreza 2.5i
Red
Ok I'm confused now. I'm trying to find the way to convert my rear drums to discs and I'd like to use stock WRX brakes. This idea came up in a few other threads I found, and the responses were that I needed the discs, calipers, brackets, e-brake cables, and the hub assembly. But I also found this page (which I understand is for a different year than mine):
http://offroadingsubarus.com/rear_disc_conversion.html
that says all I'd need is the backing plate, not the hub assembly.
Now if the 08s don't have a backing plate, then what do I need? The spindle? Would that require buying less parts than the hub assembly (they're not one and the same are they)?
There's finally an 08 Wagon in the part-out section right now, but if there are only a few parts I need that I can get from the dealership (like the caliper brackets) then I'll just do that. So if somebody could help me understand asap I'd really appreciate it.
dzrt_hrd is offline   Reply With Quote
Old 07-15-2009, 09:55 PM   #24
jamal
Member#: 71875
98 2.5GT
my wheels fit
the spindle/upright/knuckle is the big cast piece that all the suspension links bolt to. The hub is the part that the wheel actually bolts to. And of course there's a wheel bearing and axle in there too.
To put rear discs on your 08, I would expect you need to swap the uprights entirely. I haven't been under a rear drum 08 but I'm assuming that it doesn't have the provisions to bolt up a caliper.
Old 07-15-2009, 10:33 PM   #25
dzrt_hrd
Member#: 180395
2008 Impreza 2.5i
Red
I haven't looked back to see if the mounting holes and what not are there, but would you say I'm better off getting the uprights from the dealership or off a part-out?
Thanks BTW.
so how about brake interchange? nubs1094 Legacy Forum 38 01-20-2010 05:43 PM
Need help on seats interchangeability bangedlegacywagon97 Newbies & FAQs 2 06-24-2009 12:28 AM
brake interchangability?? fred6870 Brakes, Steering & Suspension 2 08-13-2008 01:42 AM
Info on Suby brake interchangability my4isflat Brakes, Steering & Suspension 3 11-02-2006 11:00 PM
Are front and rear springs on MY98 interchangeable? eric@montreal Brakes, Steering & Suspension 0 07-21-2002 10:16 AM
