Old 06-11-2008, 12:33 AM   #1
cireturbo
Member#: 119777
2013 BRZ
Default Quest for 11's in the VF48 Saabaru (How much more can I get out of my VF48?)
I currently have...
VF48 Turbo
Spearco TMIC
STI Y-Pipe
TurboXS 4" DP
P&L 3" Street Catback
P&L HiFlo Intake
Samco Turbo Inlet Hose
Walbaro 255 Fuel Pump
Cobb v2 Accessport
GM Boost Solenoid
Here's the Dyno... (20psi, injectors were maxed out resulting in taper to 15psi at redline)
Went [email protected] on 93 at the Subaru shootout. (With a 1.9 60ft.)
http://www.youtube.com/watch?v=jXLoia696oQ
*Update* - 12.6 @ 109 with a 1.87 60 ft, still on the stock clutch and transmission with no new mods. Still waiting for a transmission upgrade before I add any more power. I figure a decent 60 ft would get my current setup into the 12.4's on pump gas, I'm starting to think my goal isn't too unrealistic. Once I have a drivetrain durable enough to stand up to some launch control I'll be ready to try.
I'm currently looking into my next "stage" of upgrades, and I'm aiming for low 12's and maybe high 11's if the conditions were right. I've realized heat is my enemy on the top mount, so I'm trying to reduce it as much as I can. I'm also planning on a 109 tune in addition to my 93 tune this time around.
Here's my plan for the next batch of mods, would it be wise to upgrade my stock BPV?
P&L 44m EWG Kit
Maddad v2 UEL Headers
DW 750cc Injectors
1 step colder plugs
TGV Deletes
Phenolic Spacers
Heat Wrapping on the Downpipe, Uppipe, Headers and Turbo
Any advice or input is welcomed.
cireturbo is offline   Reply With Quote
Old 06-11-2008, 11:07 PM   #2
cireturbo
Member#: 119777
2013 BRZ
Is there any advantage/disadvantage between the Tial 38mm and Tial 44mm external wastegates on the stock turbo? I'm starting to lean towards the 44mm because of the V-band. Just wondering if the 44mm is "too much" for a VF48, if not I'll probably step up to it.
Old 06-11-2008, 11:31 PM   #3
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
spray it and dont tell anyone
mxpunk is offline   Reply With Quote
Old 06-12-2008, 09:24 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
water/meth..good for +30whp
Old 06-12-2008, 10:26 PM   #5
Foska Oats
Member#: 144081
2003 WRX
You can do better that 12.9 with that much power and the 93 octane gas.
My car has a VF 22, pinks TX TMIC, HKS Hyper TBE and a tactrix flash with 90 octane (276whp/283trq) 12.86 on the strip.
And Jamaica ain't cool, it is pretty hot.
Foska Oats is offline   Reply With Quote
Old 06-12-2008, 11:12 PM   #6
cireturbo
Member#: 119777
2013 BRZ
Yup, you are correct. I can probably knock 3 tenths off my 60ft if I get a good launch (waiting on a stronger tranny/clutch). I think the trap speed is what should be relevant. I wasn't trying to imply that my 12.9 run was anything impressive. You aren't exactly comparing apple to apple either, isn't a VF22 noticeable larger than a VF48?
Old 06-12-2008, 11:20 PM   #7
MartinSTi05
Member#: 145145
2006 wrx STi
If you have your heart set on 11's I would start with wrapping your DP/turbine housing. I would also port/polish your headers/turbine housing. Additionally weight removal is huge.
MartinSTi05 is offline   Reply With Quote
Old 06-13-2008, 12:19 AM   #8
lolawd
Member#: 176670
2006 30r STi on E85
Keep it G-14 Classified on these boards...
lolawd is offline   Reply With Quote
Old 06-13-2008, 04:20 AM   #9
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Add meth or a C16 tune and you might have a shot.
Weight reduction is your friend.
Dry ice too.
fujiillin is offline   Reply With Quote
Old 06-13-2008, 09:37 AM   #10
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
Dry ice too.
What would dry ice do?
cellgeek101 is offline   Reply With Quote
Old 06-13-2008, 10:05 AM   #11
drkramm
Member#: 159156
2007 wrx
wrb
a block of it sitting on your ic while your waiting to stage would suck alot of heat out of the ic
drkramm is offline   Reply With Quote
Old 06-13-2008, 10:57 AM   #12
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Or he could use an IC sprayer.
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 06-13-2008, 06:10 PM   #13
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
sotc
yourself.
As far as water spray is concerned, using liquids at a track isn't the brightest idea. Not to mention spraying your IC with warm water in staging isn't going to do squat.
On CO2 sprayers... I'd much rather grab a bit of dry ice and chill the IC.
Old 06-13-2008, 07:22 PM   #14
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
WRAP YOUR TURBO! Ceramic is OK, but Thermotec turbo wrap>>>>>>>coating. Search for Thermotec in the parts review forum for my review and others'....it's what all the cool kids are doing and since someone posted the link to the previously unknown ~$35 kit there, it's cheap as crap.
Old 08-02-2008, 07:54 PM   #15
VTGT
Member#: 132119
Has anyone on Nasioc maxed out the vf48 with injectors + FP+ and Fmic? I am curious to see those numbers.
VTGT is offline   Reply With Quote
Old 08-02-2008, 08:01 PM   #16
cpunlamd
Member#: 151360
2007 STI RIP
CZ4A/R35
The VF48 seems to be the best oem turbo out now. So I wouldnt look for a replacement just yet. Infact, for your purposes, the VF48 should be more than enough. TGV deletes are a must on any Suby (its just another bottle neck). And definately get bigger injectors. With the new mods you listed above, you should make about 330ish on that same dyno (on 93 pump)
cpunlamd is offline   Reply With Quote
Old 08-02-2008, 08:06 PM   #17
VTGT
Member#: 132119
I want this turbo on my 2005 legacy gt.
vf48 with injectors + FP+ Fmic +Kick ass tune = 330whp and nothing but smiles
Old 08-03-2008, 05:46 PM   #18
stamp32
Member#: 109688
2001 Gas Guzzler
Unfortunely, the Vf48 will not fit on you Legacy.
stamp32 is offline   Reply With Quote
Old 08-03-2008, 05:57 PM   #19
VTGT
Member#: 132119
With an FMIC any sti style turbo will
Back to my original question, has anyone maxed a vf48 out with all supporting mods including FP and Injectors.
Old 08-03-2008, 06:57 PM   #20
paikman
Member#: 43002
1990 BNR32 GTR &
2015 Evo X Final Edition
AutoPlaza Tuners Miguel ran a 12.2 with pretty much full weight 08 STi
He has TBE, Intake, tomei Header, his tune, 93 octane. That's about it.
Not sure how much the saabaru weighs, but I would say you have a good chance of getting low 12's as well,
as im not too sure how much dual AVCS tuning accounts for more power in comparison to last gens.
paikman is offline   Reply With Quote
Old 08-04-2008, 12:20 AM   #21
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Improving your driving will help out alot. I ran a 12.7 @ 107(1.80 60' ft) with only 296/326 on Jorges dyno. I don't know how hot at your track but it was 89 when I ran the 12.7.
Dirtyhobo010 is offline   Reply With Quote
Old 08-04-2008, 04:13 AM   #22
bloopsta26
Member#: 131371
05 buy my parts so
i can get my sti running
i have seen 12.8's on just a invidia dp this past weekend...soo i deff think a 11sec pass is attainable on the vf39. he plans on putting a few more things on it to see what he can do...here is what he plans on doing...soo just figuer 1 mod gets him to 12.8s all day...
fmic, 850cc injectors, a nice walbro, good header and uppipe/ external wastegated, alil meth and a protune by jorge. we will see what happens. i will post numbers from his dyno plot and when we get times i will post.. i deff think its attainable
bloopsta26 is offline   Reply With Quote
Old 08-04-2008, 04:51 PM   #23
CatfaceType-R
Member#: 81102
needs more turbo....you will have trouble hitting 11's without at least +335whp unless you are a great driver
i think you need more like +350whp though
get a big turbo and don't look back, dom 3 is the new(er) school subaru hottness turbo that i'm all about pretty much a 30r(rotated ball bearing turbo) in a stock location form; search 3076r turbos
CatfaceType-R is offline   Reply With Quote
Old 08-04-2008, 06:22 PM   #24
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
remove 1000 lbs and your there. lol
ahendrickson is offline   Reply With Quote
Old 08-05-2008, 11:57 AM   #25
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
I say get a tune for a shot of n20 ...but if your not launching the car hard to being with why are you wanting more power?
boostdog is offline   Reply With Quote
How much clearance can I get out of fender rolling? Carbon888 Interior & Exterior Modification 6 12-09-2006 11:57 PM
How much power can you get out of an STi? frank lipani Newbies & FAQs 21 11-20-2004 09:14 AM
How much power can you get out of a stock 6 speed? SooobieSnack Transmission (AT/MT) & Driveline 9 02-04-2004 10:02 AM
How much volume can you get out of the spare tire well? Kwyjibo Car Audio, Video & Security 12 05-06-2002 06:11 PM
How much power can I get out of a 94 Legacy turbo engine? AndrewT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-14-2001 08:16 PM
