Notices
Old 06-04-2008, 04:10 PM   #1
sureshot007
Member#: 142405
#716 G2 OBS
Default replaced oil pump, now won't start
2002 WRX Wagon, 5sp, 130k miles:
I had to replace the oil pump, and now it won't start. It turns over. A couple of times it sputtered like it was going to start, but nothing. I over filled it with oil (Maybe 2 quarts?), but I have drained out the extra. I triple checked the timing marks when I put the belt on, and before I put the covers on.
And before someone asks, it has gas.
I have no idea at this point. Anybody?
sureshot007 is offline   Reply With Quote
Old 06-05-2008, 02:31 PM   #2
azscooby
Member#: 115297
2002 ej207 vf34
Not an expert, but I've read enough to tell you "Sounds like a timing" issue.
Did you make sure you "Wound" up the cam sprockets when you put the belt on? I did my belt a little different, so I wouldn't have to reset the cams. Might want to double check it.
I don't see why overfilling it would cause any problems. I think the problem lies in timing.
Just my $.02
azscooby is offline   Reply With Quote
Old 06-05-2008, 02:40 PM   #3
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
id agree with the timing issue
Whats the "wound" up thing your talking about im about to do my timing on my engine and like a little insite on that...
03WRX-WRB is offline   Reply With Quote
Old 06-05-2008, 02:44 PM   #4
sureshot007
Member#: 142405
#716 G2 OBS
I read in another thread that if you are missing a tooth on the crank sprocket, it won't start - and it just so happens that I think I broke one tooth off. I am going to try replacing that ($15 part) and see what happens.
Old 06-05-2008, 05:38 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
how did you possibly break a tooth off???
sidewayz is offline   Reply With Quote
Old 06-05-2008, 06:17 PM   #6
sureshot007
Member#: 142405
#716 G2 OBS
I was being dumb (go figure), and I used a pry bar to get the gear off. I pried in just the right way that it bent the tooth a little, and when I tried to bend it back, it snapped right off.
Just in case there is any confusion, I am talking about the little teeth around the outside for the crank angle sensor.
Old 06-06-2008, 03:35 PM   #7
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
That can do it if you broke one of the teeth.
Since now your crank sensor isn't seeing all the teeth, it won't start. The sputtering start-up is probably the ECU picking up some of the signal, but then dropping since the signal is missing momentarily. Thus, you never have a complete start up.
When you replace it, recheck your timing belt marks.
Pakin is offline   Reply With Quote
Subura died and now won't start 3maxman Normally Aspirated Powertrain 10 01-06-2008 01:40 AM
New injectors/turbo, now won't start. Rickyh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-01-2008 03:25 PM
Engine back in, now won't start grizz3000 Engine Management & Tuning 4 08-27-2007 09:39 PM
car ran fine; now won't start nate242 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-01-2007 04:21 PM
Installed new fuel pump--now won't start!! Help! PDG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 12-03-2001 07:55 AM
