Old 06-13-2008, 07:12 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Alky / Water injection Nozzle install on FMIC
Since I couldn't find any good info on how to do this, I thought I'd do a quick writeup to help out others who are in the same boat.
So let's do this
1.) take you nozzle to a home depot or autozone and find out what size bolt and what pitch the thread is. Mine was a m10x1.0, which is not common.
2.) Go to http://www.shender4.com/thread_chart.htm and find what size drill you will need for your tap.
3.) source the drill and tap, I had to get mine on ebay because no one carried that thread pitch.
4.) Find a good spot for the install, I did it before the bend because I read you want 6-8" before the TB
5.) Score the spot with a dremel with carbide bit to make sure you drill won't skip around
6.) Drill with a tiny bit and progressively make the hole bigger.
7.) Get the tap setup and be careful with it. Don't press to hard, but apply some pressure until it catches
8.) Test fit your nozzle
9.) I took the nozzle assembly appart to make sure I don't overtighten any thread on the assembly. Then I Teflon taped the thread going into the pipe. Hint: Wrap the tape in the opposite direction of that tap, that way when it starts getting tight, the torque will tighten the tape rather then loosen it
10.) Tightly installed nozzle
Bad Noodle is online now   Reply With Quote
Old 06-13-2008, 07:12 PM   #2
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
11.) Assembly installed
12.) All done
Old 06-13-2008, 08:38 PM   #3
lev98
Member#: 140529
01 Ferrari 360 spy
Nice write up I am going to be taping mine soon.
lev98 is offline   Reply With Quote
Old 06-14-2008, 04:30 PM   #4
vulpina
Member#: 131903
GC8 PPG EJ25 GT3082
dark blue 95H
i would add a flange to have more material for the tap.
It look like it hold on very lightly , i would be concerned for leak after time .
vulpina is offline   Reply With Quote
Old 06-14-2008, 04:46 PM   #5
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
i completely agree, but I don't have any welding equipment and wouldn't trust a local place.
but honestly, it's in there nice and tight, but I will check on it every once in a while to be sure. I will also pressure check the entire system tomorrow to be sure it's all good
Need help selecting water injection nozzle? lsaltsman Water/Methanol Injection, Nitrous & Intercooler Cooling 12 04-20-2010 01:35 AM
m15 and m10 alky/methanol injection nozzles - inside mount arrowscooby Engine/Power/Exhaust 1 05-01-2009 08:25 PM
SMC METHANOL/ALKY/WATER Injection Kit anthonyrb98 Engine/Power/Exhaust 12 09-19-2007 07:46 PM
Water injector nozzle install with FMIC Question ninjaboy76 Water/Methanol Injection, Nitrous & Intercooler Cooling 2 07-30-2006 12:36 AM
Water Injection Nozzle location WhiteKnight Water/Methanol Injection, Nitrous & Intercooler Cooling 23 11-16-2005 02:16 PM
