Old 06-04-2008, 01:08 PM   #1
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Default Wiring gauges, connecting wires, question
I am going to be installing my prosport boost and oil pres this weekend. My question is when your connecting the end of a wire to the middle of another wire, what is the best way to do this? Is there a special way of doing this?
Thanks
Ryan
shamrock 05 is offline   Reply With Quote
Old 06-04-2008, 06:00 PM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
The best way is to cut the wire and solder all three ends together, or you could cut and crimp which isnt as good but still works.
ProdriveDreams is offline   Reply With Quote
Old 06-04-2008, 07:57 PM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
cut off about 1/4 inch of the insulation using a razor blade.
solder the new wire on, wrap with elect tape. if you can get heat shrink onto the main wire, do it, the use it to re-insulate your connection
jdubya301 is offline   Reply With Quote
Old 06-05-2008, 10:39 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You can also use a tap crimp connector. 3M makes them and you can get them at a auto store usually.
Old 06-06-2008, 07:10 AM   #5
shamrock 05
Member#: 120057
^^^^Ill look into those
Old 06-06-2008, 04:19 PM   #6
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
theyre usually blue. u can get em at any parts store
**Prosport gauge wiring, need exact wires** shamrock 05 Interior & Exterior Modification 10 08-04-2011 11:13 AM
newb gauge light wiring question chen Electrical & Lighting 7 09-15-2007 03:34 PM
FS: $200 - Full set of 6 (52mm) Gauges with sensors and quick connect wiring harness cah Interior/Dressup/Audio & Security 3 03-26-2007 08:49 PM
'02 WRX fog light wiring Qs...wire gauge, amperage, etc... andygold Electrical & Lighting 2 01-25-2005 09:56 PM
1999 2.5rs gauge cluster wire question. Need color for tech signal... psyber_0ptix Electrical & Lighting 8 11-19-2004 05:02 PM
