Old 06-13-2008, 05:19 AM   #1
JohnB3453
Member#: 47540
1996 Lancer Evo 4
Default injector type and size questions
I don't know if I am in the correct forum... I am running in a 2002 2.5rs with a usdm sti block with forged internals, stock RS SOHC Heads, Stock RS intake manifold with Perrin topfeed fuelrails, stock topfeed injectors, and a Borla NA header. Eventually I want to turbo the car. Currently I am trying to purchase all supporting fuel mods that will be needed to run the turbo. Will any STI or WRX topfeed injectors fit?
JohnB3453 is offline   Reply With Quote
Old 06-13-2008, 11:32 AM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
I'm not sure about the fuelrails you have, however, since you are still running your stock injectors, I would think any other top fed inj would work.
If this is the case, go purchase some used stock WRX injectors, uncap them, have them cleaned and flowtested, and you will have about 800-840cc injectors for cheap. This is the setup that I have been running for the past 3 years or so.
Here is more info if you need it : http://forums.nasioc.com/forums/showthread.php?t=478921
Wedge is offline   Reply With Quote
Old 06-13-2008, 11:09 PM   #3
front runner
Member#: 121603
2001 legacy BH
blue
I'm running DSM 440 cc low impedence injectors that i got for free. Good up to 280 horses. Though, it cost me $1.50 for resistors and solder. And to answer your question, US spec sti's are side feed and don't fit. Go with the top feed wrx or sti pink injectors.
front runner is offline   Reply With Quote
Old 06-15-2008, 02:57 AM   #4
JohnB3453
Member#: 47540
1996 Lancer Evo 4
Thanks for the info
SMC Jet placement for FMIC and size question roybfr Water/Methanol Injection, Nitrous & Intercooler Cooling 1 07-06-2006 05:38 PM
tire band and sizing question... gizmodude311 Tire & Wheel 17 05-30-2006 03:34 PM
Lowered car tire advice and sizing questions Squirl Tire & Wheel 0 05-05-2006 10:55 AM
What type and size of spark plugs? Tork1 Service & Maintenance 4 02-25-2005 10:34 PM
What's the type and size of the ABC "tool" for adjusting boost? jefersun Engine Management & Tuning 3 01-20-2005 04:57 PM
