Old 03-01-2002, 02:26 AM   #1
Robmat
Member#: 2173
2000 2.5 RS
BRP
Question What parts are needed for Autometer Ultralite A/F guage install?
Is all wiring included, or will I have to buy the necessary wiring and O2 bung?
Robmat
Robmat is offline   Reply With Quote
Old 03-01-2002, 09:13 AM   #2
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
yes all the wiring is included, with instruction, and mounting bracket, Subaru's have 2 O2 sensors 1 in the front which is wide band and will not work the Autometer Air/Fuel gauge, but the one in the back which is right after the cat, that 02 sensor will work, but your not getting acurate readings because the cats clean up the exhaust.
AndyM is offline   Reply With Quote
Old 03-01-2002, 04:50 PM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
All you need is wires.
Here is installation:
http://www.geocities.com/matsut_rpi00/autometer.html
You have to hook it up to your rear O2 sensor wire at the ECU. It takes literally 10 minutes to install. Or, you can also install another O2 sensor and make the AF meter read that sensor instead.
tmat3 is offline   Reply With Quote
Old 03-02-2002, 07:31 PM   #4
Robmat
Member#: 2173
2000 2.5 RS
BRP
OK, here is the problem: I fabricated my own intake using aluminum tubing and also did the airbox mod creating a 3 1/4" intake all the way to the throttle body. Since the mod I have been eating gas like crazy. I wanted the A/F guage to monitor things. Is this really what I need and will the rear O2 sensor giv an accurate enough reading?
Thanks-
Robmat
Old 03-03-2002, 06:45 AM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
In a way, Yes.
I use my A/F meter to check how my catalytic converter is operating, because that's pretty much what the rear O2 sensor measures. I have a Ganzflow, K&N, and Stromung. My A/F meter reads right in the middle at stoich when going 55mph. When something goes wrong with the emissions, for example when my front O2 sensor died, the A/F meter read rich because the ECU adds a lot more fuel to the engine.
So, if you get this gauge, and cruise at 55mph at steady throttle, and the A/F meter reads rich, the engine probably is eating more gas than it's supposed to. The best gauge to tell if your engine is running rich or not is an Exhaust Gas Temp gauge.
Also, I would use a vacuum gauge (or a boost gauge) to check if your engine has a vacuum leak or not. If your engine lacks vacuum, the fuel efficiency goes down. A vacuum gauge is like a health meter for your engine.
what gaskets are needed for uppipe installation? ultraspdWRX Newbies & FAQs 9 01-08-2007 07:04 PM
What parts are needed to turbo a MAP sensored RS? Homemade WRX Normally Aspirated with bolt-on Forced Induction Powertrain 19 12-10-2003 12:21 AM
what parts are needed for 6spd? cronic Subaru Conversions 2 09-23-2003 12:51 PM
What parts are needed for Headgasket change? Cusco Service & Maintenance 3 05-24-2003 02:56 AM
what other parts are needed for turbo conversion halftendril Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-14-2003 12:57 AM
