Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 06-10-2008, 11:01 PM   #1
ten80
Member Sales Rating: (123)
Member#: 53625
00 EJ205 LGT-4SALE
Default Tokico D-spec, Group N tophats, ultimate wagon springs
I'm selling my car so I re-installed stock suspension. I am selling the setup that took me two years to figure out. My goal was a setup that is near stock ride height, has a level stance, no saggy wagon ass, and has dirt-capable spring rates. I found that a combination of JDM STI front springs (V7?) and STI forester rear springs resulted in a very level ride with firm but smooth rates.
02-03 Tokico D-spec struts (under 4k miles). Will include necessary washers (grade 8, perfect fit) to use 04+ rear strut tops. $425 shipped SOLD
Group N front strut tops. ~15k use. SOLD
Group N 04-07 rear strut tops with rear boot holder cup removed, ~15k miles use. Will work with Racecomp engineering, DMS, and other coilovers. SOLD
JDM STi front springs and FXT STI rear springs. No longer available.
ten80 is offline   Reply With Quote
Old 06-11-2008, 01:11 AM   #2
SaltD
Member Sales Rating: (1)
Member#: 143162
04 FXT
JBP
Dude,
how many suspensions have you tried? You sell like 2 setups a week.
Interested in this one though. This should bolt right up to my FXT with no sag, no? I see you have the FSTI springs on there and I know you have experience with Fozzies. About how much drop from FXT stock hight do you think this might be. ~3-4"? Performance wise looks solid. Thanks.
D
SaltD is offline   Reply With Quote
Old 06-11-2008, 02:27 AM   #3
Mobutusan
Member Sales Rating: (16)
Member#: 118017
2004 WRX Waggin'
What are the spring rates on those?
Mobutusan is offline   Reply With Quote
Old 06-11-2008, 03:10 AM   #4
ten80
Member#: 53625
00 EJ205 LGT-4SALE
Yep, I have indeed tried a million suspension combos and it is unfortunate that I'm selling my car. As for the drop on a FXT, it should be around 2". The back end will definitely be taller than if you were using wrx wagon springs but the front will be a tad lower. I also have the front FSTI pink springs with a coil cut out which might work better on the heavier front end of an FXT. With the aluminum hood and lack of turbo/uppipe/etc, the front end of my car is fairly light.
I suspect that the front springs are 01-02 STI with a rate of 188lbs/in and the rears are 162lbs/in. I Drove my car yesterday with this setup and today with stock wrx suspension and the difference is noticeable, but not as extreme as when I was using USDM STI springs all around.
Old 06-11-2008, 05:29 AM   #5
psidy
Member#: 166408
2006 Sti
Will the top hats work on an '06 STI?
psidy is offline   Reply With Quote
Old 06-11-2008, 09:40 AM   #6
ten80
Member#: 53625
00 EJ205 LGT-4SALE
Yep, but you'll have to use a couple STI front strut boots on the rear struts. This is because rear strut boots will no longer attach to the rear tophats as I have cut off the lower cup that normally holds them on. I do have an extra set of STI front strut boots.
Old 06-11-2008, 02:13 PM   #7
S2K-F8
Member#: 162477
2005 Saab 9-2X AERO
Satin Gray
Are you in CO or WA?
If CO, what part? (trying to figure out if you're local)
Scott-
S2K-F8 is offline   Reply With Quote
Old 06-11-2008, 02:17 PM   #8
left footed whooten
Member Sales Rating: (4)
Member#: 44652
06 WRX
15 Forester
4k miles on the tophats, too?
left footed whooten is offline   Reply With Quote
Old 06-11-2008, 02:30 PM   #9
ten80
Member#: 53625
00 EJ205 LGT-4SALE
Front and rear tophats have right around 15k of use, all on my car. Scott, I'm in Golden.
Old 06-11-2008, 02:38 PM   #10
S2K-F8
Member#: 162477
2005 Saab 9-2X AERO
Satin Gray
Cool, just sent you a PM
Old 06-12-2008, 02:44 AM   #11
ten80
Member#: 53625
00 EJ205 LGT-4SALE
Struts are pending to S2K-F8. All other parts still available
Old 06-12-2008, 06:36 PM   #12
S2K-F8
Member#: 162477
2005 Saab 9-2X AERO
Satin Gray
Originally Posted by jskopic1 View Post
Oh, I wanted the entire package, if the sale dosen't go through, I got dibs.
I picked up the struts and camber bolts this afternoon.
Thanks Christophe!
Scott-
Old 06-24-2008, 04:02 PM   #13
ten80
Member#: 53625
00 EJ205 LGT-4SALE
Bump, still have everything but the struts!
edit:
I'm out of town till the 6th
Old 07-09-2008, 02:31 PM   #14
ten80
Member#: 53625
00 EJ205 LGT-4SALE
Still have springs and tophats!
Old 07-10-2008, 08:16 AM   #15
STi_v4_Wagon
Member Sales Rating: (9)
Member#: 120368
04 Forester XT
Compared to a stock wrx wagon will these lower at all?
STi_v4_Wagon is offline   Reply With Quote
Old 07-11-2008, 10:56 AM   #16
ten80
Member#: 53625
00 EJ205 LGT-4SALE
the front will be a tad lower and the rear a tad higher.
Old 07-11-2008, 08:41 PM   #17
urfsin
Member Sales Rating: (2)
Member#: 128975
2005 Outback XT
Golden Thunder
PM sent
urfsin is offline   Reply With Quote
Old 07-21-2008, 11:29 AM   #18
gandapanda
Member Sales Rating: (8)
Member#: 51476
05 FXT
06 S2000 - gone soon
Thanks for the rear tophats, Christophe.
Sonny
gandapanda is offline   Reply With Quote
FS NJ Tokico D Spec Shocks, Race Comp Yellow Springs & Group N Front & Rear Top Hats chop204 Suspension/Brakes/Handling 31 01-23-2010 09:01 PM
FS:(NJ) Tokico D Specs, RCE Yellow Springs and Group N front and rear Tophats chop204 Tri-State Area Private Classifieds 7 01-19-2010 04:07 PM
FS: group n tophats & crucial springs syp-rs Suspension/Brakes/Handling 7 01-29-2008 12:32 PM
Feeler: STi Pinks, Tokico D-Spec, Group N tophats (pick-up only) UCRWRX Suspension/Brakes/Handling 12 12-06-2007 04:13 PM
What's the weak link now? - Tokico D-spec + Prodrive installed on 03 Wagon 0db Brakes, Steering & Suspension 14 04-05-2007 01:17 PM
