Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 06-13-2008, 06:51 PM   #1
Member#: 172610
2008 STI
Default Recommended 08 STI Tire Pressure
Just picked my car up from dealer for its first visit. Running stock BBS rims with stock Dunlop tires. Car rode better than when i dropped it off. I was running at recommended pressure in door jam but it appears they pumped the pressure up to 42 front and 40 rear. What are you guys running at for street driving?
RallyKenSr is offline   Reply With Quote
Old 06-13-2008, 07:31 PM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
Test it. Run from about 30 psi up to max (assume 51 psi) in small increments of maybe 5 psi. Look for a couple things. One, if the pressure is too low, the tires will feel a little squishy. You want to be above this point. Two, if the pressure is too high, the tire may balloon up and start running only on the center of the tread. The steering will lighten up, and the whole car will start to feel a little skitish/darty because it's only running on the center area of the tread. As well, if the pressure is too high, the tires can stiffen up too much and start to get a little extra bouncy over bumps in the road, more thump, thump, and you being able to feel the tire leave the road surface. You'll want to be below this too high range and above the too low range. Where this is depends on the tire and your personal preference some.
WTB: 08+ STi tires or ANY 245-40-18 tire Rwu00313 Private 'Wanted' Classifieds 1 01-12-2010 06:22 PM
Recommendation on winter tire pressure pls!!! Randz Tire & Wheel 3 12-05-2007 03:04 PM
Recommendations for wireless tire pressure guages ecasirhc Interior & Exterior Modification 0 02-15-2005 06:07 AM
STi tire pressure for track days? WRC-STI Tire & Wheel 2 02-12-2004 01:58 PM
STI Tire Pressure ? stiguy Tire & Wheel 5 10-28-2003 12:54 PM
