Old 06-14-2008, 09:55 PM   #1
witte1919
Member#: 153066
2001 Impreza 2.5rs
Default who has or is running a RRFPR with there turbo set up
everything is on my car besides the FMU and the voltage clamp, not sure how to install both of them. i know what has to to where on the fmu, just not sure where to put it, and as far as the map sensor goes for the voltage clamp, not sure which wires go where, which one is the flow in and flow out?
witte1919 is offline   Reply With Quote
Old 06-15-2008, 12:09 AM   #2
witte1919
Member#: 153066
2001 Impreza 2.5rs
anyone?
Old 06-15-2008, 12:16 AM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
dude rising rate fuel preasure regulators are only good if you are just trying to raise fuel preasure even more (AFTER you've got a good tune with higher flowing injectors and engine management running)
I would highly advise against using one unless you have the above.
is that a FAT kit ??
IllNastyImpreza is offline   Reply With Quote
Old 06-15-2008, 11:38 AM   #4
witte1919
Member#: 153066
2001 Impreza 2.5rs
yes its the fat kit, with the voltage clamp and rrfpr, this is temporary set up for 2 weeks till i get the emanage
Old 06-16-2008, 08:42 AM   #5
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
I used one on my ej18t setup before i got sti 550cc injectors. RRFPR's are a sad excuse for a fuel system. The car improved 100% when I got bigger injectors and took the RRFPR off.
turboL is offline   Reply With Quote
Old 07-01-2008, 10:53 PM   #6
WickedRydaX
Member#: 31900
X2, I wish I had a better fuel controller then the field FC.
MCL
WickedRydaX is offline   Reply With Quote
Old 07-02-2008, 01:19 AM   #7
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
even if the RRFPR worked BETTER than bigger injectors.... I still don't trust the only thing keeping my car stoich being a pretty blue ball with a vacume line connected to it
('93-'01) Who is running Sparkco Plugs in there rs 2.5rsMI Impreza Forum 4 09-03-2004 07:09 PM
New Video of my car with the turbo set up. In car and out of car STEALTH-WRX Proven Power Bragging 52 08-19-2004 02:58 PM
Who has the longest running TXS Stage 4, and how is it running? xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-16-2002 10:43 AM
SAFC or a RRFPR ? with a turbo yebokmj Normally Aspirated Powertrain 8 10-29-2000 12:31 AM
