Old 06-14-2008, 10:52 PM   #1
Venividivichi
Member#: 176793
2009 pontiac G8
black
Default boost gauge install question
i bought a red racer defi boost gauge and it refuses to read the right boost, or read any vacuum. im unsure if i tapped the wrong line as i have tapped 2 different ones and i used the accessport to read my boost. everything appears to be working according to the accessport but the boost gauge never goes above 11ish and never ever has read any vacuum pressure.
any ideas?
Venividivichi is offline   Reply With Quote
Old 06-14-2008, 10:58 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
So where exactly are you tapping for the gauge sensor? To get proper readings you need a direct manifold connection, the best place to get this is the vacuum line to the factory bypass valve.
Old 06-15-2008, 01:37 AM   #3
Venividivichi
Member#: 176793
2009 pontiac G8
black
oh i used the vacuum lines off the boost control unit
Old 06-15-2008, 01:50 AM   #4
Venividivichi
Member#: 176793
2009 pontiac G8
black
yeah i tapped the wrong line...stupid install instructions
Boost gauge install question ScubieTheFierce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-24-2003 05:14 PM
OEM boost gauge install - question WRXVII Service & Maintenance 6 12-08-2002 03:51 PM
Another boost gauge install question FastRedWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-14-2002 05:52 PM
Boost gauge install question Tex-WReX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-07-2001 12:42 AM
