Old 06-05-2008, 05:48 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Question Unusual clutch wear, low miles
ok I have the nasioc friend I am trying to help, since I know a bit about this stuff. Yet I wanted further opinions. Even though I think I am on the right track.
He has an 03 wrx with an exedy organic clutch currently. The clutch has 1000 miles on it. It wont stop chattering. Once it reaches 2000 rpm it starts to chatter and slip. If he adds more gas it simply slips. I am telling him he has a clutch problem and not a trans problem. Yet after looking at the pics wow that's a new one on me.
after 2 clutches and 6k miles on the fw.
http://img.photobucket.com/albums/v4...0/DSC02285.jpg
1 time around with the exedy disk and second time with act fw.
http://img.photobucket.com/albums/v4...0/DSC02280.jpg
This is his 2nd or 3rd clutch doing this exact problem. I asked if the pilot bearing was damaged. He said no damage was noticeable, bearing was like new.
The only thing that comes to mind is the clutch fitment to the pp and fw. As if on of these surfaces was not straight and making full contact with the clutch. Yet the one heavy heat spot is really strange.
I am suppose to look at the clutch in person in the next day or so. I was going to check it for level surface to the disk and see what I come up with.
Recently installed was a set of RA gears. Yet this problem was going on before the gears were installed. Also T/O was not replaced. The car has about 58k miles on it.
Any help would be great.
thanx
hybrid gti 2 is offline   Reply With Quote
Old 06-05-2008, 06:04 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I didnt see any in the pictures but is the rear main seal leaking oil on the clutch?
And I'll be the first to ask the obvious question - You sure the problem isn't between the chair and steering wheel?
ciper is offline   Reply With Quote
Old 06-05-2008, 06:15 PM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
haha no I can't be sure of that problem yet.
Old 06-06-2008, 04:32 AM   #4
Lazyxturb0
Member#: 107682
03 WRX Catless
hey everyone.
those are pictures of my clutch, and thanks Hybrid for helping me out.
as far as my driving goes, i never launched or abused the clutch. i haven't really rode the clutch either, and drove very easy on it trying to break it in.
so the problems are very confusing to the both of us.
any help would be greatly appreciated
Lazyxturb0 is offline   Reply With Quote
Old 06-06-2008, 11:58 AM   #5
strohausii
Member#: 26770
'02 WRX
midnight black
I'll throw out some thoughts:
-installation:
-no reused parts?
-flywheel & pressure plate have markings to show "residual imbalance" where you are to install these 2 as near to 180 degrees opposite so the tolerances do not stack.
-Was the clutch assembly "aligned" when installed.
-Is there play in the clutch pedal. There should be, not sure what the "dead" travel is spec'd at, but this insures that when your foot comes off the clutch pedal, it is fully engaged.
strohausii is offline   Reply With Quote
Old 06-08-2008, 05:33 PM   #6
Lazyxturb0
Member#: 107682
03 WRX Catless
hm.. all parts were brand new, and the installation was done by a good subaru mechanic.
also, there is some play in the cluch.
i think it may have to do something with the throwout bearing, although i'm not 100% sure.
i'm going to install a snout repair kit this weekend and see if it helps.
Old 06-08-2008, 06:26 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
where did you get one so quick
Old 06-08-2008, 09:01 PM   #8
Lazyxturb0
Member#: 107682
03 WRX Catless
didnt order one yet.
i meant this father's day weekend
Old 06-08-2008, 11:46 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I already ordered one. Should be here thurday.
Old 06-09-2008, 10:34 AM   #10
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Was the flywheel resurfaced each time a new clutch was put in?
bluescoobywagon is offline   Reply With Quote
Old 06-09-2008, 04:43 PM   #11
Lazyxturb0
Member#: 107682
03 WRX Catless
yeap. flywheel was either resurfaced or replaced with a brand new one everytime.
Old 06-09-2008, 05:39 PM   #12
prometheum
Member#: 92003
04 bicycle!
here's a dumb question. it looks like the wear is just on 1 side of the flywheel
when you installed the pressure plate onto the flywheel did you make sure do torque the bolts down properly with a torque wrench? also after you torqued them all down did you go over them again with the toque wrench?
when you torque down each individual bolt it presses down on the fingers on the pressure plate so each bolt you torque down takes pressure off all the other ones. if you don't retorque them after they've all been torqued down they won't be evenly torqued
prometheum is offline   Reply With Quote
Old 06-11-2008, 02:43 AM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
^ Installed by mechanic. One would hope they did that.
Old 06-11-2008, 09:06 AM   #14
bluescoobywagon
Member#: 14911
Not A Wagon!
In my experience, mechanics use torque wrenches less often that hobbyists. Usually you get a response like "I've been changing clutches for 20 years and haven't needed a torque wrench yet"
Old 06-11-2008, 04:47 PM   #15
Lazyxturb0
Member#: 107682
03 WRX Catless
each install was done at either a reputable subaru or transmission shop, and the same shuddering/slipping and decel noise never went away.
i think a snout repair kit may do the trick, although i would not be surprised if it doesnt.
thanks for the input guys.. let me know if you guys have any more info..
Old 06-11-2008, 08:39 PM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Well after talking to act today it would seem there is grease on my clutch disk and pp. So maybe you have the same problem, Lazy.
Old 06-11-2008, 09:05 PM   #17
Lazyxturb0
Member#: 107682
03 WRX Catless
hm icic. ill double check on that
Old 06-12-2008, 10:24 AM   #18
strohausii
Member#: 26770
'02 WRX
midnight black
Could be getting contaminated from the rear crank seal?
Before I brought in my Flywheel to get installed, I was very neruotic to degrease and follow up with dish detergent (x2) and brush the flywheel. Then prayed that the mechanic would not regrease it with his fingerprints.
I've gotta admit, my engagement with the streetlight is better than it ever was with my OEM (I too had shudder on low dewpoint days). I can't say I've had any shudder yet except maybe when I was first breaking the clutch in. I just went with the OEM dealer clutch assy.
Unusual Tire Wear unity65 Newbies & FAQs 13 04-28-2009 07:21 PM
2005 Stock WRX clutch and flywheel. LOW LOW miles BiggSean Drivetrain 2 09-17-2007 01:18 AM
Fs - 2004 Sti Ferodo Ds2500 Front & Rear Pads - Low Miles - Minimum Wear mazdman Suspension/Brakes/Handling 0 01-07-2007 11:26 AM
WTB: Stock Clutch or other with low miles for WRX vipernj Tri-State Area Private Classifieds 6 06-02-2006 09:46 AM
unusual tire wear scubyslacker Tire & Wheel 7 12-09-2003 07:13 PM
