Old 06-13-2008, 07:42 AM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Default OOOOGA Horn questions
Hey everyone I just bought one of these and installed it. i was wondering if I need a relay? Some people say I do but they don't know why. Does it make it louder?
The other question I have is "Where have you all mounted your horn? I took the windshield washer fluid out and mounted it there.
Thanks for helping
emsmap is offline   Reply With Quote
Old 06-13-2008, 09:22 AM   #2
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
can anyone help me?
Old 06-13-2008, 09:40 AM   #3
ptirmal
Member#: 82243
07' Acura TL-S
I just googled it for an image, it looks like only one horn right? Some people mounted airhorns near the foglight, if you remove the panel right under it you can see you have room in there. Then there is the snorkel fender area (if you have an intake)... Are you going to get a smaller washer fluid tank?
What are those horns rated at? I believe stock is around 105db, if they're around the same it'd be safe to say they aren't drawing any more current and can be used with the stock wiring. 110 or higher and I would use a relay because it will more than likely sound louder.
ptirmal is online now   Reply With Quote
Old 06-13-2008, 10:32 AM   #4
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
yea it is rated at 112. I dont have another washer fluid tank. i am running without one. I might have to get a relay because I heard they are louder with it.
Old 06-13-2008, 10:54 AM   #5
ptirmal
Member#: 82243
07' Acura TL-S
Can you pass inspection without it? Not a big concern to others but I would never get rid of it, fear of needing it and not having it.
Just get the relay, materials are cheap.
Old 06-13-2008, 01:37 PM   #6
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
yeah you can pass. Anyway where would the relay hook up at?
Old 06-13-2008, 02:13 PM   #7
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
any other suggestions on the relay?
Old 06-14-2008, 12:19 PM   #8
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
i mean... its a relay. theres not a whole lot too it.
i guess just make sure you use adequate gauge wiring.
ProdriveDreams is offline   Reply With Quote
Another Hella horn question 03MBP Car Audio, Video & Security 27 01-30-2005 05:29 PM
Strut bar/alarm horn question decolory Brakes, Steering & Suspension 19 02-23-2004 12:55 PM
Installing Hella Supertone Horn Question keithja Car Audio, Video & Security 9 01-02-2003 02:15 AM
Horn question ratboy Interior & Exterior Modification 12 01-19-2002 10:49 AM
Horn Question ratboy Interior & Exterior Modification 8 04-19-2001 08:23 AM
