Old 06-04-2008, 07:17 PM   #1
madmax02
Member#: 152891
Default Installing an STI gauge cluster in an 02 WRX
I was looking to possibly switch out my stock cluster and get one from an STI as I like the look of that one better. I was wondering if its plug and play at all and if not what is needed in order to install it properly. Will the actual mileage on my car still read on the STI cluster or will it display the mileage that was on the STI cluster before it was removed? Is it able to be programmed or anything at all? I haven't had a chance to look into it that much yet and I'm still fairly new here and I haven't bought the part yet so I wanted to look and see what was invloved first so that if I do get it done - I can do it right the first time around - Any and all info would be greatly appreciated, Thanks!
madmax02 is offline   Reply With Quote
Old 06-04-2008, 08:36 PM   #2
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
you need the 2004 sti cluster and you have to clip one wire. look for the diy.
ownnij is offline   Reply With Quote
Old 06-04-2008, 08:52 PM   #3
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
do a quick search, i just read a diy for a 05 cluster in a 02 wrx. It was very informative and on my todo list after my warranty expires lol.
Noeladams is offline   Reply With Quote
Old 06-04-2008, 09:09 PM   #4
tonecold
Member#: 37476
MY02 WRX Stage 2
PSM (215whp/223wtq)
2004 is the easiest to install, clip one wire, done.
I did 2006 into my 02 bugeye, and my ILLumination can not be controlled.
Anyone know the difference between the 04,05,06,and 07 STi clusters?
Are they all the same in cosmetics, functionality?
tonecold is offline   Reply With Quote
Old 06-04-2008, 09:44 PM   #5
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
sc00ter is offline   Reply With Quote
Old 06-04-2008, 10:51 PM   #6
tonecold
Member#: 37476
MY02 WRX Stage 2
PSM (215whp/223wtq)
Old 06-04-2008, 10:57 PM   #7
jfdavis22885
Member#: 145716
08 Lexus IS 350
05 WRB WRX Stg2 (Sold)
the tac placement changed in 05 otherwise i have no clue
jfdavis22885 is offline   Reply With Quote
Old 06-05-2008, 02:30 AM   #8
tonecold
Member#: 37476
MY02 WRX Stage 2
PSM (215whp/223wtq)
^^^^What do you mean the tac changed in 05?
Even on the 04, the tac is in the center???
Old 06-05-2008, 06:29 AM   #9
madmax02
Member#: 152891
Thanks for the info guys! So if everything else is done right - one of the only other things that wouldn't work on my 02 WRX would be the outside temp thing correct? Or is there a way to get it to work? Not that its a big deal or anything - just thought I'd ask.
Old 06-05-2008, 10:20 AM   #10
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
The outside temp gauge won't work because you don't have the sensor for it. However, I have heard that you can get that sensor off an STI.
Someone correct me if I'm wrong.
Old 06-05-2008, 10:58 AM   #11
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
Nope, you can. I think subarugenuineparts has the sensor for sale.
RallyIt07 is offline   Reply With Quote
Old 06-05-2008, 11:04 AM   #12
WRXGuyInUSA
Member#: 13967
Bye Bye STI!!!
Also... the mileage STAYS with the cluster...
So your car will now read the new mileage, that was on the STI you got the cluster from. If you don't report it, it's fraud... not a good thing to have a car with an odometer discrepancy.
I think some dealers can change the mileage on the new cluster, but it would have to be done through them, and documented.
WRXGuyInUSA is offline   Reply With Quote
Old 06-05-2008, 11:09 AM   #13
sc00ter
Member#: 117767
2015 WRX
3" TBE/AP/e85
Yes, this is right. The mileage on the cluster will read whatever the original STI had on it.
However, the dealer will NOT change the mileage on the cluster for you. You can send it to a place called Tacoma Speedometer and they will change it for you and give you the documents necessary to prove legality. I think they make you take a pic of the mileage of your stock cluster while plugged into your car and send it in with the STI cluster as well.
Site:
http://www.tacomaspeedometer.com/index/
Old 06-05-2008, 12:06 PM   #14
Sooksook
Scooby Scammer- Do Not Buy From User
Member#: 156254
'03 GDA
Too Low for Nabisco Blue
Or alternatively, get a cluster that has more mileage and wait til you catch up before you install it amazingly out of pure coincidence, the V7 cluster I bought was over by only 500 km.
Sooksook is offline   Reply With Quote
Old 06-05-2008, 01:40 PM   #15
tonecold
Member#: 37476
MY02 WRX Stage 2
PSM (215whp/223wtq)
Well...I've been wanting the damn outside temp to work as well, but I've never heard a success story.
There is a write up on ScoobyMods, but no one on NASIOC has confirmed it works to my knowledge.
Old 06-05-2008, 09:34 PM   #16
madmax02
Member#: 152891
I have read/been told that the 04 STI cluster is easier to install in the WRX but then a friend told me that its probably the 05 STI cluster that I want as it lights up differently then the 04. Can anyone comfirm this? Are they 2 different colors? I was told that the 05 STI cluster is/looks similiar to the bf defi gauges which is kind of the look that I'm looking for.
Old 06-06-2008, 04:17 PM   #17
chesthair
Member#: 142252
It does work. follow this to a "t" and you should be good to go.
http://www.scoobymods.com/forums/showthread.php?t=3309
** one thing to realize, the regulator is orientated so be sure to figure that out before you solder.
Ian
chesthair is offline   Reply With Quote
Old 06-09-2008, 11:28 PM   #18
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
"Now its 06LEGGY4LIFE"
i swapped an 05 cluster into mine and everything works great! other than the outside temp and the dccd and rear diff temp. lol. but thats cuz i dont have those sensors! lol. but the illumination and shift light work and thats all that matters!! and it looks 34536564 times better!
02REX4LIFE is offline   Reply With Quote
Old 06-10-2008, 12:48 AM   #19
vecdran
Member#: 162932
Does the shift light and beeper still work when swapped? Or is that dependent on the STi ECU.
vecdran is offline   Reply With Quote
Old 06-10-2008, 02:23 AM   #20
tonecold
Member#: 37476
MY02 WRX Stage 2
PSM (215whp/223wtq)
Yes, the shift light and buzzer work when swapped.
My 06STi illumination feature doesn't work on my 02 bugeye...
Whenever I push on the right knob, it cycles between "A" and "B", but I don't see "ILL"....
Anyone know why?
Do all the 06/07 do that?
Old 06-10-2008, 11:47 AM   #21
vecdran
Member#: 162932
Excellent, that's one of the features I was unsure about, and am very interested in.
Old 06-10-2008, 12:18 PM   #22
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
Ian
The regulator is orientated... meaning what? lol
Old 06-10-2008, 12:19 PM   #23
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
Anyone know why?
Yeah, they do not have that option on the new models. I guess it is really pointless too, but really sweet to have.
Old 06-10-2008, 12:45 PM   #24
chesthair
Member#: 142252
sorry, meaning there is an input and a output. if those are switched, your circuit won't work. -Ian
Old 06-10-2008, 01:33 PM   #25
RallyIt07
Member#: 158498
07 WRX w/ JDM 6spd
ah I get it. Yeah, so you got yours working? What happen if you have the OAT already?
04 Sti Gauge Cluster In My 02 Wrx HOOGUNZO Subaru Conversions 2 07-16-2008 04:32 AM
06 sti gauge cluster in an 02 wrx lovemyrex Electrical & Lighting 2 10-18-2007 11:32 PM
sti gauge cluster in an 02 wrx? michaelpatrick Electrical & Lighting 0 05-10-2006 12:35 PM
STI Gauge Cluster in an 02-03 WRX MarylandEcstasy Interior & Exterior Modification 9 01-20-2006 11:23 PM
STi gauge cluster in an 01' 2.5RS install help needed RyansJDMgc8 Subaru Conversions 4 07-07-2004 02:03 AM
