Old 06-15-2008, 03:41 PM   #1
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Default Sleeved or closed deck
Ok so im looking at the two options for my ej257.
Sleeved darton block or having the deck closed.
Not knowing the price of a darton sleeved block at this time makes the decision harder but im guessing it will be cheaper then having the block closed.
Which one do you think will be better price for performance and which will hold more power and for how long?
project_skyline is offline   Reply With Quote
Old 06-16-2008, 10:35 AM   #2
MS WRX
Member#: 117780
2004 WRX
Are you talking about filling the block with concrete or "Block Rock" to close it? If so i would prolly not do that, it can affect your cooling badly.
MS WRX is offline   Reply With Quote
Old 06-16-2008, 10:40 AM   #3
rex-a-saurus
Member#: 149930
05 WRX
CGM
^^Agreed. I believe thats why the sti's are semi-closed.
rex-a-saurus is offline   Reply With Quote
Old 06-16-2008, 12:39 PM   #4
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
no need to make a ej257 motor sleeved unless you plan on running 35psi or higher with a huge turbo
what hp numbers, what turbo, etc?
blowbyu24 is offline   Reply With Quote
Old 06-18-2008, 11:15 AM   #5
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
1200 or more crank hp. 42R or equivalent.
Here's the site that does the conversion.
http://www.xcceleration.com/engine-p...ceengines.html
Old 06-18-2008, 03:48 PM   #6
bboylocob
Member#: 151809
2007 WRX
i dont know about how much hp and psi the sleeves can take but if u looking for that amount off hp. Might want to step it up to a 45r.it will make ur goal alot easier to get too.plus a 45r is just friggin huge and it would be sweet!!!
bboylocob is offline   Reply With Quote
Old 06-18-2008, 07:06 PM   #7
BiGtUrBo
Member#: 126022
go with the Darton sleeves, it will costs alot less than their closed deck conversion. Also, their closed deck conversion looks like it's still using the stock sleeves, what good is that for the amount of boost you will need to run ???
BiGtUrBo is offline   Reply With Quote
Old 06-18-2008, 07:25 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
my sleeving is the same cost ($1000) as there's. I use Darton sleeves though.
My vote would be sleeves from a personal opinion. You can fit a bigger bore with a sleeve and the sleeved block can handle plenty of pressure
no need to spend $3500+ for closing a block
Old 06-18-2008, 07:39 PM   #9
moorebl
Member#: 59238
it cost me about 2500 extra to have my motor sleeved. i did it just in case i decide to get crazy. its great if you plan on keeping your car and modifying it to high hp
moorebl is offline   Reply With Quote
Old 06-18-2008, 07:56 PM   #10
norexyet
Member#: 39149
11 elantra
yea i said elantra
I would go with sleeving also. It eliminates any cooling issues and can hold as much as you are looking to run. My coworkers sleeved block has almost 15k miles on it with countless 30psi dyno runs with no issues.
norexyet is offline   Reply With Quote
Old 06-18-2008, 10:49 PM   #11
JMK508
Member#: 115420
It's like a STI but
it doesn't break= EVO
30k for a longblock............**** that
JMK508 is offline   Reply With Quote
Old 06-19-2008, 12:12 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
but it will give you're a on command
then you'll be
Old 06-19-2008, 02:33 AM   #13
SaabTuner
Member#: 67608
The trouble with sleeving is that the pistons can get dramatically hotter because cast iron sleeves conduct less than HALF the amount of heat aluminum conducts. This often misleads people into thinking the engine is LESS detonation prone because, as less heat is absorbed from the pistons, the engine tends to run cooler. Nothing could be further from the truth.
The EJ205/207/257 were not designed to have such thick, relatively insulating, iron (or steel) sleeves, and the pistons can easily become quite hot by installing such things. Not only does this exacerbate any existing predilection for detonation, but also makes the piston itself much weaker and more likely to fail, should any detonation occur.
That doesn't mean that "closing" the deck is a better solution. However, using an already-closed deck, such as the EJ22, is generally the ideal solution.
Another solution is to sleeve it, and have piston-cooling oil jets installed. (If I remember right, the oil passageways through all the EJ motors are the same where the EJ22's oil jets get their oil supply.) I have seen pictures of EJ257's with this done. Just make sure to upgrade your oil pump if you have this done, as you will need the larger pump to meet the increased demand for oil flow.
My 3.14159265358 cents
-Adrian
SaabTuner is offline   Reply With Quote
Old 06-19-2008, 10:21 AM   #14
MS WRX
Member#: 117780
2004 WRX
$30k??????? You can buy Supra longblock for 25k that will hold 50 psi and make 1400 whp.
Old 06-19-2008, 11:34 AM   #15
Homemade WRX
Member#: 33782
96 bastard child
-Adrian
I was going to say "but oil..."
you can have a similar effect without having to install oil squirters through your rod design. You note the EJ257 rods come from the factory with notches at the top of the big end. Pauter also offers this as an option
Old 06-19-2008, 12:26 PM   #16
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
I don't know much about those xcceleration guys but there prices appear to be aawful high. I've seen mostly sandrail engine builders that will close a deck for a lot cheaper than this place.
kellygnsd is online now   Reply With Quote
Old 06-19-2008, 04:23 PM   #17
MS WRX
Member#: 117780
2004 WRX
And you can rock it for much much cheaper
Old 06-19-2008, 07:14 PM   #18
renosfasteststi
Member#: 97044
I had the same dilema... I ended up going with a sleeved block.....Their is a place in so-cal who is probably the most reputable place to have the deck closed but they said they have never ran more than 30 psi through it so they wouldnt gaurantee anything......so I'd go sleeved if I were you..
renosfasteststi is offline   Reply With Quote
Old 06-22-2008, 05:11 PM   #19
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Ya i had never heard about xcceleration either until we stumbled upon it one day while searching engine stuff.
The price does seem a little high and if i did somehow chose to get it done im not sure if i would even do them.
Sleeving does seem like the better option.
Thanks for everyone's input especially saabtuner.
Old 06-22-2008, 05:16 PM   #20
JOEFLAT4
Member#: 179090
closed deck.
JOEFLAT4 is offline   Reply With Quote
Old 06-22-2008, 06:03 PM   #21
sanjay
Member#: 100624
2004 WRX Wagon
You can do both the Sleeved and closed deck.
sanjay is offline   Reply With Quote
Old 06-22-2008, 07:03 PM   #22
charliew
Member#: 125304
It's just my shade tree observation but I don't see the wrist pin end on the rod providing the same spray as the squirters on the closed deck motors. I'm guessing the slots in the rods do let the excess oil out of the rod but it won't have the pressure that is at the squirters, also it is a place to help loose oil in a bearing. If the piston is really hot that also means the wrist pin needs all the help it can get on oiling. I'm guessing the closed deck motors run a little hotter and thats why the squirters were added.
charliew is offline   Reply With Quote
Old 06-22-2008, 07:59 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
the big end of the rod is the end that gets the grooves and a larger pump and preferrably a higher pressure would be recommended as well...as for pressure of the oil being ejected, your right, that will will have a little less pressure but will be the same pressure your rod bearings are seeing.
The velocity, aim and distance to travel is what should really matter...now think of the rods motion (and forces) in relation to the cylinder wall and piston.
Also in this case, you know the piston getting oil will only result once the rod bearing has recieved it.
Now any pressure drop is of course pretty much trouble. With the rod relief, if a pressure drop occurs you know you have oil getting to the bearings for a longer period of time than with squirters because of the volume flow order.
Rod bearing oiling > piston oiling
Darton sleeved Ej22t closed deck shortblock Texy32 Engine/Power/Exhaust 13 12-27-2009 03:40 AM
Block options: open or closed deck 2.5rsDOHC Normally Aspirated with bolt-on Forced Induction Powertrain 19 08-21-2004 01:01 PM
open or closed deck? phwishpow Normally Aspirated Powertrain 2 01-12-2004 09:05 AM
open deck or closed deck enyce4u Normally Aspirated Powertrain 14 02-16-2002 02:56 AM
will the new WRX have open or closed deck? Gambit Normally Aspirated Powertrain 6 01-16-2001 03:29 PM
Message Board Statistics All times are GMT -4. The time now is 08:57 PM.
