Old 06-12-2008, 09:04 PM   #1
shanks9sti
Member#: 144947
2010 Mazda 3 sport
Default stock STi block
does anyone know how much it would cost to rebuild the stock ej25? i lost compression in the third cylinder and i just wasnt sure how much it would cost, or how much i could even sell the block for...
shanks9sti is offline   Reply With Quote
Old 06-13-2008, 03:29 PM   #2
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
That's a hard one to guess, because there's no way of knowing what the damage is until you take it apart. It could be as simple as new pistons and bearings, or it may have a borked cylinder wall.
bluescoobywagon is offline   Reply With Quote
Old 06-13-2008, 05:03 PM   #3
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
If it turns out that you cracked a piston, don't rebuild with stock ones. You can get forged pistons for a little more money and the block will be a lot stronger. If it is just the piston expect a cost somewhere between $4000-$5500.
jbwrx is offline   Reply With Quote
Old 06-13-2008, 05:22 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Pistons and rings $600
new bearings $150 (if needed)
Honing $50-100 (if needed)
Crank grind $80-150 (if needed)
Various seals and gaskets $250
your labour
Thats pretty much it.
Old 06-13-2008, 06:11 PM   #5
bluescoobywagon
Member#: 14911
Not A Wagon!
During a rebuild you should also change the timing belt, water pump, t-stat, and oil pump. The price will vary depending on how much you do yourself. If you don't do any of the work, jbwrx is probably pretty close.
Old 06-13-2008, 06:30 PM   #6
icslowmo
Member#: 114667
00/5 Silver STi RS
FAT 40R kit w/ FMIC
$4k-5.5K is way too much. Just buy a new Sti short block from Subaru ~$1,900 and new forged pistons $450-550. Have bores checked and sized for pistons (like reddevil said) $50-150. Total ~$2,700 and you should be good for at least 400whp..
icslowmo is offline   Reply With Quote
Old 06-13-2008, 06:44 PM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
That's at a minimum if you're going to use drop in pistons which I don't recommend. If you're going to bore and hone you have to split the case and that adds at least $250 for new gaskets and seals + labor if you have a shop do it. That takes you to a little over 3k just for parts and machine work and if you have a shop do all the work at a minimum you'll pay $2K in labor so $5K
+ was about right if you don't plan on doing all the work yourself.
Old 06-13-2008, 06:50 PM   #8
shanks9sti
Member#: 144947
2010 Mazda 3 sport
alright well heres the deal, its not something i was really looking to rebuild, i already sold my sti that i had put a cobb short block into, i just have the block lying around and wanted to get rid of it pretty much. but my friend offered me $100 for it which seems kind of ridiculous to let it go for that, i know it needs work but im not just going to give it away. i know theres nothing wrong with the pistons, but the guy who took it apart said honing out the cylinders would be enough, but then it needs oversized pistons right? anyways i basically just need to get rid of it, but its kind of hard to do when im not sure how much work it needs, if anyone is interested let me know
Old 06-13-2008, 07:50 PM   #9
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
Considering I am on my 3rd motor, the estimate is pretty accurate.
Old 06-13-2008, 08:01 PM   #10
shanks9sti
Member#: 144947
2010 Mazda 3 sport
hm...ok
Old 06-14-2008, 02:35 AM   #11
Jhovany
Member#: 137317
2006 STI
Rally Blue
Yeah just buy a whole new STI shortblock (just like mentioned above ~1900) EVERYTHING should be around $4000 area if you are going to have a performance shop do it all for you!!!! And I do mean EVERYTHING
Jhovany is offline   Reply With Quote
Old 06-14-2008, 07:13 AM   #12
bluescoobywagon
Member#: 14911
Not A Wagon!
If the cylinders, crank, and rods are intact, then $100 is a stupid low price. At a guess, you could probably sell the parts for $600-700.
Old 06-14-2008, 09:51 AM   #13
shanks9sti
Member#: 144947
2010 Mazda 3 sport
alright i'll probably just put it up on ebay then
Stock STI block... Jason_STI_05 Private 'Wanted' Classifieds 3 10-10-2006 11:12 PM
Gruppe-S GT30 .82 AR on 98 octane - 404whp on stock STi block BLUE STINGER Proven Power Bragging 59 04-21-2006 01:53 AM
Stock STI Block Time Attack Test 2 Element Tuning Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 71 12-09-2004 01:37 PM
Weak points of the 2.5l stock STi block? neversatisfied Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 91 09-24-2004 12:51 AM
427whp with stock STI block. sponaugle Proven Power Bragging 95 03-13-2004 04:28 PM
