#1 |
Member#: 166500
Vehicle:'01 RHD Evo 7, 92 Skyline GTR |
in the midst of doing my up pipe i broke a rubber hose. it runs from the intake to this solenoid and that solenoid goes the the wastegate/turbo. it broke from the part from the intake to the solenoid. if i drive whats going to happen and can i replace this with any hose or should i just wrap it and itll be alright
heres pics ![]() ![]() ![]()
#2 |
Member#: 44256
Vehicle:2002 WRX Wagon |
I would recommend you not drive the car...
Buy a vacuum line extender or new line... If you have trouble, let me know - Im local and have both of those parts... |
#3 |
Member#: 15652
TXIC
Vehicle:2002 2.5L WRX Wag. 160K club |
it is the factory boost control line. word to the wise, make sure the hose you replace it with is the same size on the inside as the factory one. otherwise it will affect the cars ability to control the boost. granted, it will still control it, but it may(most likely will) spike and bounce around more.
this happened to me when I decided to replace all the hoses becasue they were hard and cracked just like yours. I have been able to somewhat tune it out, but it sucked. I could not find the exact same hose at the store, so I just tried to get close. you may try to get one of the hose nipples in there, but mine was so hard it just kept splitting. |
#4 | |
Member#: 166500
thanks alot for the info would i be able to buy it at the dealer or something? |
#5 |
Member#: 126042
SWIC
Vehicle:2004 W Ŕ X PSM |
HAHAHA I broke this on my friends car when we swapped the turbo. FWIW He just went to Kragen and replaced it with a similar size hose and the car runs great. The car has been tuned since then and there was no problem with controlling boost. IIRC, that hose is hard (hence why its so easy to break) yet my friend replaced it with a normal flexible hose.
| Thread Tools | |
| Display Modes | |
| what is this and what does it do? | Russ77 | Factory 2.0L Turbo Powertrain | 5 | 09-22-2005 01:00 AM |
| Firefox: What is it, and why did I just download it? Am I screwed? | poison | Off-Topic | 19 | 08-31-2005 07:36 PM |
| CEL came on while changing coolant- what is it and will it go away without scanning? | thrdeye | Service & Maintenance | 7 | 03-29-2004 05:02 PM |
| Just installed my up-pipe & DP and..... | SuperSubie81 | Factory 2.0L Turbo Powertrain | 2 | 06-17-2003 05:41 PM |
| ('93-'01) what is this and what does it do? | shimstock | Impreza Forum | 4 | 04-10-2001 09:53 AM |
