Old 03-01-2002, 03:25 PM   #1
DeanO
Member#: 3715
Default Help! Does the STOPTECH front brake kit fit 17" UK OEM wheels?
I recently upgraded to the silver 17" UK OEM wheels (53 mm offset) with Michelin Pilot Sports (215/45/17). I had a great buying experience with Dan at Vivid Racing.
Now I'd like to upgrade to the STOPTECH front brakes. Tech support at STOPTECH offers a fitting template and it appears as though there is only about 2-3 mm between the STOPTECH calipers and the inner aspect of the Subaru 17" wheels. It SHOULD therefore fit, but I'm concerned.
Has anyone ever upgraded to the STOPTECHS and the 17" OEM wheels? I'd rather avoid using any spacers or shave the calipers.
Any help is appreciated.
Dean
2002 WRX Wagon
DeanO is offline   Reply With Quote
Old 03-01-2002, 03:30 PM   #2
Zahnster
Member#: 2918
2002 Impreza WRX
Silver Sedan
From what I've gathered in similar circumstances, 2-3mm is pretty decent clearence. I've heard of much worse.
I'm by no means an expert on this. What does stoptech have to save about 2-3mm of clearence?
Zahnster is offline   Reply With Quote
Old 03-01-2002, 06:42 PM   #3
bgsntth
Member#: 3441
05 OB XT
Blk
FWIW, I doubt I have 2-3mm clearance with my P1s. In fact, I had to have the wheels rebalanced because the stick-on weights did not clear the calipers. The brakes are huge.
bgsntth is offline   Reply With Quote
Old 03-01-2002, 08:34 PM   #4
duckboy
Member#: 6243
2004 XT
hi-yo silver
Default clearance
i have the stoptechs on my wrx w/ gtones. but previously i had my stoptechs on with P7's and kumhos. the clearance w/ the P7's was very close. about 2-3 credit card thickness gap. couldn't really measure the gap any other way. it was close but nothing ever came in contact. stoptech was aware of this. infact my car was used to tool-up off of and used for testing.
i also ran the car on the track several times and nothing happened. should the tires been better (race rubber) i don't think the results would have been any different. the greatest loading case is for the outside wheel when in a turn, and under those load conditions, the spokes that are currently at the top of the wheel (nearest the brake caliper) would be (in theory) bending away from the caliper, thus creating more clearance. so, even in theory, dynamic clearance shouldn't be a problem. in any case, my P7's were stout wheels and did not hit w/ 2-3 credit card thickness clearance. i'm rambling...
hope this helps...
duckboy
duckboy is offline   Reply With Quote
Old 03-01-2002, 09:23 PM   #5
DeanO
Member#: 3715
Thanks for the replies so far.
Zahnster,
STOPTECH recommends adding 2mm to their template measurements, just in case.
bgsntth,
I think you're right. 2-3mm of clearance may be enough.
Duckboy,
I just bought a vernier caliper from Lowe's and 2 credit cards stacked together is very close to 2mm.
Well, using STOPTECH's caliper template, there should be at least a 62.3mm clearance from the outer face of the stock caliper to the inner face of the front wheels.
I measured 69mm using a vernier caliper.
Therefore, I've decided to go for the STOPTECH kit. I may be the first guinea pig to try it on 17" UK OEM wheels, so wish me luck.
Dean
Old 04-28-2002, 11:58 AM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Deano,
So...did the UK OEM wheels fit?
Thanks,
Tim
mav1c is online now   Reply With Quote
WRX Stoptech Front Brake Kit subieside Private 'For Sale' Classifieds 25 06-28-2004 08:32 PM
Austin, TX: Silver 17" UK OEM wheels & misc for sale TriniTuner Private 'For Sale' Classifieds 16 01-09-2004 07:34 PM
Going rate for 17" UK OEM wheels? mbakercad Tire & Wheel 9 12-31-2003 01:59 PM
CA: Stoptech front brake kit gt3000fa Private 'For Sale' Classifieds 5 12-14-2003 04:46 PM
Cheapest Price for 17" UK OEM Wheels?? SoLiDbReAkZ Brakes, Steering & Suspension 35 07-15-2002 06:49 AM
