Old 06-11-2008, 12:39 AM   #1
ironhead1230
Member#: 66419
2008 STI
Default 2008 STI boost gauge install - access through firewall
I am going to install an electronic boost gauge in my 2008 STI but cannot find a good place through the firewall to get to the engine bay.
I've searched and read through a lot of install write ups, but have not found any for the 2008 STI. I know a lot of people have used a grommet under the pedals, but I could not find anything in that area in my car. For anyone that has installed any type of gauge in a 2008 STI, where did you feed the wires through the firewall? Pics would be great.
Thanks
-Mike
ironhead1230 is offline   Reply With Quote
Old 06-14-2008, 03:47 PM   #2
ironhead1230
Member#: 66419
2008 STI
ttt. No one has installed a boost gauge in the 2008 STI? I see a number of grommets and rubber boots from the engine bay, but haven't been able to get access to them from inside the car.
-Mike
Old 06-14-2008, 06:22 PM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
take a coat hanger, straiten it out, and poke around.
some vehicles dont have an easy pass-through. sometimes there is a slight bend you have to make with a coat hanger.
i have done installs on a few cars that were a royal pain. u just need to play around a bit to figure it out.
jdubya301 is offline   Reply With Quote
Old 08-03-2008, 04:21 PM   #4
Leadfoot77
Member#: 74268
2013 STi
Did anybody find a good place for wiring through the firewall?
Leadfoot77 is offline   Reply With Quote
Old 08-05-2008, 10:18 AM   #5
factoryflood
Member#: 174082
2008 wrx sedan
pearl white
hey guys, have a 08 wrx, the easiest way is there is a passage all the way on the left(drivers side) from inside the car. You'll have to unbolt the wheel well, but the wires go thru there nicely and cant be harmed from heat or anything else so it looks mint. Not real difficult, just gotta look for it. Hope this helps.
factoryflood is offline   Reply With Quote
Old 08-11-2008, 07:54 PM   #6
INGUS
Member#: 182895
2008 WRX
Hi everyone,
I just got a '08 WRX and my first mod. was to install an updated custom boost gauge that I had designed for my Talon TSI a number of years back.
I went through the grommet on the passenger side firewall but I used a drill bit (by hand) to get through the tough part of the insulation in the passenger compartment. I also tapped in to the dash dimming control to have the display dim when you turn the lights on.
As soon as I am allowed to post pictures of the install I will put them here.
The gauge is a 30 segment LED bar graph spanning -9 to 20 PSI
INGUS is offline   Reply With Quote
Old 02-11-2009, 11:20 PM   #7
il09sti
Member#: 201513
2009 WRX STI
pics?
il09sti is offline   Reply With Quote
Old 02-12-2009, 01:10 PM   #8
Sb22284
Member#: 168386
I assume much didnt change from the 07 to 08 firewall.
First place i would try is by the foot pedals. Its super easy to get to if you jack up the car. Pop the rubber grommet off and push a hanger through the hole. You will see it exit by the steering shaft.
Second spot you can try is behind the IC. That is where subie ran my stock gauge wire. Its a bit more work as you have to take off the IC to easily get to it. You also have to do a bit of work to get at it from the inside of the car.
If you want i can take pics when my car gets back from the dealer =)
Sb22284 is offline   Reply With Quote
turbo timer boost gauge install w/ factory boost gauge Blakestyle521 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2004 10:19 AM
Boost Gauge Install on 04' STi artdoesart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-31-2004 01:43 AM
STi Genome boost gauge install help Specialist Electrical & Lighting 1 08-12-2003 10:25 PM
New boost gauge installation in STi, perfect match!! WorldOne Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-24-2003 12:10 PM
STI Genome Boost Gauge Installed ImprezaWRXDriver Bay Area Impreza Club Forum -- BAIC 5 10-21-2002 12:41 AM
