Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 06-16-2008, 08:25 PM   #1
ReubenH
Member#: 172522
1998 Legacy GTB Ltd.
Default Keep blowing the foglight fuse
This is for a JDM 98 GTB Limited, it has 4 foglights (pic), and a switch to turn the fog lights on, and another to select between the big round ones, and the little projector ones. you can't have both on at once. The ones on the outside of the projector fog lights are turning lights, come on with the indicators (just FYI).
As the title says, i keep blowing the fuse for the foglights. It first happened when i went to put them on after getting back on the road from a rebuild, no luck... Tracked it down to a simple blown fuse, so put another one in. it worked for a while, but later blew that one too. I checked all the plugs, all was in order, then put a 20amp fuse in. It worked for about half an hour, then blew again... So no more replacing fuses, otherwise something is going to catch fire... any ideas what might be causing this? The little fog select switch's light has blown. Could that be it? only thing i can think of...
ReubenH is offline   Reply With Quote
Help Perrin PW-1/Aquamist keeps blowing the 15A fuse sutter2k Water/Methanol Injection, Nitrous & Intercooler Cooling 1 06-06-2008 04:52 PM
keep blowing "clock room" fuse in my 02 bxracer69 Electrical & Lighting 1 02-20-2008 07:53 AM
Blowing the main fuse to ECU everytime I turn the key reddevil Electrical & Lighting 2 04-19-2007 09:26 PM
Keep blowing tail light fuse- HELP... MK19 Electrical & Lighting 9 06-23-2003 01:06 AM
I keep blowing my abs fuse DoorKnob Technical Forum Archive 1 06-28-2000 12:32 AM
