Old 06-12-2008, 05:53 PM   #1
meatling
Member#: 179655
2007 WRX TR
Urban Grey Metalic
Default wiring I/c sprayer
I have asked this in the meth/sprayer section and not much luck so here we go. I purchased an intercooler oem pump, tank and wiring, sprayer and the switch. I have a wrx 07 so there is no harness. Do I need to use a relay or is there already one in the pump? Can i just vampire clip all of the wires in my fog lamp harness? The power, ground, illumintion and ground? ( I do have a fog switch for the fog ligjhts that came with the car so it is a used harness.) My electrical skills are not the best and none of the posts talk about an oem tank/pump. They are mostly using wagon bottles or some aftermarket stuff. Thanks for any help you can give me on the wiring. I did check out the posts by peaty and big wrx. http://www.clubwrx.net/forums/engine...r-sprayer.html and
http://www.scoobymods.com/forums/showthread.php?t=3642
meatling is offline   Reply With Quote
Old 06-12-2008, 06:48 PM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Clubwrx link no work. Also interested in wiring.
Old 06-12-2008, 08:35 PM   #3
ptirmal
Member#: 82243
07' Acura TL-S
You don't need to use a relay. Just wire the pump + to the battery (fused) and the - to the switch, then ground the switch. The non oem part is it can be used with the car off. If you use a relay and tap into the ignition and wire the switch in then you will not be able to use it when the car is off (how it should be).
You shouldn't vampire the fog switch power and ground, the illumination and ground for the switch would be ok to tap though. Plus you wouldn't be able to spray if you had your high beams on, lol.
ptirmal is offline   Reply With Quote
Old 06-12-2008, 09:58 PM   #4
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Any wiring diagram?
Old 06-12-2008, 11:31 PM   #5
redrexmeister
Member#: 111692
04 wrx wagon
I believe STI workshop manual should have wiring diagram. I got one for $15 on the e-Bay, comes prety handy. I'll check it for you, as I wanted to do the same retrofit.
redrexmeister is offline   Reply With Quote
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 03:32 PM
help wiring windshield sprayer button to the ic sprayer button woodys77 Electrical & Lighting 5 04-22-2009 12:29 AM
Wiring a 2004 I/C sprayer in a 2002 WRX? Rizzo314 Electrical & Lighting 12 07-11-2004 07:54 PM
Wiring for STI IC Sprayer Switch/Tank adeliciouspizza Electrical & Lighting 2 04-08-2004 05:24 PM
In search of a switch hot wire near IC sprayer switch. StiDreams STi Forum Archive 3 09-07-2003 09:35 PM
