Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 06-11-2008, 09:08 PM   #1
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
WRB - It's mostly stock..
Default Electrical Grimlins
Update - I replaced the combo stalk for the headlight controls and removed my gauges, the problem still persists. I noticed that the speedo and odo stop working when I switch the headlights to "on" and star working when "off". The ABS light reacts the same way, but it also comes on when in Reverse, and my headlights turn off when in reverse. WTF is going on lol... anyone seen this before? Any suggestions? I have the FSM but these wiring diagrams are jibberish to me. Automotive electrical is not my thing. I just want to try everything I can before I have to take it in somewhere. Thanks
I have a couple things going on, and need some advice/help. It started off when my dash cluster, hvac, and radio lights went out. When my headlights were off I could see the radio light up and the odometer light on. when I switch the stalk on for the headlights the odometer light goes off and the radio readout dims down really low. I do have 3 gauges installed, but I have had them in for a long while now and they are operating just fine. Then the other day i noticed that my headlights were on all the time, even when the stalk is in the off position. And yesterday I noticed as I was backing into the garage that my ABS light comes on when I put the car into reverse, then goes back off once I take it out. Any help is appreciated, especially about the ABS light, as that one kinda bothers me.
Thanks
Wrx-WannaB is offline   Reply With Quote
Old 06-11-2008, 10:34 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There may be problem with the dimmer control module causing this trouble.
Old 06-13-2008, 10:49 AM   #3
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
Last night it got worse. I fired up the car and my abs light came on, and stayed on, without putting it in reverse. And I also had a CEL. My speedometer isnt working and my odometer has ceased to operate. Oh yeah, and my foglights wont turn on. I need some help, anyone have suggestions? I am desperate. Thanks
Old 06-13-2008, 11:10 AM   #4
Cougar4
Member#: 53443
Winestone
The CEL light may be on due to the problem with the speedometer. The speed sensor may be bad and this would explain a few things. Have the codes read to help with the diagnosis on these problems.
You might want to go over the ground wires under the hood and clean the connections. This may help solve some things like the ABS light turning on.
Old 06-13-2008, 12:00 PM   #5
ptirmal
Member#: 82243
07' Acura TL-S
11' Ducati Monster 796
I agree the CEL is most likely a speed sensor error. Did you mess with the stock gauges at all?
I would check the wiring for the gauges you installed, if something shorted out it could cause a problem like that. Run over that wiring and see if it helps, maybe even try just unplugging them or pulling their fuse and see if the problem subsides. If it doesn't then it's an OEM problem, the stalk seems the most susceptible to wear.
ptirmal is online now   Reply With Quote
Old 06-13-2008, 02:06 PM   #6
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
Thanks for the responses, I'll check that stuff. I didn't suspect the gauges i installed because they are working normal and are daisy chained into the Hvac/radio harnesses. I will look into them though. I appreciate it.
Old 06-13-2008, 02:28 PM   #7
Larc
Member#: 30920
2000 impreza RS
blue
Thanks
<removed my post becuase i got an answer... and i'm a noob, there is a button on the steering colomn which fixed my prob... not at all related to above. sry>
Larc is offline   Reply With Quote
Old 06-21-2008, 11:22 AM   #8
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
Update : Tore the dash apart and found nothing. I think some of the problem is just in the light stalk. So I will be replacing that soon. The CEL was from the speedo sensor which i just unplugged and it worked for about 2 days and has stopped again. But I have another problem now also, It seems I am hitting fuel cut at weird times in the power band and sometimes i get a funny idle. I really want to hit this thing with a sledge hammer...
Old 06-25-2008, 10:46 PM   #9
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
Bump, anyone got ideas? I need to replace the combo light stalk on the left side of the steering wheel. Dealer wants $100, anyone know which years are interchangeable or someone who has one they can let go? thanks
Old 06-26-2008, 02:05 AM   #10
Cougar4
Member#: 53443
Winestone
Before replacing the light stalk you should verify it is bad. I suggest you get a service manual to help you solve these problems. It will save you time and money.
Old 07-10-2008, 01:51 AM   #11
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
Updated first post... TIA
Old 07-10-2008, 04:59 AM   #12
Cougar4
Member#: 53443
Winestone
Part of the problem at least you are having sounds like a grounding problem. If you didn't follow the instructions I gave you in post 4, I suggest you do that. The problems you are having need to be tracked down by doing proper testing using a meter or light probe.
Old 07-10-2008, 06:09 AM   #13
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
yeah you need a multimeter and a little electrical knowledg asap. Otherwise youll be replacing good parts till the cows come home.
turboL is offline   Reply With Quote
Old 07-10-2008, 05:23 PM   #14
schrott
Member#: 164010
97 gfc sport
blue n' grey
HAHA AHAHAH AHAHHAHAHA......... you guys should read my post about 11 fuses....
wannab, i feel your pain.... this is weeks i have been trying to find out what i did wrong, and since i fix cars, bikes, and boats all the time, maybe its pride thats keeping me from taking it to a shop.....
please let me know what you find out, and by all means...... read my post, it sounds like alot of the same things....... except i did psyical damage to my car.
schrott is offline   Reply With Quote
Old 07-13-2008, 12:16 PM   #15
Wrx-WannaB
Member#: 113647
2002 Impreza WRX
The cel was for the speedo, but it works fine until I turn the stalk to the on position for the headlights. and the abs light only comes on in reverse. Which also shuts the headlights off. They come right back on, and the abs light goes off when I take it out of reverse. The speedo also stops working when the headlights are in the on position, when i turn it back(even while driving) it pops right back up to the speed I am going. I'll check the grounds again... I have a multimeter, any specific areas i should check first?
Old 07-13-2008, 01:05 PM   #16
Cougar4
Member#: 53443
Winestone
Lets check out the grounding for the headlights first. We first need to make sure that you are referencing to a good ground point before we start taking measurments. One way to do that is to check for voltage drops between various ground points. With the engine running and the headlights on, start checking ground connections between the negative battery post and the negative battery clamp. Set the meter to read DC voltage and see if there is any voltage between those points. Since they should be tied together with no resistance between them there should be no voltage difference. If you have no voltage there then move the probe on the battery post to the chassis ground. Make sure there isn't any voltage there either. Keep one probe on negative battery lead and then check the engine ground the same way. You keep moving around from known good test points. The ground problem may be in the dash area so you may need to make a ground lead extension to work from the nagative lead of the battery so you can measure points inside the car. You can also make other ground points your reference point as long as you know they are good compared to the battery ground connection.
I am assuming you have a digital meter to make the checks with so you don't need to keep track of polarity on the meter probes.
