Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 06-08-2008, 08:18 PM   #1
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
Default 9" Wheels
are there any 9" wheels that will fit a wagon?
ahendrickson is offline   Reply With Quote
Old 06-08-2008, 08:56 PM   #2
wrxsnowstyle
Member#: 122973
02 WRX wagon
9 inch wide i would guess...but yes there are. you can fit a 17x9.5 if you wanted to, i havent seen a useable 18x9 set up yet, itd be pointless to run 225s on a wheels that wide.
for what its worth, try being a little less vague in your posts, that doesnt give us much to work with.
wrxsnowstyle is offline   Reply With Quote
Old 06-08-2008, 08:58 PM   #3
wrxsnowstyle
Member#: 122973
02 WRX wagon
this is directly from another thread:
Originally Posted by gold rush View Post
these are Work Emo Kai 17x9 29et (44et - 15mm spacer) with Hoosier 275/40/17 R6's. Fenders needed to be cut out and I installed "Wald" flender bubles for a Lexus IS300. The fronts bolted right up, but the back small part that goes on the door need to be cut and glued onto the main part because it was too long and stuck out when the door was open. Also the rear door needed to be trimmed a bit to close nicely. I also had to trim the lip down in the back in order for the tire to tuck and not rub, plus the rear camber needs to be at least 1.5 degree.
Old 06-08-2008, 10:23 PM   #4
waktasz
Member#: 86356
Ouch, my resale value hurts.
waktasz is offline   Reply With Quote
Old 06-09-2008, 11:01 AM   #5
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
I was thinking I would like to run a set of 235/40R17 90W Falken Azenis RT-615s with a set of like 17x9 wheels. I am pretty new to determining the fitment of wheels/tires. What did you mean when you said it would be pointless to run 225s on 9.5s. I am also planning on putting sedan front fenders/bumper on and rolling my rear fenders. Would this set up work you think? Also, what offset are you thinking?
Old 06-09-2008, 11:22 AM   #6
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
Oh yeah, I also have my car lowered 2.0 inches in the front and 1.6 in the rear
Old 06-09-2008, 12:08 PM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
235/40 is the tire size choice of STX competitors- they are limited to a 8" wheel and the fitment is very good. Lots of 8" choices, several 8.5" as well.
the only reason to run 9"+ rims is if your trying to run 255+ tires and w/ a wagon that will be very (very) difficult w/o some serious "work"- see above
Old 06-09-2008, 01:49 PM   #8
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
ok, cool. in that case i have a wheel in mind
9" wheels on a wagon lbtch Tire & Wheel 10 03-17-2010 04:17 PM
wtborrow: some very wide wheels. wei? benson? somone with atleast 9" wide 5x100? Loomin VIC Private Classifieds 42 10-18-2008 07:59 PM
295/40ZR17's on 9" Wheels masti04 Tire & Wheel 3 02-16-2008 09:16 AM
285/30/18 on an 9" wide wheel. Can it be done? rich728 Motorsports 18 10-06-2006 06:21 PM
