Old 06-15-2008, 03:40 PM   #1
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Default Question about Hybrid compression numbers
I need some help here guys. I don't have the technical know how to figure what my compression numbers should be when I get ready to compression test my hybrid before going on the dyno. I'm running stock 2.0 heads, STI shortblock. I had about 7 thousandths milled off the heads and am running the OE STI HG. What is the acceptable range of cylinder pressures I should see after the compression test? Thanks so much!
John
Acostafan is offline   Reply With Quote
Old 06-16-2008, 08:42 PM   #2
Acostafan
Member#: 67398
2002 Now with 100%
Monday bump for some help!
Old 06-17-2008, 02:57 PM   #3
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
What's important isn't the compression number, but the consistancy. Compression testers vary as do testing methods. Go ahead and test and post the numbers.
bluescoobywagon is offline   Reply With Quote
Old 06-17-2008, 03:40 PM   #4
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Your compression numbers will be effected slightly by your increased compression ratio, but there are other things that will effect it more, such as gauge accuracy, cam timing (and overlap) as well as the engine temp.
I would only worry if you had one cylinder that was 15-20% less than the rest, or if all were less than 100psi.
eastcoastbumps is offline   Reply With Quote
Old 06-17-2008, 03:59 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I had a slightly higher than normal CR hybrid and I would get 155-160psig on a warm compression test. Now that I'm at 8.5:1 I'm getting 145 psig
Old 06-17-2008, 07:47 PM   #6
Acostafan
Member#: 67398
2002 Now with 100%
Cool. Thanks guys. I will post up numbers when I do the CR test next week. I'm just trying to cover all my bases before I go to Topspeed.
Old 06-17-2008, 10:21 PM   #7
Turbo_Mike
Member#: 130276
2004 STi
JBP
Correct compression test by subaru standards...
Remove all coils and spark plugs.
Screw in compression tester, set throttle to 100% wide open.
Crank until gauge stabilizes at maximum.
Compression should be 131-175 (depends mainly on starter and battery)
Maximum difference between cylinders : 7 psi
Minimum allowable compression: 127 psi
Turbo_Mike is offline   Reply With Quote
Old 06-18-2008, 02:47 AM   #8
sleeperrex
Member#: 19466
2002 wrx/hybrid
I also have a hybrid using the same head gasket.
I measured 180psi on all 4. Originally i was measuring 155 on my 2.0 heads and engine.
sleeperrex is offline   Reply With Quote
question about hybrid engine foxtrott501 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-09-2010 08:21 AM
questions about hybrid swap wrxdrivr04 Built Motor Discussion 15 02-20-2009 02:43 AM
Question about doing compression test WrXwaBBit Service & Maintenance 6 07-10-2006 03:53 PM
question about mt compression test results kenlee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 05-13-2005 01:58 AM
Question about trim...part numbers?? jackacc Legacy Forum 4 02-25-2004 03:34 PM
