Notices
Old 06-05-2008, 12:59 PM   #1
dougb76
Member#: 160340
2009 wrx 5 door
RIP
Default electrical system problem 06 wrx
This is a long shot, but let's see if anyone has any ideas.
Bought the car (06 wrx tr) about 6 months ago, in that time it has died electrically three times now (more below). The alternator was replaced under warranty the first time. The second time, it sat at the shop and they thought the alt. was dead again, then magically it came back. Don't know the verdict this time yet.
Mods: Cobb AP v1, xtreme xenon HID kit (grounded, checked that already), prosport electronic boost gauge, crappy panisonic cd player.... everything else is purely mechanical.
Symptoms: Slow or hesitant to start at times, it will idle ok, but then when I start driving, the power fluctuates rapidly to the dash lights, boost gauge, cd player, etc. to the point that they will turn off and back on again, and the dash lights flicker. The car even feels jerky, as if it's loosing ignition power. This goes away after 20-30 sec of driving.
Also, if I run the ac/defrost, when the ac cycles on, the dash lights flicker dramatically whether at idle or driving.
Most recently, the car has exhibited the above symptoms the last few days and then after driving about 20 min, turned it off for 5 min and then it wouldn't start again, no click, didn't try to turn over, nothing, but the dash lights came on. As with the previous 2 times it didn't start on its own, it jumped fine and started right up and ran fine.
The dealer insists the battery is fine (I've checked it myself and it seems ok), the alt is only 5 months old. Any ideas?
Thanks!
dougb76 is offline   Reply With Quote
Old 06-05-2008, 03:46 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
From what you say there may be a couple of issues with the electrical system or they may be tied together some way, possibly bad grounding between the battery and the chassis.
You may be able to track down the faulty power connection to the dash lights by tapping around the main power panel under the hood with a screwdriver handle. You could also try the panel in the dash area. There may also be a problem with the engine grounding so go over that also. One other thing to do is clean the battery connections using a battery cleaning brush. Even if the connections look ok. This will positively eliminate the connections as a trouble source.
Old 06-05-2008, 03:49 PM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
that sounds like alternator diodes and or a loose connection
ProdriveDreams is offline   Reply With Quote
Old 06-05-2008, 05:18 PM   #4
dougb76
Member#: 160340
2009 wrx 5 door
RIP
I thought the first also, but that means either a.) the alternator died, came back to life and died again in 4 months, or b.) the replacement alt. was bad to begin with.
Anyway, thanks for the suggestions and keep them coming. It's a the shop right now since it's still under warranty, but I'm going to go over there today or tomorrow and talk to the tech.
Old 06-05-2008, 05:21 PM   #5
Arctic Penguin
Member#: 119532
2006 WRX
sounds like a kid job on the electrical system bites somebody in the ass to me
Arctic Penguin is offline   Reply With Quote
Old 06-05-2008, 06:07 PM   #6
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
i'd check for bad grounds and reverse all the electrical mods (HIDs, CD player, boost gauge) to be sure that they're not the problem.
dantastic is offline   Reply With Quote
Aftermarket HID problem - 06 WRX - Using factory projector housing Buetang Interior & Exterior Modification 10 06-03-2008 12:27 PM
Security System Problems 02' WRX dairyaamodt2002rex Car Audio, Video & Security 3 09-16-2007 10:00 AM
Odd problem 06 WRX clutch- not shudder Warren N.CA Warranty Issues & SOA Problems 7 12-12-2006 08:21 PM
F/S AEM Intake system 02-06 WRX, STI AddieVac Engine/Power/Exhaust 0 11-11-2006 08:26 PM
Can the stock electrical system on a WRX handle 1600watts? Kwyjibo Car Audio, Video & Security 20 06-15-2002 01:15 PM
