Old 06-09-2008, 12:06 PM   #1
state
Member#: 118560
2002 2.5 RS
Unhappy I think I may have screwed up...
ok guys, when it comes to tires and rims I am a newb.
I just bought a set of used Tarmac IIs 17x7.5 that came with a set of 225/45/17 blizzaks, I wanted to pop a set of summer tires on so I bought a set of 245/40/17 Federals. now I am afraid that they will be too wide for my rims or even my fenders. I cant cancel the order without paying a restock fee
do you think these tires will fit?
for reference, I am sitting on a set of whiteline flatout springs
ok guys, flame away at me for being a newb
state is offline   Reply With Quote
Old 06-09-2008, 12:32 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Man, you're so screwed....
Really, I'm not sure, but it sounds like you are screwed.. lol...
Old 06-09-2008, 01:08 PM   #3
Arctic Penguin
Member#: 119532
2006 WRX
well
ya geot the wrong tires and the wrong springs
Arctic Penguin is offline   Reply With Quote
Old 06-09-2008, 01:26 PM   #4
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
it'll fit but the tires will bulge. if you have a wagon the 245's may rub but you shouldn't have clearance issues if you have a sedan.
kunfuzion is offline   Reply With Quote
Old 06-09-2008, 01:48 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....the recommended wheel width for that size (according to Federal) is either 8"-9" or 8"-9.5". .....depending on the model you purchased. They'll buldge as kunfuzion mentioned.
Kean is offline   Reply With Quote
Old 06-09-2008, 03:24 PM   #6
Boxologist
Member#: 21118
teh tyres will fit easy. u will probably need to roll the rear fenders.
Boxologist is online now   Reply With Quote
Old 06-10-2008, 03:39 PM   #7
Tire Rack Moderator
Member#: 1215
ext. 4362
245/40-17 Rim Width Range...... 8.00 to 9.50
Old 06-10-2008, 04:38 PM   #8
state
Member#: 118560
2002 2.5 RS
I may be starting a For Sale thread VERY SOON then.
Old 06-10-2008, 04:45 PM   #9
REX8
Member#: 24038
Don't just yet. They'll fit the rims just fine. Depending on the sidewall stiffness, and the pressures you run, they may feel a little softer on turn-in, but not a big deal.
You'll probably be able to run them a little high on pressure to get some of the feel back.
Not worth losing hundreds of dollars on the deal, try them out first.
Old 06-10-2008, 05:04 PM   #10
Tire Rack Moderator
Member#: 1215
ext. 4362
squishy sidewalls
irregular wear
tramlining
reduced steering response
reduced contact patch
not really a good fit
Old 06-10-2008, 05:08 PM   #11
REX8
Member#: 24038
Originally Posted by [email protected] View Post
squishy sidewalls (depends on the tires)
irregular wear (false, we're talking about 10mm over...he won't see any wear changes running a reasonably correct pressure)
tramlining
reduced steering response (a product of sidewalls, the extent of which depends on the tires...might be horrible, might be hardly noticeable)
reduced contact patch (ummm....no. Curb-weight and PSI determine contact patch AREA. Change in SHAPE, sure).
See comments
Of course no one would recommend it for street driving, but if he has them already, and the loss of turn-in isn't horrible (again, depends on the tire), it very well might not be worth losing the $$$.
There are plenty of stiff sidewalled summers that will feel better in a 245 40 than a 225 all-season. Its all relative. If he can live with it, maybe he'd rather not lose the money.
BTW: You forget to mention gas mileage, unsprung weight, etc!
Old 06-10-2008, 05:31 PM   #12
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
or sell the wheels and get something a bit wider.
I tnink I may have screwed things up - not sure last lemming alive Transmission (AT/MT) & Driveline 0 10-04-2009 01:17 PM
Oh crap...I may have screwed up!!! WrexT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-12-2008 01:22 PM
Changing PCV valve and may have screwed something up subaruwrx420 Service & Maintenance 19 05-21-2007 02:43 PM
I think I may have really *effed* up WRC 3X1 Off-Topic 35 06-04-2005 04:45 AM
Help I think I may have gotten screwed Dageman Engine Management & Tuning 7 03-05-2005 09:00 PM
