Old 06-08-2008, 09:12 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Is this a bad idea? heat wrap on DP
Update 07/28/10 --> HT tapes are holding up extremely well even after 2 years.
I used DEI heat wrap and used high temperature tapes to seal it... I am putting DP on my car tomorrow; should I leave it on or peel them off?
Thanks,
Old 06-08-2008, 09:17 PM   #2
MIKE DD
Member#: 106818
2003 Truck
it's fine, leave it
MIKE DD is offline   Reply With Quote
Old 06-08-2008, 09:19 PM   #3
DUB03REX
Member#: 164939
02 Tacoma TRD
SV650 XR250 R6 Tiger 800
So you already put it on and now you are asking if you should take it off or leave it on?
Anyway, leave it, couldn't hurt.
DUB03REX is offline   Reply With Quote
Old 06-08-2008, 09:29 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I normally spray DEI silicone spray on top of DEI wrap, but ran out of them. Just wondering if anyone else had done the same thing and how it is holding up.
Old 06-08-2008, 09:34 PM   #5
MIKE DD
Member#: 106818
2003 Truck
i did a piss poor job wrapping mine and just used metal zip ties, 1k miles and ain't unwrapping yet, wish me luck =)
Old 06-08-2008, 10:33 PM   #6
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Mine was wrapped for about 2 years, unpainted and all. I took it off when the DP was installed on the car, but the metal underneath was not rusty (SS Helix catted DP).
rougeben83 is offline   Reply With Quote
Old 06-08-2008, 10:49 PM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I am more curious about how high temperature tape will hold up.
Old 06-08-2008, 11:43 PM   #8
choi0706
Member#: 126548
easy, whats the tape rated at?
the ideal solution is to get a "real" ceramic coat job.. not the shiny bling stuff jethot is famous for.. I found doing a combination of ceramic coating on the turbo/DP/headshield and using heatwrap +silicone spray+ heatshield works excellent on keeping the heat away from the top mount..
choi0706 is offline   Reply With Quote
Old 06-08-2008, 11:46 PM   #9
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
ive had mine wrapped and coated for a few months now and holding up great all with DEI products
03WRX-WRB is offline   Reply With Quote
Old 06-09-2008, 01:10 AM   #10
bebesito21
Member#: 176128
5862 ...baby boosted
Thanks,
you should continue to wrap all the way up to the flange. that is the part that sits right under the intercooler.
bebesito21 is offline   Reply With Quote
Old 06-09-2008, 01:13 AM   #11
bebesito21
Member#: 176128
this may smoke alot too, the header wrap will definitely smoke, doesn't look like it has anyware to go.....check the temperature threshold on the tape as well. otherwise looks good.
Old 06-09-2008, 01:58 PM   #12
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
Definitely wrap all the way up to the mouth. I've had my dp and header wrapped with heat wrap and foil tape for a few years. Don't be scared by the white smoke billowing from your scoop, the adhesive will start to burn off pretty quickly. It may take several days for all the glue to burn off. It would be a good idea to throw a few more clamps on. When the adhesive burns off, the only things holding the tape on are the clamps, and the tape may loosen over time.
foxboroxt is offline   Reply With Quote
Old 06-09-2008, 03:36 PM   #13
awd-turbo
Member#: 167551
02 wrx
nope. it is ok...go up to the flang though...but i would not suggest wrapping the turbo.. there has been heated discussions on whether it wears them uot faster...and i myself believe that it does....
awd-turbo is offline   Reply With Quote
Old 06-09-2008, 03:53 PM   #14
bebesito21
Member#: 176128
I installed my new downpipe yesterday. I wrapped the whole thing from flange to flange all the way back to the cat back. I only used thermal wrap and the sealant spray. My underhood temps went way down...i can actually touch the intercooler after running around now. the downpipe wrap is hot to the touch but not unbearable...however i woudnt leave my hand on it.
i want to wrap my turbo next
Old 06-10-2008, 12:58 AM   #15
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I drove around in the city in 100F weather with this downpipe on. Surprisingly, it did not smoke at all... not sure if it's due to no place for smoke to escape to.
Old 06-10-2008, 09:56 AM   #16
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
Did the tape have any adhesive on it?? If so, where did you get the tape, and what is it called? I've used whatever I could find at Home Depot, and it definitely smokes. I thought my car was on fire the first time!
Old 06-15-2008, 02:36 AM   #17
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I stopped by at Walmart to locate the tape again to find out what the specs are, but tapes were sold out.
After driving for almost a week now it still hasn't smoked which is very strange. Tape did come with adhesive on it.
Old 04-02-2009, 01:33 AM   #18
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
update: 04/01/09
So far it's holding up amazingly well. Looks as good as new after almost a year.
Old 07-28-2010, 11:17 PM   #19
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
update: 07/28/10
It's still holding up amazingly well even after 2 years!
Old 07-28-2010, 11:30 PM   #20
02WRX<3
Member#: 183230
2006 STi
haha, who would think that you would bump this page up 2 years later, cool. XD
02WRX<3 is offline   Reply With Quote
Old 07-29-2010, 12:15 AM   #21
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
You ever find out what that tape was?
Psychoreo is offline   Reply With Quote
Old 07-29-2010, 12:25 AM   #22
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Unfortunately I don't know the brand name, but I still got a lot of tape left. I picked it up from Wallmart, so you might be able to find one there.
Old 07-29-2010, 12:27 AM   #23
Psychoreo
Member#: 79643
2015 WRX STI
I'll take a look, thanks!!
Old 07-29-2010, 03:14 AM   #24
Kfly04
Member#: 252005
2004 STI
Java Black
thats fine man heat wrap is always safe to use we use them on headers all the time
Kfly04 is offline   Reply With Quote
Is this a bad idea? (DIY uppipe) OHTOORECKS Newbies & FAQs 25 11-14-2007 11:48 PM
Is this a bad idea? tacomaprime Off-Topic 13 12-11-2005 10:36 PM
i should of got the subaru, but is this a bad idea? siopao2000 General Community 36 02-20-2005 12:11 PM
heat wrap on dp Fitz12444 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-28-2004 10:06 AM
Is this a bad idea? staticfritz Tire & Wheel 4 08-29-2004 06:56 PM
