Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-13-2008, 01:22 AM   #1
b-man1
Member#: 165353
2000 2.5 rs
white
Default Boost controller question
Hey guys, I'm turboeing my RS and decided it would be a good idea to put in a manual boost controller so that I could turn it down from time to time, making my engine last longer. I've been sitting on this huge pile of parts for a while now which gave me time to think, perhaps too much. I was planning on t-ing into the wastgate line and t-ing into that again for a boost guage. My question is:
Will opening the MBC drop boost from say 6 to 5 psi? Or take pressure off of the wast gate causing manifold pressure to actually rise instead even though the gauge would read less?
If I'm over-thinging this then let me know. Thanks!
b-man1 is offline   Reply With Quote
Old 06-13-2008, 01:50 AM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
The less air going to the wastegate the higher the boost will be. As for putting the boost gauge there you will only get wastegate pressure showing not the actual boost in the intake manifold, for that you need the boost gauge T-ed into the BPV...
wrxdrvr is offline   Reply With Quote
Old 06-13-2008, 01:58 AM   #3
b-man1
Member#: 165353
2000 2.5 rs
white
I see...so when people tell me that my car can only handle 5 or 6 psi, what are they talking about?
Old 06-13-2008, 02:07 AM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I don't know, but on my wrx wastegate pressure is about 7 Psi that is the max my boost gauge showed when I hooked it up at the turbo... When I moved the gauge to the BPV it showed 13.5 Psi that was actually in the intake manifold.
Old 06-13-2008, 02:26 AM   #5
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
say buh bye to your motor noob.
AWDWRXLOVER is offline   Reply With Quote
Old 06-13-2008, 02:53 AM   #6
b-man1
Member#: 165353
2000 2.5 rs
white
Thanks for the help man
Old 06-13-2008, 06:19 AM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I'm moving this, but let me caution you...you need MORE help before you do this as you haven't researched enough. "turning down boost" is like putting a bandaid on arterial bleeding.
Old 06-13-2008, 11:26 AM   #8
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
b-man1. Your motor (I assume is a stock EJ251) will do just fine at 6psi if you meet several guidelines.
- Upgraded fuel pump
- Get some sort of EM system that will let you adjust timing AND fuel. There are some pretty inexpensive ones out there that will allow this. Look into Emanage.
- Get it tuned properly. Meaning you should not be seeing any knock anywhere in your datalogging.
- Use the search here on Nasioc. I'm sure this has been covered before. Also, check rs25.com which is solely for GC owners.
Wedge is offline   Reply With Quote
Stock Boost and Boost controller question benibarra23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-15-2010 10:13 PM
boost gauge/boost controller question scoobaru_wagon Newbies & FAQs 9 04-30-2005 10:37 PM
manual boost controler question bttune2.5rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-30-2001 07:26 AM
More boost controller questions.... Obscure411 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 05-15-2001 11:15 AM
Boost Controller Question Steve E Technical Forum Archive 9 10-11-2000 02:58 PM
