Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 03-01-2002, 08:17 PM   #1
Supapooh
Member#: 4461
02 2.slow
Default Pics of My Zex install for those who care.
The install was very straight forward with not a single problem at all. All said and done it took about 3 hours from start to finish. I have yet to fill the bottle and try it. However the brain is programmed, and the purge solenoid does work. I can't wait Here is the first one of the bottle in the trunk.
Supapooh is offline   Reply With Quote
Old 03-01-2002, 08:18 PM   #2
Supapooh
Member#: 4461
02 2.slow
Here is the wiring and the nitrous line routed through the firewall.
Old 03-01-2002, 08:19 PM   #3
Supapooh
Member#: 4461
02 2.slow
Here is the arming switch and the purge button mounted on the center console
Old 03-01-2002, 08:20 PM   #4
Supapooh
Member#: 4461
02 2.slow
here is the zex "brain" You can see the T used for the purge solenoid as well as the T I used to connect the vacuum/intake hose.
Old 03-01-2002, 08:21 PM   #5
Supapooh
Member#: 4461
02 2.slow
Here is the purge solenoid.
Old 03-01-2002, 08:22 PM   #6
Supapooh
Member#: 4461
02 2.slow
And here is where the "purge" exits through the vent on the hood.
Old 03-01-2002, 09:32 PM   #7
HudsoN456
Member#: 11462
1999 Integra GS-R
Super Sonic Blue Pearl
Thumbs up
That is pretty freakin cool. Try it and tell us how it feels!!
-Adam
HudsoN456 is offline   Reply With Quote
Old 03-01-2002, 10:27 PM   #8
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Can you post some pics of the intake part of the kit? Where and how you are running into the motor?
Are you adding additional fuel?
Looks good! Love the switches...big fan o' switches here.
NC
Reciprocity is offline   Reply With Quote
Old 03-01-2002, 10:42 PM   #9
Supapooh
Member#: 4461
02 2.slow
No extra fuel.....yet, It's only a 55 shot. I tapped the nozzle into the cobb cai. Its about 8" away from the tb. I'll try to get some pics when it's light out. And I should be filling the bottle this week.
Old 03-04-2002, 07:24 PM   #10
Pikeadon
Member#: 4422
00 RS
Yellow
I hope to get the zex kit it looks so easy to install. ZWhen you get the bottle filled can you post how much it cost, and how did you mount the bottle in the trunk/ thanks
Pikeadon is offline   Reply With Quote
Old 03-04-2002, 07:27 PM   #11
satrya
Member#: 5887
2002 GDAA
797
Cool. Curious though, would there be any harmful effects if water / other material gets into the upward facing purge tubing?
satrya is offline   Reply With Quote
Old 03-04-2002, 07:34 PM   #12
Supapooh
Member#: 4461
02 2.slow
I don't think so as it would all just be pushed out
Old 03-04-2002, 07:59 PM   #13
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
you'd think so given that the purge will be happening at 900-1100 psi.
ColinL is offline   Reply With Quote
Old 03-04-2002, 08:35 PM   #14
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Eh maybe you could make some kind of flap on the tubing going up.....Like on Mack truck exhaust pipes.....Just a silly idea.....Nice pics, like the install. Thinking of getting a Zex kit myself, just trying to figure out which to get first the Zex or a proecm chip.
Buster
EvasionOfTruth is offline   Reply With Quote
Old 03-04-2002, 09:09 PM   #15
Supapooh
Member#: 4461
02 2.slow
If I were to do it again, I would get the chip and pulleys. I just found the zex pretty cheap so I went with it. But you can't beat having power anytime. Rather than relying on a bottle. I have to drop my bottle off to be filled, I will probably do that tomorrow.
Old 03-05-2002, 06:39 PM   #16
tulit
Member#: 338
09 STi
Where did you run the nitrous line? (looks like through the interior. BAD idea)
tulit is offline   Reply With Quote
Old 03-05-2002, 09:22 PM   #17
Supapooh
Member#: 4461
02 2.slow
Yup ran it under the carpet. Whys it a bad idea?
Old 03-05-2002, 09:59 PM   #18
Jesse Lorenzen
Member#: 14962
2008 Impreza 2.5i
Pearl
Where did you get the Zex kit and for how much? I can't find any mention of it on the Zex website.
Jesse Lorenzen is offline   Reply With Quote
Old 03-05-2002, 10:32 PM   #19
Supapooh
Member#: 4461
02 2.slow
I don't wanna say the price. I bought it used though The purge kit was only 100.00 however It's the honda/acura kit
Old 03-06-2002, 12:43 AM   #20
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Did I read that correctly, you put a honda/acura n2o kit on your subie? Well now that i think about it, it should be fine. But i'm not sure you'll be getting the "55" horse advertised. This on has a t/b spacer & it mixes it's onw fuel/n2o correct? Good luck & don't kill yourself or someone else. btw, n2o is'nt cheap so don't blow it to often. And, DO NOT SMOKE NEAR OR IN YOUR CAR!!!! VERY EXPLOSIVE!!!
Tim Sanderson is offline   Reply With Quote
Old 03-06-2002, 01:08 AM   #21
gasser
Member#: 3110
2001 2.5RS
STM shiny gray
HI, ...
can you explain the need for a T on your vacume lines please?
You should run it under your car for other safty reasons, not becuase it is VERY EXPLOSIVE! Becuase anyone that knows anything about N2o knows its non-flamable
sorry about my spelling I know it sucks. but I would like to know the need for the T you used in your vacume lines?
gasser is offline   Reply With Quote
Old 03-06-2002, 01:53 AM   #22
Pikeadon
Member#: 4422
00 RS
Yellow
gasser, your right N2O is non flammable, it just helps the fuel combust more rapidly
So what are the other safety reason for not running the line in the car.
-would it be because a puncture in the line would eventuly put enough N2O in the cabin to put you to sleep?
Old 03-06-2002, 02:04 AM   #23
Supapooh
Member#: 4461
02 2.slow
Wow........it's not explosive, and why wouldnt I get the 55 hp shot I jetted it for? It sprays directly into the intake, about 8" before the tb. The honda/acura kit is not only specific to honda/acura. It's the same number as they do not have or need a specific kit for every car. Why would I kill myself or someone else
The T on the vacuum lines is ran into the zex. It was put there for raising the fuel pressure I believe. I feel confident running the line through the cabin. The ss braided hose is pretty puncture proof. I feel that inside the car is a lot safer than underneath where it could get caught on something or something could kick up and hit it.
Old 03-06-2002, 02:07 AM   #24
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Don't use a crank pulley with Nitrous or a Turbo..bad...
Eric
Eric SS is offline   Reply With Quote
Old 03-06-2002, 07:20 AM   #25
foolio
Member#: 9351
2006 trailblazer SS
black
So you mean that i couldnt get the N1 pullie set?
Why?
J
foolio is offline   Reply With Quote
Pics of Gram Lights Optimise for those who asked. SCRAPPYDO Tire & Wheel 16 09-12-2007 12:57 PM
few pix of my xb from JDMTHEORY meet for those who care djcttb Member's Car Gallery 55 07-07-2007 07:11 PM
pics of Greddy catch can install for all who care ellisnc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-12-2002 07:59 PM
for those who care after my BBQ/Bday fun run ^jynx^ Tri-State Area Forum 2 09-10-2001 06:40 PM
For those who care, more part numbers!!! North Ursalia General Forum Archive 0 10-14-2000 12:24 AM
