Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 06-10-2008, 07:43 PM   #1
revenance
Member#: 121851
2003 wrx
YELLOW
Default small problem or big problem?
i just pulled out my 5spd on my 03 bugeye. and when i "dropped" it out i bent the 2 studs on the bottom that bolt it on. can i simply bend them back or should i replace them? and how hard is it going to be to replace them?
revenance is offline   Reply With Quote
Old 06-10-2008, 08:37 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If you can get them straight that's fine. If you can't then it will make the re-install a little more difficult. Just don't pound on the threads.
To remove them all you really need is a vise grips.
Tim Sanderson is offline   Reply With Quote
Old 06-10-2008, 08:39 PM   #3
revenance
Member#: 121851
2003 wrx
YELLOW
are they just threaded in?
Old 06-10-2008, 08:41 PM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
yes....
flstffxe is offline   Reply With Quote
Old 06-10-2008, 09:04 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Lock two nuts together and drive them out then install new ones. It's hard enough to get the damn thing installed when they aren't damaged!
'99 Outback 2.5L problem, maybe BIG problem evanejp1980 Legacy Forum 3 12-03-2009 09:59 AM
104k, fixing most problems, potentially big problem? 25mphnext2miles Factory 2.0L Turbo Powertrain 11 01-05-2009 10:51 AM
Too small injectors, or ecu problems? reddevil Engine Management & Tuning 5 10-28-2006 04:23 AM
Clutch problem or tuning problem? earlmale Transmission (AT/MT) & Driveline 3 02-21-2006 12:24 AM
Web problem or my problem? No search? RyeDaddy General Community 2 08-22-2003 12:17 PM
