Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 06-16-2008, 02:44 PM   #1
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Default Storing new tires on rims
I have a set of WRX 17 inch rims with new bridgestone tyres(fitted to the rims).
I have stacked them 4 up on the concrete floor. Is this okay?
What is the best way to store them?
runner19 is offline   Reply With Quote
Old 06-16-2008, 02:56 PM   #2
subaru3169
Member#: 55252
* pullup bar *
i don't see how that's bad.. unless they see crappy weather conditions.. i'm assuming you mean on a concrete floor inside an enclosed area??
subaru3169 is offline   Reply With Quote
Old 06-16-2008, 04:56 PM   #3
gtboost
Member#: 87716
2005 FXT
You should let the air out of the tires due to the fact that it will cause the tire to dry out faster. Also put something between the tire that is touching the concrete floor because concrete will obsorb the oil that is in the tire and cause it to dry out faster.
gtboost is offline   Reply With Quote
Old 06-18-2008, 08:24 AM   #4
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Yup it is in a closed garage. But on a concrete floor. I will put a plastic sheet between the last tyre and the concrete floor
I was just concerned about the weight on the last tyre. There are three other rims+tyres resting on it. Is this okay.
Old 06-18-2008, 08:45 AM   #5
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
that's the same way I store them ...
Luke@tirerack is online now   Reply With Quote
Old 06-18-2008, 11:56 AM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Luke, aren't you supposed to pimp out your tire storage bags?
I stack mine in the free plastic bags I got from TireRack when I bought my tires. I don't usually let all the air out, just most of it.
bluescoobywagon is offline   Reply With Quote
Old 06-18-2008, 12:17 PM   #7
subaru3169
Member#: 55252
* pullup bar *
oh damn.. i should take out the air in my other set of wheels
Old 06-18-2008, 02:40 PM   #8
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
yeah .. .that's thinking
hey OP buy these
or this
if you don't the world as you know it will change forever
but I use some of those same bags you mentinoed for many of the ones in my garage
Old 06-18-2008, 02:46 PM   #9
bluescoobywagon
Member#: 14911
Not A Wagon!
I should mention that the reason I don't let all the air out is that one year I had loaned out my air compressor and then when I changed my tires from winter to summer, I still had enough air to nurse it to the gas station. If they were completely flat, I would have had to switch the tires back. I never let the air out to reduce moisture loss, I always did it to reduce stress on the sidewall and to help prevent balooning. It makes sense though...
Old 06-18-2008, 03:08 PM   #10
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I go through tires so fast that I am sure they are thrown away before I can see the tire drying out becuase of being aired up.
medamullet is online now   Reply With Quote
Old 06-18-2008, 03:52 PM   #11
Web Foot STi
Member#: 39086
2004 STi
Large contractor garbage bags work well to keep the sun light away, and put p the tyres near electric motors (ozone).
Web Foot STi is offline   Reply With Quote
Install/Balance new tires on rims (North Shore) NorthVanWRXOwner2be Vancouver Impreza Club Forum -- VIC 4 12-01-2009 03:48 PM
New tires on stock rims. shady Tire & Wheel 5 01-31-2006 04:31 AM
New tires on stock rims?? FastWagon Brakes, Steering & Suspension 12 04-21-2003 07:10 PM
new tires on stock rims -LD Brakes, Steering & Suspension 17 02-07-2002 01:31 AM
