Old 06-06-2008, 01:21 AM   #1
DubUAreEx
Member#: 113687
2008 WRX Sedan
Lightning Red
Default help!!tail lights not working
hi i have an 04 wrx sedan....my tail lights suddenly stopped working My brake lights do work and i checked the fuse cases but cant find the ones for the rear lights.. PROBABLY SOMETHING STUPID. I have no idea. please help
DubUAreEx is offline   Reply With Quote
Old 06-06-2008, 01:24 PM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
there is a fuse, or used to be, that was for rear illumination in the cabin. if all else fails check all the fuses. i know there is one for the tail lights.
ATX25RS is offline   Reply With Quote
Old 06-06-2008, 04:18 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check fuse 12 and also the taillight relay. Also see if the switch on top of the column works.
Old 08-05-2008, 06:57 PM   #4
milcic07
Member#: 152849
2013 BRZ
Dark Grey
I have a 2007 WRX and today out of the blue my tail lights, 3rd eye, and wing light all stopped working at once. I checked the owners manual and all fuses are good.
I then followed the brake pedal up to a black harness with 4 cables plugged into it. I jiggled the wires and had my buddie watch from the back of the car and the lights where flickering on and off. I unplugged the harness and it looked brand new so I snugged the wires from the female end of the harnesss in tighter, tested and all tail lights came on for 2 pumps of the brake then the tail lights stopped working again..
Any Ideas? Am I missing anything?
Thanks!
milcic07 is offline   Reply With Quote
Old 08-05-2008, 08:09 PM   #5
milcic07
Member#: 152849
2013 BRZ
Dark Grey
please guys chime in
Old 08-05-2008, 08:49 PM   #6
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
your fuse for your tail lights is behind your changer holder on your driver side dash.
i ran into the same promblem about 4months ago.
you got a main fuse box under the hood and you got one behind the change holder.
hope that helps.
jeremywrx15554 is offline   Reply With Quote
Old 08-06-2008, 08:12 AM   #7
milcic07
Member#: 152849
2013 BRZ
Dark Grey
hope that helps.
Thanks for chiming in but did you read my post at all??? I already checked all fuses..
Old 08-06-2008, 11:33 AM   #8
Cougar4
Member#: 53443
Winestone
It sounds like you have a loose connection, possibly a bad ground, in the connector you pulled apart. If you can't locate it your warranty should cover this problem.
Old 08-11-2008, 07:24 PM   #9
milcic07
Member#: 152849
2013 BRZ
Dark Grey
Thank you.. There is actually a switch within the harness that is right above the brake pedal. The dealership is trying to track down a part number to order me a new one.. I will keep you guys posted
Old 08-13-2008, 01:12 PM   #10
milcic07
Member#: 152849
2013 BRZ
Dark Grey
It was the brake switch, the dealer replaced and my brakes are now working..!
Old 08-20-2008, 11:29 PM   #11
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
I'm having this problem now. I uninstalled my amplifier and thought everything was good until a guy pulled up next to me and said my rear driving lights weren't working and only illuminated when my brakes were on. I'm going to check everything in the morning. Anything it could be besides fuse or loose connection?
ThreeEleven is offline   Reply With Quote
97 passanger tail light not work pacotaco Electrical & Lighting 2 02-09-2009 12:31 PM
dash lights and tail lights not working. eocarockwell Electrical & Lighting 1 04-24-2008 11:57 AM
Tail Lights not working whitaken Electrical & Lighting 3 11-09-2007 10:36 AM
illumination and tail lights not working thetraut Electrical & Lighting 4 01-24-2006 04:07 AM
tail lights not working 02SilverRex Electrical & Lighting 7 04-09-2005 08:57 PM
