Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 06-04-2008, 02:29 AM   #1
rice_balls
Member#: 70784
2004 Impreza WRX
Default Headlight assembly adjustment
Hi I am not sure if the adjustment is the same as previously posted adjustments for headlights but here it goes....
I have an 04 wrx and the headlight assembly is sitting in a way that there is a gap between the outer bottom corner of the light assembly and the fender where it sits. As far as i know the rubber seal on the assembly should be sitting against the fender cutout where the headlight should be seating but it isn't. There is probably less than a 1/4 in gap. Is there a way to adjust this so it seats properly or do i just have to live with it?
Thanks!
rice_balls is offline   Reply With Quote
Old 06-04-2008, 09:04 AM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Yes, this happened to me when i did my TSX retro fit.
there are two pins that are held into the fender with the rubber condom looking things, one is yellow and one is white i believe. i ended up having to eboxy my condem things in the fender since they kept falling out, but that should take care of it for ya.
You could also try pushing with some gentely, but forcefully at that bottom corner, that worked for me, for like 30 seconds than it would pop back out.
Any other q's just pm me.
skingfreak is offline   Reply With Quote
Old 06-04-2008, 01:56 PM   #3
rice_balls
Member#: 70784
2004 Impreza WRX
I'm kind of having a hard time visualizing it but ill take a look when i get off work. Thanks for your input
WTB: PS Headlight Assembly sovereignmk1 Legacy Forum 0 01-26-2002 08:07 AM
headlight assembly part number slide Legacy Forum 2 01-21-2002 11:58 PM
Blueish reflectors within headlight assembly...what is it? JasonRan Interior & Exterior Modification 3 01-16-2002 10:24 AM
Anyone want to sell me their 00-01 headlight assembly L/R Rallyspec North West Impreza Club Forum -- NWIC 3 06-30-2001 11:59 AM
