Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 06-04-2008, 07:37 AM   #1
Spun Autosports
Vendor Sales Rating: (147)
Member#: 104686
2005 WRX
www.Spun-Autosports.com
Default Spec Clutches Instock Ready to Ship----Tons Of Kartboy Short Shifters and Bushings!
Cusco LSD's
Cusco 1 Way Front LSD 02-07 WRX/STI (PM For Price)
Cusco 1.5 Way Front LSD 02-07 WRX/STI (PM For Price)
Cusco 1.5 Way Rear LSD 02-07 WRX/STI (PM For Price)
Cusco 2 Way Rear LSD 02-07 WRX/STI (PM For Price)
Cusco Tarmac Gear 5 speed WRX Only(PM For Price)
Not Sure What LSD you need? Read Here!!
The 1-way Type RS utilizes coil springs located between the pressure rings to develop initial torque and features full engagement only during acceleration.
The 1.5-way Type RS utilizes coil springs located between the pressure rings to develop initial torque and features full engagement during acceleration and partially under deceleration.
The 2-way Type RS utilizes coil springs located between the pressure rings to develop initial torque and features full engagement during acceleration and deceleration.
Tarmac Gear This center differential is amazing. Offering a 35/65, front/rear split, this will help get you down the tarmac track faster and more reliably.
Kartboy Short Shifter Kits
Shifter 5 Speed WRX (PM For Prices)
Shifter 6 Speed STI (PM For Prices)
Shifter and Front and Rear Bushing Combo 5 speed WRX (PM For Prices)
Shifter and Front and Rear Bushing Combo 6 Speed WRX (PM For Prices)
5 speed WRX Shift Knob/Short Shifter/Front and Rear Bushings (PM For Prices)
6 Speed STI Shift Knob/Short Shifter/Front and Rear Bushings (PM For Prices)
Spec Clutches and Flywheels
Stage 1
Types of Driving: Street, Drag, Drift, Road Race, Rallye, Pulling, Autocross
For bolt on naturally aspirated and mildly modified forced induction engines. Stock-like daily drivability and very good wear characteristics.
High clamp pressure plate, steel-backed and multi-compound woven organic material and high torque sprung hub and disc assembly, bearing and tool kit.
Spec Clutch Kit Stage 1 (PM For Price)
Stage 2
Types of Driving: Street, Drag, Pulling, Autocross
For all mild to moderately modified naturally aspirated and power adder engines. (Also good for stock power levels and spririted driving when good daily drivability and extremely long life are the goal.) Stock-like daily drivability and EXCELLENT wear characteristics.
High clamp pressure plate, pure Kevlar friction material and high torque sprung hub and disc assembly, bearing and tool kit.
Spec Clutch Kit Stage 2 (PM For Price)
Stage 2+
Types of Driving: Street, Drag, Road Race, Rallye, Pulling, Autocross
For all modified engines making more torque than the stage 2 can support. Maintains stage 2 feel for good daily drivability and offers very good wear characteristics, but provides a higher torque capacity. High clamp pressure plate, composite multi-friction carbon-kevlar material, high torque sprung hub and disc assembly, bearing and tool kit.
Spec Clutch Kit Stage 2+ (PM For Price)
Spec Flywheel
The automotive component most responsible for insuring optimum clutch performance and life is the flywheel. The flywheel's contribution to power transfer is three-fold.
Firstly, the flywheel should provide a consistent and friction enhancing surface for the clutch disc.
Flywheels also aid in proper inertia, which is determined by the flywheel weight. Inertia controls the ratio of power to acceleration and can make a vehicle faster or slower based on gear ratio, tire type, vehicle weight, power output and even the location in the powerband output is achieved. The weight of a flywheel and amount of inertia it provides can also effect drivability.
Lastly, the flywheel must provide a true balance at rpm, which means no dimensional runout that produces engine damaging and power robbing vibrations and allows smooth engine revolutions.
SPEC flywheels are CNC manufactured at an unheard-of .001 tolerance, in an industry where the standard is .010. This precision manufacturing process ensures perfect balance and a perfectly flat bedding surface for the clutch disc, both of which also contribute to the ultimate in safety for competitive environments. All SPEC flywheels carry SFI certification. (sfi link)
To allow for specific inertia needs, SPEC flywheels are made in high carbon billet steel and aircraft quality billet aluminum. The aluminum and most steel SPEC units are rebuildable and feature a replaceable steel friction plate that is made from a friction- enhancing steel metal specially formulated for optimum clutch bedding and holding power. The aluminum and steel materials provide a light and medium weight option for all types of racing. SPEC spends a lot of time and effort on research and development of optimum flywheel dimensions and weights for all types of driving and racing and can optimize your MOI (moment of inertia) to maximize your car's output and performance.
Spec Flywheel (PM For Price)
Tom
412-760-2127
__________________
Email:
Phone: 412-760-2127
Visa-Mastercard-Discover-American Express
Spun Autosports is online now
Old 06-05-2008, 06:53 AM   #2
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-05-2008, 02:26 PM   #3
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-06-2008, 07:29 AM   #4
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-06-2008, 02:55 PM   #5
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-07-2008, 08:00 AM   #6
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-08-2008, 08:27 AM   #7
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-09-2008, 06:44 AM   #8
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-10-2008, 08:15 AM   #9
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-10-2008, 06:35 PM   #10
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-11-2008, 08:17 AM   #11
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-12-2008, 07:34 AM   #12
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-12-2008, 03:48 PM   #13
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-13-2008, 07:31 AM   #14
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-14-2008, 08:17 AM   #15
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-15-2008, 06:02 AM   #16
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-16-2008, 07:51 AM   #17
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-16-2008, 03:22 PM   #18
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-17-2008, 08:36 AM   #19
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-17-2008, 02:41 PM   #20
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-18-2008, 08:16 AM   #21
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-19-2008, 07:13 AM   #22
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-19-2008, 06:06 PM   #23
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-20-2008, 07:11 AM   #24
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Old 06-21-2008, 07:23 AM   #25
Spun Autosports
Member#: 104686
2005 WRX
Bump!
__________________
Email:
Phone: 412-760-2127
Closed Thread
Kartboy Short Shifter and Bushing Combo--Kartboy Shift Knobs--Spec Clutches Spun Autosports Drivetrain 13 12-07-2008 08:53 AM
Kartboy Short Shifter and Bushing Combos| Spec Clutches|Cusco LSD's| Kartboy Knobs| Spun Autosports Drivetrain 93 05-03-2008 05:36 AM
KARTBOY KARTBOY KARTBOY! Short Shifters and Bushings! FREE Shipping & Tons of Stock! Spun Autosports Drivetrain 34 10-23-2007 10:55 PM
KARTBOY KARTBOY KARTBOY! Short Shifters and Bushings! FREE Shipping & Tons of Stock! Turn in Concepts Drivetrain 3 10-20-2007 10:10 AM
Kartboy Short Shifter and Bushing Madness*Tons of Cusco Clutches in Stock!!!! Spun Autosports Drivetrain 60 02-24-2007 08:00 AM
Message Board Statistics All times are GMT -4. The time now is 01:18 PM.
