Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 06-16-2008, 09:29 PM   #1
turboboxer80
Member#: 172286
04 wrx
87 rx coupe
Default oil pressure problem please help me.
ok so i just got done putting in jdm ea82t. my oil pressure gauge is pegged at max. i think it says like 85 psi. but when i start the motor you can here that the lifters are not pumped up and sounds like a diesel. am i missing something? is there two oil pressure sensors. on this car? i havent seen two. when i unplug the wire next to the filter the gauge stays that way at max? im frustrated. i just want to drive it .
turboboxer80 is offline   Reply With Quote
Old 06-17-2008, 12:48 AM   #2
Keiji22
Member#: 175854
98.5 Volvo V70 XC
Bleached Sphincter
There are two oil pressure switches. A small one, and a large one.
The large one is the one you want your wire connected to.
If it is still pegged, check for any leaks.
If you're hearing your engine do the "bang bang bang" like a diesel... I hate to say this but you probably snapped a rod. >.<...
It happens when you have absolutely no oil pressure and all of your bearings are burnt out.
Worst case scenario, go buy a mechanical oil pressure gauge. unscrew the small switch and install the mechanical oil pressure gauge into it. It comes with brass fittings and whatnot. If you are getting the correct amount of oil pressure, then I suggest installing that in your car instead of the stock oil pressure gauge.
I know, I just had this happen to me as well. Turned out to be a broken gauge in the dash.
If you are getting the correct oil pressure, you probably haven't thrown a rod. Maybe an issue with your cams?
Keiji22 is offline   Reply With Quote
Old 06-17-2008, 11:11 PM   #3
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
^^^Ok you need to go read up on the EA82T a bit my friend
Turboboxer80 - First off, you need to make sure the sending unit you have is for the gauge, not an idiot light. It sounds like you have the one for the idiot light then the gauge in there currently which is making the gauge go WTF? The gauge sending unit is much larger compared the idiot light sending unit since the idiot sending unit is just a switch where the gauge has a rheostat potentiometer (its very similar to an old thermostat in a house that has a rheostat in it).
Second, I've only seen an EA series engine snap rods on a couple cars and that was due to a blown headgasket, then being run like that until it basically hydrolocked, snapped the rod, sent it through the block AND then started back up and kept going. I'm willing to bet it needs to run for awhile before it gets all the air out of the lifters. Very common problem with an engine thats been sitting for more then a month. My new XT6 sat for a month and had a valve tick, it went away after a couple miles of driving it too.
Caboobaroo is offline   Reply With Quote
Old 06-18-2008, 11:21 PM   #4
turboboxer80
Member#: 172286
04 wrx
87 rx coupe
caboobaroo
how can i tell wich oil sending unit i have. when i started it the oil pressure gauge went to max. and after a few minutes the lifters were sounding bad so i didnt want to messing any thing up. so i just turned it off. there is a oil leak from the crank seal that i have to replace, and the oil pan has a large dent in it i assume from shipping. so you are saying that i should let it run for a little while and see if that lifter noise goes away.
Old 06-19-2008, 12:21 AM   #5
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Originally Posted by turboboxer80 View Post
caboobaroo
Wheres the dent? It could be blocking the pickup tube, and could be why its sounding the way it is.
When I got my new engine and installed it, it sounded like that for about 10min before the lifters pumped up.
TurboneX is offline   Reply With Quote
Old 06-19-2008, 01:17 AM   #6
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
the one for a light will be about the size of a quarter, the other one, the one for the gauge, is a cylinder shape bigger around then a half dollar and about an inch in length. It'll also have a screw on the end of it which a wire is connected, This wire will get connected to the main wire that goes into the engine harness. The idiot light switch has the wire directly connect to it.
Old 06-19-2008, 01:08 PM   #7
turboboxer80
Member#: 172286
04 wrx
87 rx coupe
jdm motor didnt have the screw in wire type oil sensor but the original motor did. can you change that whole piece where the filter connects to?
Old 06-19-2008, 03:13 PM   #8
subari87
Member#: 167422
1987 3 main
subari87 is offline   Reply With Quote
Old 06-19-2008, 06:43 PM   #9
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
You can replace the complete pump, but its possible to replace the sender. And much easier. If you swap out the pumps, make sure you replace the rubber gaskets and the seal.
Last edited by Flowmastered87GL; 06-21-2008 at 09:22 PM. Reason: Removing Subari nonsense
Old 06-20-2008, 12:41 AM   #10
Caboobaroo
Member#: 72335
89's RX/XT6
Blacksssssss
When I got a new oil pum p for my old RX, it had both sending units in it, the light sending unit was up at the top of the pump and the other one was down on the lower front of the pump
Old 06-21-2008, 09:16 PM   #11
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
To elaborate a bit more..... the light one at the top screws in from the front, and the lower one for the guage kinda hangs down diagonally at a 45% angle if I recall.
Flowmastered87GL is offline   Reply With Quote
Oil leak problem, Please help! roloc31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-19-2008 12:49 AM
Oil leak problem, Please help! roloc31 Newbies & FAQs 4 10-17-2008 09:50 PM
Oil leak problem, Please help! roloc31 Newbies & FAQs 3 10-09-2008 08:34 AM
('93-'01) Gauge light problems please help me Texas25RS Impreza Forum 1 04-25-2001 08:44 AM
CE light problem please help me! ac_gohan Bay Area Impreza Club Forum -- BAIC 15 02-10-2001 10:56 PM
