Old 06-15-2008, 04:43 PM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Ideal set up for drag racing?
Between these two set up which one would you pick if you are to run your car at the track?
1. Stock 07 WRX wheels and RE92 (20 + 23 lbs) = ~43lbs
2. Stock 04 BBS wheels and RE070 (16 + 27 lbs) = ~43lbs
I tend to believe better drag set up may be #1 since more weight is distributed toward the edge with set up #2. Any thought?
Your help is appreciated.
gopsu is offline   Reply With Quote
Old 06-15-2008, 05:11 PM   #2
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
what size are the tires
I Love Boobies is offline   Reply With Quote
Old 06-15-2008, 05:31 PM   #3
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
Using BBS Wheels I would go with 245/45 17R SLICKS
tux121 is offline   Reply With Quote
Old 06-15-2008, 06:47 PM   #4
gopsu
Member#: 96448
02 WRX VF34
245 width may not be ideal on a 17.5 width wheel... 245/45/17 means about an inch taller than OEM rubber size and about 3-4 lbs heavier.
RE92 = 215/45/17
RE70 = 225/45/17
Old 06-15-2008, 07:25 PM   #5
Arctic Penguin
Member#: 119532
2006 WRX
f body and a big turbo
Arctic Penguin is offline   Reply With Quote
Old 06-15-2008, 11:07 PM   #6
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
a better drag setup would be 16s.
Old 06-15-2008, 11:14 PM   #7
gopsu
Member#: 96448
02 WRX VF34
Unfortunately, my car has 4 pot brakes in the front and do not really like how RS wheels look.
Which set of wheel to use for drag racing? txl146 Tire & Wheel 5 05-14-2008 01:33 PM
Ideal wheel set up for a 1/4 mile drag run? txl146 Motorsports 3 05-09-2005 10:00 PM
Ideal rims for drag racing Need4Boost Tire & Wheel 7 03-26-2005 12:55 PM
JIC dampers - settings for drag racing? edkwon Brakes, Steering & Suspension 1 05-27-2003 03:38 AM
Up tire pressure for Drag racing? Ethan Brakes, Steering & Suspension 2 02-19-2002 08:57 AM
Message Board Statistics All times are GMT -4. The time now is 06:06 PM.
