Welcome to the North American Subaru Impreza Owners Club Thursday August 21, 2014
Old 06-08-2008, 05:03 PM   #1
Aaron3969
Member#: 180317
2002 WRX WRB Stg 2
Default Odometer On With Key Off
Hey guys. Dumb question.... my odometer is ALWAYS on. I can turn the car off and come back 8 hours and its still on. Not sure if it's supposed to do that. All the other cars Ive ever seen have them shut off with a key. Also along this line, my OBDII port is always powered. Normal as well? Once again, Im used to having the port deactivate when the key is off. I know its on because my Cobb AP stays on with the key off. Thanks for your help.
Aaron3969 is offline   Reply With Quote
Old 06-08-2008, 05:26 PM   #2
funky monk
Member#: 143094
08 LGT
DBM
yea, all of them are like that. My friend pointed out to me a while ago that the gas gauge doesn't move when the car is off like most other cars, I'd never even thought about it. Guess it's just a subaru thing
funky monk is offline   Reply With Quote
Old 06-09-2008, 01:37 AM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
thats how they are dude, live with it
jdubya301 is offline   Reply With Quote
Old 06-09-2008, 11:06 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Having those things powered on with the key OFF doesn't sound right to me but I can't say for sure what is really correct. There may be something wrong in the ignition switch area. I would think the display would at least go into a SLEEP mode after the ignition was shut off for some time. If other owners say that is the norm and don't have a problem with a battery drain then I guess it is fine. Having the OBD2 port hot all the time doesn't seem right either. I would think that should be switched with the ignition.
Old 06-09-2008, 02:29 PM   #5
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
yeah, when i was shopping for subies, they all had the odo-ers on. it was nice to see the mileage was visible
Old 06-09-2008, 03:10 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....my '03 is always on but my '08 Forester is off.
Kean is offline   Reply With Quote
Old 06-09-2008, 03:34 PM   #7
2.5wagonkid
Member#: 178003
94 old leggy BC
panda
same story
2.5wagonkid is offline   Reply With Quote
Old 06-09-2008, 03:46 PM   #8
boxer4power
Member#: 163545
2002 impreza 2.5ts
Green
really? my 08 forester stays on. so does my 02 wagon
boxer4power is offline   Reply With Quote
Old 06-09-2008, 03:55 PM   #9
Kean
Member#: 25187
'08 Foz Prem TGM
....yep. As recent as two weeks ago I changed the oil in both. When I went to document the mileage on my logs (yeah, I'm anal like that), I recall having to use the key to read the odometer. .....with my '03 I did not. I'll check when my wife and I go home today (since we drove the Forester), but I'm fairly certain it doesn't display the mileage without the key.
Old 06-09-2008, 03:57 PM   #10
Cougar4
Member#: 53443
Winestone
Are the displays that stay on, LCD type displays? I could understand that if that is the case since they draw very little power. If they are vacuum floresent then I could see it being a problem.
Old 06-09-2008, 04:02 PM   #11
Kean
Member#: 25187
'08 Foz Prem TGM
....as a follow up to my last post, the following is from the Forester manual:
Odometer/Trip meter
This meter displays the odometer and two trip meters when the ignition switch is in the "ON" position.
NOTE
Even with the ignition switch in the "Acc" or "LOCK" position, the odometer and trip meters are displayed for 10 seconds when you press the knob.
Old 06-09-2008, 04:05 PM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
....I believe for everyone else here (not sure about your application) the answer is yes.
Old 06-09-2008, 09:05 PM   #13
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
This is correct newer model scoobies do turn the odo off after a while, however you do not need the key to read the mileage, simply hit the tripmeter reset button and it will display the odometer reading, and on newer cars that do gauge sweep it will also display the amount of fuel in the tank.
oops kean beat me too it.
ProdriveDreams is offline   Reply With Quote
Old 06-09-2008, 10:13 PM   #14
02redwagone
Member#: 87067
02 Old but tasty
SRP
The 02 head unit will give and take CDs with the key out too. Very handy.
02redwagone is offline   Reply With Quote
Old 06-10-2008, 01:01 AM   #15
0wrx2
Member#: 82297
2OO2 urban offroader
four door black
... for stealing someones CDs
jp
0wrx2 is offline   Reply With Quote
Old 06-10-2008, 10:45 AM   #16
Cougar4
Member#: 53443
Winestone
Thanks for the reply Kean. Since LCD displays only require current measured in microamps to run the display it makes sense that the display can be on at all times.
Impreza Turns off, then turns on with no key Jutboy Electrical & Lighting 2 02-23-2009 12:40 PM
Brake lights and running small lights on.... with car off... ltjake22 Interior & Exterior Modification 14 03-12-2007 07:34 AM
Honda says odometers on 6M cars click off mileage at too-quick pace NYCshopper Non-Subaru News & Rumors 20 02-19-2007 01:22 PM
How do i wire my windows so that they'll operate with the key off or out? Trizzle Electrical & Lighting 9 05-09-2004 01:26 AM
radiator fan turns on with key just before crank posistion... BoostedAWD Electrical & Lighting 4 03-16-2004 07:22 AM
