Old 06-15-2008, 01:49 PM   #1
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
09 triumph daytona 675
Unhappy ej25 hybrid random plug!?!?
hey guys, I have a hybrid build and this is my problem and its driving me insane. There is a hole on the block directly under the throttle body. i used to have it plugged but then I assume there was soo much pressure built up that the oil going through the oil return line got pushed back up and later blew the turbo. I got a new turbo, and what i did was take the breathers from the cylinder heads, the pcv, and this random plug and ran them into a catch can... then vented to atmosphere... THERE IS SOOO MUCH PRESSURE THAT COMES OUT OF THIS THING!!! not to mention oil.... the catch can is say about 20oz, and it was 1/3 of the way full after a 20 minute drive with minimal boost. please help me out... I believe i am having lots of blow by but I need to confirm it with a leak down test. I really dont want to spend 4k on a rebuild... Im broke!
heres the main quesion(s)
- what does this pluggy thing do?
- can i plug it up or should I route it to a catch can
- what are your thoughts on the fried rings?
mannyOlicious is offline   Reply With Quote
Old 06-15-2008, 02:27 PM   #2
Silver Ra
Member#: 123143
03 wrx 08 forester
98civic k24/k20 02 Rsx
so are u running a catch can now and is it hooked up to ur pcv valves ?
Silver Ra is offline   Reply With Quote
Old 06-15-2008, 03:28 PM   #3
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
this is what it is... pipe from each cylinder heads, the pcv that is on the block next to the throttle body, and the pipe that is on just below the throttle body into a water bottle with a small vented hole on top... it fills up way quick
Old 06-15-2008, 03:34 PM   #4
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
THIS DAMN THING!!! hahaa
Old 06-15-2008, 03:35 PM   #5
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
its the little gold stub on the rear of the block, right in the middle
Old 06-15-2008, 03:43 PM   #6
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
Old 06-15-2008, 08:20 PM   #7
Dom'sGurl
Member#: 150837
2006 Legacy GT
you have lots of pressure on that port? Do you have any vacuum source on your crankcase at all?
Excessive crankcase pressure usually means you have a blown motor.
Dom'sGurl is offline   Reply With Quote
Old 06-15-2008, 08:24 PM   #8
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
i was hoping blown and motor werent in the same sentence... damn thanks! haha
Old 06-17-2008, 01:22 PM   #9
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x10s
I would do the leakdown test. If it comes up clean, consider running a drain from the bottom of the catch can to the oil pan. That would recirc the oil back to the pan and the can won't fill up.
bluescoobywagon is offline   Reply With Quote
Old 06-17-2008, 02:12 PM   #10
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
hybrid have a big problem with blow by. It is well documented, and discussed. There doesnt seem to be agood solution to the problem.
NITROS is offline   Reply With Quote
Old 06-17-2008, 04:45 PM   #11
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
I was thinking that same thing!
Old 06-19-2008, 03:56 AM   #12
Rick539
Member#: 35997
We tapped it and put a pipe plug in. No problems or leaks. It puts out more oil than the other vent due to it being directly over oil gallery. The other vent has an alley way the gases pass thru to get to the vent. Much easier to understand if you look at them with the block apart.
Rick539 is offline   Reply With Quote
Feeler: KS - 02' PSM WRX - 18g EJ25 Hybrid jinsing7 Private Vehicle 'For Sale' Classifieds 6 03-06-2008 02:00 AM
322AWHP/300AWTQ with EJ25 Hybrid and 18g jinsing7 Proven Power Bragging 30 12-20-2007 03:36 PM
ej22t/ej25 hybrid! scubaracer Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-13-2007 08:34 AM
To tune.. or not to tune. EJ25 hybrid question FederalAuditor Engine Management & Tuning 5 02-09-2006 12:55 PM
Help form New Zealand EJ20/EJ25 Hybrid 1FSTKR Factory 2.0L Turbo Powertrain 4 07-19-2005 12:34 PM
Message Board Statistics All times are GMT -4. The time now is 08:19 PM.
