Old 06-11-2008, 03:04 PM   #1
newbie-subie
Member#: 105944
2004 Impreza WRX
Java Black Pearl
Default HID Help (turns on for a second and stays off)
I need help!! So i just got these aftermarket HID's....Brand New. I installed them perfectly fine. Unplugged the DRL connecter. When I turn on the headlights....they would go on for like a split second and than it would turn off. It stays off and no light whatsoever! I turn off the headlight.....try to turn on again and same thing (flick on for a split second and turn off) and yes I know turning them on and off is bad for the balllast and bulb, but I was just testing to see if they even work. My guess is...there is not enough power going to the ballast than to the bulb. Maybe Bad Ground? I Grounded it where the stock bulb grounds. HELP!!! Thanks!
newbie-subie is offline   Reply With Quote
Old 06-11-2008, 05:26 PM   #2
chubbsub
Member#: 176944
06 STI
What brand are they? i have some zentec's that did the exact same thing
chubbsub is offline   Reply With Quote
Old 06-11-2008, 05:42 PM   #3
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
first of all, the best thing you can do is get rid of that HID kit. they suck.
they are not working because you have them connected to the stock wiring. subaru wiring is not made to handle the high load of hid startup.
this is why relay harnesses are recommended
jdubya301 is offline   Reply With Quote
Old 06-11-2008, 09:33 PM   #4
newbie-subie
Member#: 105944
2004 Impreza WRX
Java Black Pearl
Thanks all! Problem fixed.... the ballasts that I were using were defective. Got new ones ( full warranty) and worked just fine!
Old 06-12-2008, 01:52 AM   #5
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
yay. another HID kit blinding drivers on the road.
Old 06-12-2008, 05:50 AM   #6
newbie-subie
Member#: 105944
2004 Impreza WRX
Java Black Pearl
Looks like you didn't mention anything about HIDs blinding people on the road. Even though I angled the bulb downward. Nice Try. Also....it's all mounted to stock wiring and it works perfectly fine.
Old 06-12-2008, 07:40 PM   #7
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
For now
ptirmal is offline   Reply With Quote
Old 06-12-2008, 09:38 PM   #8
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
uhhhh what are you talking about..
they do blind people. and fail for pointing your lights down... now your bight as hell HIDS can light up a solid 2 seconds of road in front of you... thats a great lighting upgrade.
Originally Posted by ptirmal View Post
For now
exactly..
Passenger side HID dosent turn on Jrags87 Electrical & Lighting 4 09-03-2008 12:26 AM
passenger side HID doesn't turn on? ASpec818 Electrical & Lighting 10 05-11-2005 06:59 PM
HID operation: Turn on one at a time? Scooby Blue Electrical & Lighting 7 07-16-2003 09:24 PM
Oil light on for few seconds after engine started up. LeXisHfLiP Service & Maintenance 3 06-02-2003 09:19 PM
oil light came on for a second after oil change... is this normal? Poe Factory 2.0L Turbo Powertrain 3 01-28-2003 10:07 PM
Message Board Statistics All times are GMT -4. The time now is 01:52 AM.
