Old 06-05-2008, 09:37 PM   #1
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
Default stri x-line boost gauge reads low
So I ordered a pair of stri x-line gauges on the classifieds here. When I went to hook up the boost gauge I used the vaccuum line going into my factory gauge that was previously hooked up. I connected the new line to the existing factory hose and ran it up to my gauge like normal. Everything seems to work fine except the gauge wont really read past 12 or so psi. When I hooked up my Utec it said I was running 17 pounds like I should be..
Any imput is appreciated.. Thanks
evan_impreza is offline   Reply With Quote
Old 06-06-2008, 02:23 AM   #2
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
anyone have any suggestions?
Old 06-06-2008, 05:36 PM   #3
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
are you running higher than stock boost to atain the 17 psi?
skingfreak is offline   Reply With Quote
Old 06-07-2008, 03:13 AM   #4
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
Yes it is a stage 2 Utec.. it should be 16.5 psi.. Do you think shortening the vacuum line would help any?
Old 06-08-2008, 04:04 PM   #5
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
buuuump for suggestions
Old 06-10-2008, 03:10 AM   #6
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
to the top...
Old 06-10-2008, 03:51 PM   #7
zen_nation
Member#: 181267
i think some punk just took your money and sold you a used broken boost gauge. don't worry they will get theres in the end when they least expect it.
zen_nation is offline   Reply With Quote
Old 06-10-2008, 05:37 PM   #8
androofoo
Member#: 130312
2007 Legacy GT
t fitting issue
androofoo is offline   Reply With Quote
Old 06-11-2008, 08:03 PM   #9
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
but the thing is I didnt change anything about the t -fitting as I used the existing one that my factory boost gauge was hooked up to
Old 06-16-2008, 03:18 AM   #10
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
to the top! suggestions are welcome..
Old 07-05-2008, 10:28 PM   #11
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Anyone has an issue of mechanical boost gauge needle fluctuating from 15-18psi like crazy at WOT? I had tightened all fitting, but it's still doing it.
STRI X-Line BOOST Gauge Black Pearl07 Interior/Dressup/Audio & Security 7 11-20-2008 08:02 PM
Boost Gauge Reading Low??? slingshot New England Impreza Club Forum -- NESIC 0 01-15-2005 01:34 PM
