Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 06-07-2008, 05:13 PM   #1
renew
Member#: 171944
2007 Impreza WRX
wr blue mica
Default 06/07 - better rear diff (LSD)
Hi guys, I am quite new to NASIOC but I have the following question (didn't find any real answer during my research I did for a few days right now )
I have a 06/07 (actually its a MY06) WRX and I want a better rear-differential for normal driving on the road but the car will also be used on track-days.
Are there any changes between the 2.0 WRXs and 2.5s? Same differential housing? I know that the final drive is different - but does this affect the choice of available LSDs? Where and how is the drive train attached to the diff (actually determining the final drive ratio)
Actually I would prefer a mechanical type like a quaife - but Quaife said there diffs only fit the "old" ones till MY00.
So has anybody done a rear-diff-swap to something more affective than the stock unit without having to change the axles and anything else?
Thank you very much, yours renew
renew is offline   Reply With Quote
Old 06-07-2008, 09:46 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
you can upgrade rear diff to aftermarket lsd
with no problems.
just make sure it is the proper lsd for your car's year.
Old 06-08-2008, 12:10 AM   #3
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
The Ring and Pinion Gear Ratio is different by year, but you can remove the Ring gear from the differential unit, and then bolt it on to your new diff and put it back together. Ensure it is shimmed properly, of course
I am not sure about axle differences between years.
Last edited by aboothman; 06-08-2008 at 02:00 PM. Reason: added "R&P Gear Ratio is different"
aboothman is offline   Reply With Quote
Old 06-08-2008, 02:46 AM   #4
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
All WRX/RS rear diffs are the same, so you need aftermarket. Go read the Differential FAQ for your options.
Old 06-08-2008, 08:53 AM   #5
renew
Member#: 171944
2007 Impreza WRX
wr blue mica
thats what I heard but wasn't sure about.
So if the Diff fits for instance a MY00 RS (like Quaife says there diff does) it would also fit into my MY06 WRX.
So thanks, I just wanted to be sure. And of course I've read the diff-FAQ, but haven't found any thread about just replacing the rear-diff of a MY06/07.
Old 06-08-2008, 01:11 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
A clutch Type LSD for the rear is ALWAYS more favorable. Yours is R160 still, and LSDs made for the WRX will fit any of the newer R160s; '97+ 2.2L Impreza, '95+ Legacy/2.5GT/Outback, '97+ Forester.
For the OLD SKOOL guys; 93-96
There is a different rear diff on the 1.8L Impreza L, you'd have to swap that with the newer R160. The '97+ Impreza L's has the R160. Yes, a WRX LSD will fit onto an Impreza L's rear diff as well if the Impreza is within the years and has the right rear diff.
FuJi K is offline   Reply With Quote
WTB 06-07 wrx rear diff xxdprussxx Private 'Wanted' Classifieds 0 04-27-2010 10:09 PM
Have open 3.9 rear diff, have 07 wrx rear diff, want vsld 3.90 rear diff - how ? Bad Noodle Transmission (AT/MT) & Driveline 25 10-07-2009 10:25 AM
WTT or buy: 06 07 sti rear diff for wrx diff 02subbysnack SWIC Private Classifieds 6 01-19-2009 11:57 AM
CO: 07 R180 rear diff - 11k, will ship, 07 STi Front and Rear Axles GeneralTJI Drivetrain 6 06-11-2008 01:45 AM
WTB : 02-07 5speed + rear diff (FL) Javi_LGT Private 'Wanted' Classifieds 8 12-21-2007 02:21 PM
