Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 06-05-2008, 12:46 PM   #1
ScoobyMods.com
Vendor Sales Rating: (6)
Member#: 23928
1996 STi 555 RHD
Default JIC FLT-TAR Coilovers 08 WRX/STi /KSport GT Pro Coilovers! 02+ WRX/STi/Tein S-Tech's!
Kastle's Korner has just received stock on the new FLT-TAR Coilover system
for the 2008 WRX/STi models.
JIC FLT-TAR Coilovers 08 WRX/STi (GRB)
The JIC FLT-TAR is the flagship coilover system. All FLT-TAR coilovers are
designed on US-spec vehicles for US streets, fitment and performance is
unmatched. Included in the kits are pillow ball upper mounts with adjustable
camber plates. For flexibility, the dampers have 15-way compression and
rebound adjustability. The spring rates are of the linear-rate type with
independent ride height adjustable lower brackets. This allows adjustment
without compromising damper compression or rebound travel. Based off of
racing technology, the FLT-TAR is a street performance suspension,
customizable for full time track use. NOTE: some applications may come with
a rubber bushing upper mount. A Pillow Ball upper mount may be substituted
for additional cost and with no warranty.
The spring rates are as follows;
Front: 7kg
Rear: 5kg
Overall the true beauty of this coilover system is without a doubt, the build quality. This is a system that is superior to most simply for the fact, that you'll be able to significantly increase your handling capability and take your driving experience to the next level. Simply put, these coilovers are some of the best bar none. Take it from me personally, as I've recently equipped one of my personal friend's WRX's with these, and they're great! JIC really did an amazing job.
The response, feel and experience is what these are all about...
PM for the best pricing!
Feel free to check them out on our site
We're also running specials on the K-Sport GT-Pro Systems for the 02-04 WRX/STi, as well as the 05+ WRX/STi GT-Pro Systems!
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring its inverted monotube design, 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and braking system reducing heat transfer This design also reduces under-sprung weight, which improves handeling and responsiveness.
36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
Key Features:
-Inverted steel shock absorber for durability
-Lower center of gravity and higher chassis rigidity
-Designed to reduce friction for cooler shock oil temperature
-Inverted design like vehicles in WRC and all JGTC cars
-36-way adjustable dampening
-Made from high quality 6061 Aluminum with T6 for increased hardness
-Compression/Rebound adjustable
-Adjustable spring perch for height adjustment
-Adjustable body allowing maximum suspension travel
-Pillow Ball Top Mount w/ adjustable camber (not available for some models)
-Monotube High Pressure Design reduces oil leakage
-Electroplated body for protection from corrosion and rust
-One Year Limited Warranty
Incl. Front & Rear Pillow Ball Mount / Front & Rear Inverted Tube
$1345.00 SHIPPED!
You can view the coilovers on our site here
For those looking for springs, we haven't forgotten about you. We're featuring the Tein S-Tech Spring set up for your 02-03, 04 or 05-07 WRX/STi!
TEIN S.Tech Springs are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
Additional Features:
- Chrome Vanadium SAE9254V Construction
- Progressive Spring Rate Design
- Includes Silencer Rubber on certain applications
- Green Powder Coat Finish
- Developed to be used in conjunction with OEM or OEM replacement dampers
- 1-year Manufacturers Defect and Sag Warranty (Covers over 5mm sag, breakage, deformity, and noise. Does not cover powder coat finish and rusting.)
Contents of Spring Kit:
- Individual Springs x 4
- Main Spring x 4
- Some applications include TEIN Silencer Rubbers
- Warranty Information and Bump Stop Reference Guide
- 2 TEIN Decals
Ride Height:
Front: -1.73"
Rear: -1.26"
Spring Rate:
Front: 250 lbs/in
Rear: 220 lbs/in
02-03 $220.00 SHIPPED!
2004 $220.00 SHIPPED!
05-07 $230 SHIPPED!
PM for any Legacy/Forester Inquiries! Visit Kastleskorner.com for any of your suby needs!
ScoobyMods.com is offline
Old 06-05-2008, 07:36 PM   #2
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
afternoon bump!
Old 06-06-2008, 03:42 PM   #3
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump it up!
Old 06-09-2008, 12:00 PM   #4
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump!
Old 06-09-2008, 07:58 PM   #5
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump for Monday
Old 06-09-2008, 08:31 PM   #6
Stubaru
Member Sales Rating: (8)
Member#: 2073
07 Volvo S60R
Cthulhu Gray
PM me a price for tein SS coilovers with pillowball mounts to 06026 for an 04 Sti.
Thanks,
Stu
Stubaru is offline
Old 06-10-2008, 06:41 PM   #7
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
All PM's answered!
Old 06-13-2008, 12:09 PM   #8
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Bump for Friday.
Old 06-15-2008, 04:17 PM   #9
kos
Member Sales Rating: (36)
Member#: 118334
2005 AW RS + 2006
Time Attack WRX
bump for a local vendor
kos is offline
Old 06-16-2008, 12:30 PM   #10
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Thanks kos! Monday is here!
Old 06-16-2008, 08:25 PM   #11
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
Bump bump
Old 06-17-2008, 12:19 PM   #12
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump!
Old 06-18-2008, 04:16 PM   #13
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump bump
Old 06-19-2008, 12:27 PM   #14
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
top o' the mornin' bump!
Old 06-20-2008, 01:11 PM   #15
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
PM for great pricing!
Old 06-23-2008, 12:35 PM   #16
ScoobyMods.com
Member#: 23928
1996 STi 555 RHD
bump it up..
Closed Thread
Ksport GT PRO Coilovers Fpr 05-07 WRX/STi arfrce Suspension/Brakes/Handling 52 01-28-2008 01:35 AM
05+ STi Ksport GT Pro Coilovers MaxD Suspension/Brakes/Handling 21 09-24-2007 11:55 AM
FS: 02-04 KSport GT Pro Coilovers, SSAC Top Mount, Stock STI DP bpwatts TXIC Private Classifieds 7 01-30-2007 07:03 PM
Ksport Gt Pro Coilovers 05 sti narenji Car Part Reviews 1 12-16-2006 10:20 AM
