Old 06-13-2008, 09:50 AM   #1
16gsuby
Member#: 150696
2005 WRX
white
Impreza WRX how to make power?
i want to make 400whp on a ej205? What are the supporting internal mods I need? I know i need pistons, but will the rods hold?
16gsuby is offline   Reply With Quote
Old 06-13-2008, 10:48 AM   #2
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
uhhh....
1 forged pistons
2 new rods
3 new crank
4 valve train is fine but is a bit restrictive so an upgraded valve train would be good.
5 turbo back exhaust,
6 FP green turbo or larger
7 injectors 800cc or larger
8 upgraded tranny to support the power, and clutch
9 exhaust manifold and up-pipe
10 intake, CAI
thats just some of the things you need to do theres more trust me
03WRX-WRB is offline   Reply With Quote
Old 06-13-2008, 11:31 AM   #3
16gsuby
Member#: 150696
2005 WRX
white
I'm talking about internals only, I know the bolt ons, but will I have to upgrade the rods or are they reliable for 400whp,I'm planning to pnp heads and get stage 2 valvetrain to help with air.
Old 06-13-2008, 01:05 PM   #4
silverongold
Member#: 132599
02 impreza wrx
crank could handle it right?
silverongold is offline   Reply With Quote
Old 06-13-2008, 01:31 PM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
The crank can handle it as well as the rods as long as tuning and fueling is great. If you have access to a very reputable tuner then you could probably get away with just a piston swap.
I wouldn't take any chances. A set of CAT Rods can be had for $300 on ebay.
MY99 2.5GT is offline   Reply With Quote
Old 06-13-2008, 04:06 PM   #6
Dantes Inferno
Member#: 126027
ej22t will run 400whp on all stock internals, maybe its a cheaper route.
- well ported 2.5 SOHC heads, delta 220 cams
- sti yellow side feed injectors / fuel rail
- wrx 2.5 intake manifold
- maybe something like a vf43
- a good engine management system
- tune it well
Dantes Inferno is offline   Reply With Quote
Old 06-13-2008, 05:26 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by 03WRX-WRB View Post
uhhh....
1 forged pistons
2 new rods
3 new crank
10 intake, CAI
are you serious?
Aside from supporting mods (exhust, fmic, fuel, turbo and tune)...pistons, rods (for insurance as EJ205 CAN but are at limit), I always suggest a cam and at least springs while people are in there. Simply because of the top end gains that can be picked up. Port work is time consuming = $$$
Old 06-13-2008, 05:31 PM   #8
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
- tune it well
There is no way a VF43 is going to get you 400 whp on its own. Even if you add meth you won't get there.
jbwrx is offline   Reply With Quote
Old 06-13-2008, 06:29 PM   #9
16gsuby
Member#: 150696
2005 WRX
white
so i'm guessing the rods could take it, but it would be insurance for my motor. i don want so much lag so i'm guessing a pnp 20g
Old 06-14-2008, 12:11 AM   #10
03WRX-WRB
Member#: 167879
2005 Impreza
midnight blue
Originally Posted by Homemade WRX View Post
are you serious?
i was just simply stating that a crank can be a good idea, it does NOT by any means have to be changed if you want a car that can handle well past 400whp the crank would be a good idea
the rods can hold 400whp in the 2.0 the pistons/rings are the weak point. the crank bearing can be a weak point to if you lack oil.
i just tour down my motor and my cyl 4 was toast top ring melted closed, 2nd ring broke in 10 pieces and the piston broke 2nd and 3rd ringlands
but really you need a good reliable tune
How to make HKS Silent Hi Power more rumbling sound? The_Bang Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-03-2007 04:46 PM
How to make mechanics stick to their quotes ? il96 Tri-State Area Forum 3 05-07-2003 02:36 PM
How to make your car handle to your liking Eric SS General Community 4 11-10-2001 05:34 PM
How to make close to 300hp on the WRX? SiriBX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-04-2001 04:53 PM
I need help i want to know how to make my subaru faster? impreza_power Technical Forum Archive 25 09-07-2000 10:07 AM
