Old 06-09-2008, 10:49 PM   #1
greenshoes3
Member#: 164049
MBP stg2 dom tuned
Default 235/45/17's on OZ Prodrive P1's?
I bought 4 used Bridgestone ls-z tires 235/45/17's for $100, will they fit my wheels or not? They are the 17". A guy at discounttires said they would fit but I would have to lower the tire pressure a little to get them to sit flat. Thanks!
greenshoes3 is offline   Reply With Quote
Old 06-10-2008, 09:16 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
how wide are your wheels?
Old 06-10-2008, 12:53 PM   #3
nixgame22
Member#: 101219
I think the P1's are 17x7
nixgame22 is offline   Reply With Quote
Old 06-10-2008, 01:16 PM   #4
nv-wrx
Member#: 75643
2004 WRX
San Remo Red
Yes they are 17X7"
I've got 225/45/17s on my P1s. They stick out a bit, but not bad. I don't see a problem putting the 235s on there, as a friend of mine has 225s on his 6.5" stock rims.
nv-wrx is offline   Reply With Quote
Old 06-10-2008, 01:39 PM   #5
greenshoes3
Member#: 164049
MBP stg2 dom tuned
yes they are 17x7. I wanted to use them for track use. Right now I have ****ty federal all seasons on there with good tread, so I figured the bridgestones would benefit my handeling for minor track duty.
Will it benefit handeling or be unsafe?
Thanks for all the help!
Old 06-10-2008, 02:32 PM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
The minimum recommended rim width is 7.5" so the sidewalls are going to be squishy. You'll probably need to run increased pressure at the track to keep them from rolling over onto the sidewalls.
bluescoobywagon is offline   Reply With Quote
Old 06-10-2008, 03:42 PM   #7
Tire Rack Moderator
Member#: 1215
ext. 4362
235/45-17 Rim Width Range...... 7.50 to 9.00
squishy sidewalls
irregular wear
tramlining
reduced steering response
reduced contact patch
not really a good fit
235/45/17's on 04 sti wantsti Tire & Wheel 4 06-13-2009 02:50 AM
235/45/17's on OZ Prodrive P1's? greenshoes3 Newbies & FAQs 3 06-10-2008 09:50 AM
Can i run 235/45/17's in the rear and 225/45/17's on the front rims? All4bSpinnin Tire & Wheel 10 12-24-2007 09:50 PM
Any Pics of 235/45 17's on 17.5 wheels? NcKidd Tire & Wheel 1 12-08-2006 01:39 PM
235/45/17's on stock wheels? Inprogress Tire & Wheel 3 02-21-2006 07:45 AM
