Old 06-07-2008, 04:17 AM   #1
JHo_STi
Member#: 169675
98' E36 M3
estoril blue
Default Defi owners...
I was wondering if it would be alright if I tapped both the 12v Continuous & 12v ignition to a 12v Ignition source...
This way my defi's ONLY turn on when my car is started...
The downside is that everytime I shut off the car, my PEAK boost and boost warning set will reset back to default..
The reason I did this is because I dont want the Defi's to turn on when im just listening to music with car off...
Will this affect/damage the control unit since it has NO 12v continuous and gets switched in either ON or OFF state??
btw this is for my bmw 335i...
JHo_STi is offline   Reply With Quote
Old 06-07-2008, 12:58 PM   #2
magnum2066
Member#: 158586
2009 WRX
Pearl White
If you tap a continuous circuit they won't shut off.
magnum2066 is offline   Reply With Quote
Old 06-07-2008, 01:25 PM   #3
Runnerup44
Member#: 112126
theres a way to wire it so that it doesnt turn on when ur listenting to the radio and only when the key is in the on position
Runnerup44 is offline   Reply With Quote
Old 06-07-2008, 03:41 PM   #4
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
^^ Exactly. Wire the continuous 12V like you are supposed to so you won't loose your settings. Then wire the 12V ignition wire to a source that is only hot with the key in the ON position. That way, when the key is in the ACC position (listening to the radio), the gauges are off.
I wired my Defis this way so I wouldn't have to listen to the oil pressure warning buzzer when just listening to the radio.
jac04 is offline   Reply With Quote
Defi Question: All Defi BF owners, please look Gfunk720 Interior & Exterior Modification 4 05-19-2010 07:42 PM
Defi owners-How did you solve this problem ? Okeyd57 Electrical & Lighting 8 02-13-2008 03:55 PM
Question to all Defi owners bhs515 Interior & Exterior Modification 3 03-22-2005 08:02 PM
defi hud boost owners help! 6Pack Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-10-2002 09:05 AM
DEFI owners please read... wop Normally Aspirated with bolt-on Forced Induction Powertrain 1 02-01-2002 02:41 PM
